Question about Microsoft Xbox 360 Console
I want to replace the DVD Rom it does not recognise, Game ,DVD or CD disks .I would like to know how to open the console ,take the older DVD out and replace it with a new one . I also read that the new DVD will need to be Flushed or it will not work. How do you flush an XBOX DVDROM ? Thank you.
  • 767 Answers
Try this,find a tutorial on youtube on how to disassemble your drive
then find out what make /model drive next goto richpsx and
buy the same drive then open the old drive and simply unplug
all the connections from the drives P.C. board and remove it
and plug it in to the new drive , after you remove the new drives
P.C. board.
And that will resolve your problem. with out flashing your drive.
Rob
Posted on May 16, 2010
Testimonial: "Thank you,very helpfull."
    President:
  • 1,382 Answers
Step 1: Replacement XBOX 360 DVD Drive
  • Connect the "Replacement DVD drive" to your pc via SATA connection.
  • Place the dvdrom drive into MODE B with SLAX or the CrossWire Trick (Hitachi 78 and above only support SLAX Method).
Please Note: Once you have the drive in MODE B you will notice it will take 3 presses on the eject button to close the drive.
  • With the drive now in MODE B restart your PC and make sure that the new drive has been identified by Windows. Once the new hardware has been found and installed it will be shown in the my computer/explorer area on your pc as a additional dvd-rom drive.
  • Insert a DVD Movie or an XBOX/XBOX 360 game into the "Replacement Hitachi DVD drive".
  • Open Firmware Toolbox 4.5. Choose 'Tools -> Direct Drive Dump (GDR ONLY). On the next screen choose 'RAW DUMP' and save the file as "original.bin". If you have problems with 'RAW DUMP' try 'CLASSIC DUMP'. example: c:/xbox360/hitachi0046/606HG324240-may2006/original.bin
Make sure you can identify the backup firmware in future by placing it in a directory that matches the serial number which is located on the sticker of the dvdrom drive. This will make it much easier to identify in the future.When the firmware is backed up it will ask you if you want to open it. Choose "yes".
  • Now select "Tools->Spoof Firmware" from the Firmware Toolbox 4.5 menus. Choose the version that you would like the fw to report back as. Leave all other options as they are.
Please note: - Spoofing a drive as itself has the effect of UNSPOOFING it
  • Now Click "APPLY SPOOF"
  • Choose "Tools->Smart Hack Patcher", a window warning will appear, choose OK. Choose the output file name, we suggest calling it "final.bin" and save it at the same location as the original. The ruleset option should be automatically selected for you so leave it alone.
eg. c:/xbox360/hitachi0046/606HG324240-may2006/final.bin
  • Push the "Generate File" button, if everything goes fine the file will be generated almost instantly.Once the file has been generated it will ask you if you want to open it. Choose "Yes".The Main Window will show the generated file (final.bin). You will notice that the spoofed information is shown in bold.
Step2: Flashing the Replacement Drive
  • Choose "Tools->Direct Drive Flash->Differential Flash Patch".Make sure the Hitachi drive you want to flash is selected
  • Click the "Read Drive and Detect Differences" button, after a few seconds the sectors list below the button should be populated.
  • It will now ask you if you would like to keep the keys from the drive.. Choose 'No'.Click the "Start Flashing" button and choose the flash mode.. I suggest using the 0047 flasher for 47 drives etc etc..
  • After a few seconds the flashing is complete.
Thank you!
Posted on May 13, 2010
DVD drive recognised but disc not recognised
not sure how its recognised on control panel
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Apr 05, 2012 | NEC MultiSpin ND-1300A (ND-1300A)...
My Playstation 2 damages CD's. The laser seems to melt the disk, making circular scratches. I don't know if the CD is melted (maybe it's scratched by something else in the CD-ROM/DVD-ROM...
If the PS2 is standing upright, switch it to the laying position. Having it stand upright can sometimes cause the drive to damage disks.
Best, -Mind
Aug 03, 2011 | Sony PlayStation 2 (PS2) Console
WHEN PUT DISK IN IT SAYS OPEN TRAY EVERY TIME YOU PUT A DISK IN TRAY AND CLOSE IT TO PLAY YOU GET OPEN TRAY
take a can of air and blow some into the drive to make sure no dust or dirt is on the laser.
Now try another game and music cd to see if it will ready anything, if it still doesn't read then that means the drive is bad and would need to be replaced with the same type of dvd drive with the same rom version.
Dec 31, 2009 | Microsoft Xbox 360 Console
Cant eject my disc
Dear! It is the fault about belt of a CD/ DVD Rom. You can remove this fault if you can change the belt that is inside the CD/ DVD Rom. And if you want to eject your disk as soon as possible? Use a pin and put inside the very small hole of CD/ DVD Rom and press under your controle slowly. Your disk will open.
Thank you.
Jul 26, 2009 | Sony PlayStation® 3 (80GB) Console
Cd rom recognised as cd audio
They will definately need drivers to be able to give out 100% of the performance.
You definately might have receive a disk while purchased the CD/DVD ROM.
Try that driver once and see the difference.
Jun 03, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
Put cd in then it says open tray wont play cd
Hi. this open tray code is caused by a failed limit switch that is responsible for sending a signal to the optical assembly, confirming that the tray is totally closed and ready to read the disk. this switch is part of the drive and, it is recommended to replace the DVD-ROM drive in this case.
Jun 03, 2009 | Microsoft Xbox 360 Console
It keeps saying there is no disk in the console or it will say system error
1) Lens is dirty
2) Game(s) disc scratched
3)cd/dvd rom broke
4) systems mainboard is broke
(stop if it works after each)
First try a can of air, or a straw and strong lungs to try and clean the dust from the top of the lens of the laser.Then try another game. Then take apart the system, and clean the lens with a q-tip and rubbing alcohol. Replace cd/dvd rom drive, ask google for directions.
Dec 01, 2008 | Video Game Consoles & Games
Samsung dvd writer SH-S162L
try using a cleaning disk or it might have to be opened to be manually cleaned or at worse the laser mechanism will have to be replaced
Oct 11, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
ACER 9410CD/DVD-ROM driver not found.
I am assuming you are using XP,
update the drivers via device manager and select the device with the yellow question mark,right click update,reboot and restart
if nothing then remove the device via add/remove programs
select device and remove,reboot and restart
should auto recognise and install the drivers for you,
dont forget to do SP2 updates
Good luck with that,
Let me know how it goes thanks
Aug 14, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
CD-RW/DVD-ROM wont write to 8x disks
My combo drive is unable to read any files in DVD. Please let me know what should be done.
Combo Drive SM-352F
May 12, 2008 | Samsung SM-352F CD-RW/DVD-ROM (Combo)...
Microsoft Xbox 360 Console Logo
296 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
