Question about Home
I have an AEG Undersink water heater installed. Unfortunately just about every time I turn the tap mixer to hot, the unit trips out and I have to remove the cover and reset it. Is this an electrical / wiring problem or is the unit at fault? Any help would be greatly appreciated!
  • 56 Answers
Check the voltage supply if it is good the the unit is bad
Posted on May 14, 2010
Takes a long time to get cold water. Then it is still luke warm. New house. Unhook it, and you get plenty of cold water. Takes forever to get hot.
Open water heater drain valve or TP valve to see if unit is producing hot water.
Protect yourself from scalding water.
If water heater is not working, then call service technician, or re-post question on fixya with type of water heater, description of water heater and brand, and what you have done so far to repair problem.
If water heater is working, then you probably have crossover problem at recirculation system check-valve or at single-handle faucet. Or both.
Remove check valve and clean with white vinegar; replace defective single-handle faucet cartridge.
Open following links for resources
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Water-heater-recirculation-system.html
Jul 31, 2011 | Laing Thermotech Autocirc Undersink...
I installed a new water heater it has power to it but it is net heating up, is there a reset button if I tripped a breaker within the unit
First a question. Did you fill the water heater until water ran freely at the hot taps.
If not you may have had an air pocket and blown an element. Water heaters will
always be shipped with the ECO in the reset position. The reset is a RED button
located under the upper cover for the thermostat. Shut off breaker to water heater
and remove this cover, and the fiber glass, then push the reset. Replace the fiberglas
and the cover securely and turn on power. You should actually hear the heater in most
cases. Remember that it takes about 45 minutes for a full tank of hot water from startup.
Feb 27, 2011 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Same problem with rinnai V1200.starts ok and as soon as you want to ajust cold water,the hot water line gets cold.**** all design
These units need water flow/pressure to work. If you use a mixer to get the right temperature as soon as you try to increase cold to make the water colder you unfortunately reduce the hot flow. Fairly complicated fault to explain, all continuous flow units have the same flaw. Solution is to try and increase flow and the best way is to take any water filters or restrictors out of your tapware. Most taps have the located in the end of the spout. Unscrew the end and remove any restrictors. Shower roses are a bit more tricky to find. This fixes 99% of these problems.
Dec 22, 2010 | Rinnai Water Heaters
Water temp. at the tap fluctuates
It is likely the inlet filter is plugged. this reduces the flow and then the heater adjusts the burn rate down to protect itself. the filter screens are small and plug easily. It would be a good idea to install a larger pre filter on these heaters.
May 30, 2010 | Bosch 2700ES Natural Gas AquaStar ...
Which circulating pumps works on tankless water heaters
Laing UCT-909-TANKLESS UltraCirc Tankless Water Recirculating Pump
This is designed to maintain the proper flow to fire the heater. Please be sure the pressure in the house is at least 5 psi over the minimum required for your unit.
Apr 03, 2010 | Rheem Tankless Hot Water Heater...
Can this unit be used with a tankless hot water system
Isn't the undersink unit hooked to the cold water pipe? If this is the case, the undersink unit is not affected by the tankless unit!
Mar 01, 2010 | Laing Thermotech Autocirc Undersink...
PowerStar AE125 seems to have failed
You have a blown element. If you purchased the heater, call Bosch for technical assistance, and the unit should be under warranty. The grey matter your getting is the magnesium that the elements have in them.
Nov 12, 2008 | Bosch PowerStar AE125 AE125 Whole House...
Home Logo
203 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
