Question about Panasonic CW-1006FU Air Conditioner
Outdoor unit fan is running when turned of inside? is this normal?
    Novelist:
    Champion:
  • 246 Answers
No. The thermostat (located in the house) controls both the inside and outside units.
A common problem for the situation you're describing (and the one I will explain here) is that the contactor (located in the outside unit) which is controlled by 24 Volts coming from the 'inside' thermostat - has 'stuck' in the 'made' position (causing line voltage to remain to the condenser 'and' possibly to the compressor).
To 'determine' this - 'turn off the line voltage to the outside unit.'
You do that by locating the 'breaker/fuse box' which is located near the outside unit. It will be a gray box about the size of large cigar box - and will be attached to the side of the house usually - although it can be on the AC unit itself.
The lid can be lifted which will expose a 'breaker switch' which resembles a light switch (sometimes a little larger) which can be flipped in the OFF position.
If it's a 'fuse block' - then you will have to grip it and pull it out. Usually there will be a metal ring that you can grip and pull. Once the 'block' is out - you will notice that it contains two fuses.
Either way - once you flip the switch down or pull the fuse block - the line voltage is disconnected to the AC.
NOTE: some 'older' breaker boxes contain 'knife connectors,' which are designed to 'disconnect line voltage' by the action of 'pulling a handle (on the side of the box) ... down. When this handle is pulled down the 'knife connectors' will 'disengage - thus disconnecting the line voltage to the AC unit. "It is not uncommon" - for 'one' of these 'knife connections' to remain in the "connected" position - which will still leave partial line voltage to the outside unit - a potentially dangerous situation.
Point being - it is always wise to check the voltage coming in (with a voltmeter) before sticking your hands into a electrical device like a AC.
That being said - sometimes after turning off the breaker switch (or pulling the fuse box) you can hear a 'buzzing noise' coming from the outside unit. If you hear this noise - it means you are still getting 24 Volts from the inside thermostat. However, in this case, assuming the thermostat is indeed OFF - then you shouldn't hear any buzzing noise.
Either way - when you turn the breaker off the unit will shut off. NOTE: be sure the inside thermostat is in the OFF position.
Then you can open the electrical panal of the AC unit and take a look at the electrical components. NOTE: as stated above it's always 'wise' to use a voltmeter and "make sure" there is no voltage to the unit. You are looking for 24, 110 or 220 volts.
The component (contactor) you are looking for is usually easily identified because the unit's main electrical wires (typically 3) are coming into the contactor from the breaker box.
This component usually has a small plastic front plate that can be removed by taking out a couple of screws. (Note: it wouldn't be unsual for this cover to be missing already)
Once the cover is removed you can see that this device is designed to 'connect' the wires coming in from the breaker box to another set of matching wires that sends line voltage to the fan and compressor among other things.
It is a 'spring loaded' device that is usually 'pulled together by 24 Volts coming from the inside thermostat - but by depressing it (manually with a screwdriver) will cause the copper contacts to "make" - thus - connecting the wires from the breaker to the wires sending voltage to the fan and compressor.
This is accomplished with 'spring loaded action.' Normally - you should be able to take a screwdriver (as stated above) and manually depress the contacts - but in this case - it - may already be - "made" - and you will not be able to this.
Usually if this is the case the copper contacts have 'burnt' together - and the connection is permantely engaged - which is what causing the AC to run (outside) even though OFF on the thermostat inside the house.
If the contacts have burnt and are permantely engaged - then the 'fix' is to replace the contactor - which can be accomplished by removing all the wires (from the contactor) - clearly labeling them so you can replace them on the new one.
Once you've removed all the wires - you need to remove the contactor from the unit. It will usually be 'screwed' into the unit with screws.
Once you have the contactor out you can take it to a Air Conditioning Supply house and buy a replacement part. I would try to get an identical contactor - to make it as easy as possible re-installing it and putting the wires back on it.
NOTE: I would not attempt this unless you are -very - "mechanically inclined." Changing out a contactor can be very complicated/difficult.
Also - 'paying a Service Tech to do this for you - shouldn't cost much - probably less than $100 (if you already have the replacement part).
Posted on May 13, 2010
Luxpro psd111 thermostat shows snowflake (sometimes blinks), outdoor fan works, but no cool air comes out inside- no air flow at all. Is it the thermostat or an a/c unit malfunction?
If the outdoor unit is running the indoor fan should definitely be running. Turn power off to indoor unit. Put red green and yellow wires together behind the tstat with a wire nut. That is power (red), indoor fan (green), and compressor (yellow.) Turn power back on. This is bypassing the tstat and you should have indoor fan and outside running as well. If yes the problem is in the tstat, if no indoor fan the problem is in the unit. Good Luck!! Let me know!!
Apr 28, 2017 | Heating & Cooling
Split system is not heating however the fan outdoor is ok and the unit inside is flowing
If everything seems to be working but it's not heating or cooling, check the contactor that turns the compressor on at the outdoor unit. Make sure you have power through both legs of the contactor because sometimes they will build up carbon an the contacts and not allow normal electrical flow. If the contactor is pulling in and there is power going through it, you'll need to check the run capacitor and the compressor itself
Aug 16, 2016 | Electrolux Heating & Cooling
Haam air conditioning split then I switch on come to E7 what is the problem in my a c please give me answer any parson
Malfunction of Outdoor Unit Fan Motor ( E7)
Remote Controller
Display
E7 Method of
Malfunction
Detection
Abnormality of fan motor system is detected according to the fan speed detected by hall IC when the
fan motor runs.
Malfunction
Decision
Conditions
?? When the fan runs with speed less than a specified one for 15 seconds or more when the fan motor
running conditions are met
?? When connector detecting fan speed is disconnected
?? When malfunction is generated 4 times, the system shuts down.
Supposed Causes ?? Malfunction of fan motor
?? The harness connector between fan motor and PC board is left in disconnected, or faulty connector
?? Fan does not run due to foreign matters tangled
?? Clearing condition: Operate for 5 minutes (normal)
Troubleshooting
Caution
Be sure to turn off power switch before connect or disconnect connector, or parts damage may be
occurred.
Replace the outdoor unit fan motor.
Connect the connector.
Remove the foreign matter.
YES
NO
Are fan motor
connectors
disconnected?
NO
YES
Is the pulse input?
Check No. 11 Check for pulse input
for number of rotations
on the outdoor unit
PC board.
Replace the outdoor unit PC board.
YES
NO
NO
YES
Is there
any foreign matter
around the fan?
Can the fan be
easily rotated by hand?
(S2584
Jun 07, 2016 | Heating & Cooling
How to troubleshoot thermostat wiring?
I'm not sure if the thermostat is wired correctly. First, the thermostat is wired directly to the outdoor unit (compressor/condenser unit). It is NOT directly connected to the indoor unit. It connects to a low voltage control panel in the outdoor unit that sends a signal to your indoor fan/evaporator. This wire is called the fan relay switch and physically runs between the low voltage controls of the indoor and outdoor units. If the fan relay is bad it's possible that the unit runs continuously. To prevent destroying your outdoor unit there is a safety feature that prevents the indoor fan from shutting down while the outdoor unit is running. If the indoor fan did shut down while the outdoor unit was running than you would slug your compressor. That is, your compressor normally sees refrigerant gas but is instead seeing refrigerant liquid. That would not be good since this scenario would destroy your compressor. It sounds like a faulty fan relay. The actual contactor portion of the relay is in the outdoor unit.
Aug 22, 2014 | Honeywell Electronic Programmable...
I have a Weather King Heat Pump Outdoor Unit, Model 10PJA3101. I noticed that the a/c was on and working fine inside but the fan was NOT moving on the outdoor unit. There are no tripped breakers or...
If you are cool inside and the fan is not running then you are ok... I would however turn the temps. up a bit to eliminate more stress then necessary...
I am surprised that the fan is not working and you are still cooling though.
Was it a windy day? on a still day it may not work...
Are you sure the compressor was running but the fan not???
Some outdoor units do have switches that will turn off the fan if the head pressures are too low if the air temps. are low...
heatman101
Jul 06, 2011 | Weather King 10AJA2501AH Air Conditioner
Indoor fan slow to rotate in heat mode and no heat/compressor
The indoor fan will not run at normal fan speed untill the indoor coil reaches 32oC. This is done so that a cold draught is not felt when outdoor unit is not running. Check to make sure the outdoor unit is operating. If the outdoor fan is running but there is no indoor fan after 5 mins then you must likely have a gas issue or a fault compressor circuit.
May 31, 2010 | Fujitsu 24R1 Air Conditioner
Rudd Acheiver 13 nothing turns on outside but the fan inside is
Try pushing the red reset button at the outdoor unit near the brass service valves (where the refrigerant lines enter the outdoor unit). Also check for power from circuit breakers furnishing power to the outdoor unit ( the indoor unit has a seperate power supply source ). There may be fuses in the service disconnect box mounted near your outdoor unit. If those "blow" they will prevent operation of your outdoor unit. You can test continuity using an ohmmeter. If you do not have an ohmmeter, you can take the fuses to the local hardware store. They should be able to test them for you and offer replacements if needed. If after doing all these steps you continue to have problems, let us know and we will dig a little deeper. :-)
Apr 18, 2010 | Ruud UBHC Air Conditioner
Air conditioning won't work. Thermostat says it's in 'recovery mode'
by the outside unit, you will have a shutoff. pull out the shutoff, and unscrew the cover. 2 cylinder like fuses are inside. It is likely that one or both are bad. When you turn on the AC and the outside fan does not turn on... this is likely this is the solution.
Apr 28, 2009 | Honeywell Electronic Programmable...
Vibration when heat only is on inside and out
Is it noisy always when running in heat or only for intermittant periods? Depending on where you live every 45-90 minutes of run time the heat pump goes into a cycle called defrost. The fan on the outdoor unit will shut off. the compressor will continue to run but in actually cool mode. this heats the outdoor coil and allows any frost or ice that is built up on the outdoor coil to melt. The compressor can get pretty loud in this mode and you may actually see steam coming off of the unit. This is normal. However if it is noisy all of time in heat check/clean your coils. If this doesn't remedy it have your refrigerant charge checked by a NATE certified Service Technician. Good luck.
Nov 22, 2008 | Goodman CLQ36AR49 Air Conditioner
Panasonic CW-1006FU Air Conditioner Logo
111 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
