Question about Acer EMACHINE 1GB/160 DESKTOP
How do I install Vuze Release [4.4.0.4] on ubuntu. I've down loaded it but can't do anything it seems.
  • 570 Answers
Double click the downloaded icon and follow the steps given and install it
Thanks
Posted on Jun 08, 2010
Bitlord freezing pc
Kinda confused...If you cannot get your PC to boot up, how can Vuze still work? I suggest you boot up into Safe Mode, and uninstall Bit Lord. Then you can contact those folks and ask them why this happened to you.
Aug 26, 2014 | Packard Bell Computers & Internet
I am using ubuntu 10.04.2 and epson lx 300+ printer. When i try to install i am not able to select device as parallel port #1. What should I do?
I don't know I've used Ubuntu for years and I've never had to configure a printer in my life, it allways managed to install it self...
Is your computer connected to the internet when Ubuntu install the driver???
Have you tried an other printer cable??? have you tried the printer in an other computer???
Apr 29, 2011 | Computers & Internet
While installing ubuntu on my emachine d6417 when it gets to copying files it freezes and if i am using windows 7 sometimes in the middle of me doing something or checking emails it cuts off and dumps...
You may have a hard drive problem or a ram problem causing the freezing i would suspect it to be a ram problem if it freezes while loading files from the ubuntu disc as ubuntu loads to ram before installing you can down load and make a boot-able disc from SEAtools to test your hard drive. And some older versions of ubunbtu (9.10 and earlier)had a utility for checking memory (ram) )you may be able to down load this tool from ubuntu forums or google for ram (random access memory )testing utilities that can be run directly from your c/d drive on a bootable disc.
I hope this helps
Andrew A
Mar 28, 2011 | E-Machines D6417 (RBD6417) PC Desktop
I can't load a new OS.
Hey,
ubuntu installation guide is here
https://help.ubuntu.com/community/Installation
Let me know if you need anything else.
Thanks,
Ekse
Feb 15, 2009 | Dell INSPIRON 3500 INTERNAL 56K MDM...
Acer 7720 will not boot
Do you want to try and see if a 'Linux LiveCD' boots? This is the way I test if the computer works. You burn this CD to a disk, and then boot off of it when you're computer starts. I will not modify anything on your computer as long as you go to 'Try Ubuntu with out installing'
http://www.ubuntu.com/getubuntu/download
Don't worry, I'm not trying to get you to install anything, just see if it boots into the 'live environment' (means you are running it off of the cd) If this works, that means that it is only your windows installation is messed up, and a reinstallation of windows should work fine with a Windows install CD NOT the recovery cd.
Jan 31, 2009 | Acer Aspire 7720 Notebook PC
Ubuntu is not starting...
Uninstall Ubuntu and try Ubuntu 32bit version.
Vista sometimes does not get along with other software,or O.S
Jan 30, 2009 | Compaq Presario Notebook
Ubuntu linux compatibility with vista
1.Repartition HD to fit Ubuntu
2. Install Ubuntu
3. Upon starting computer, select operating system (Vista or Ubuntu)
You could also use Wubi which is a program on the ubuntu 8.10 cd that allows you to install Ubuntu right from Vista and it will run just like it's an app per say. Just to warn you though, it will not run as fast and if you are installing this on a laptop it won't be able to hibernate. Also it doesn't require you to create a separate partition to install Ubuntu. This could potentially be a bad thing, depends on how you look at it.
Hope this helps!
Jan 29, 2009 | Compaq Presario Notebook
How to install linux on compaq presario cq40-144tu
hrm... i'll just assume that this is the first time you've attempted anything with linux? There are vairous Linux distributions, with the Ubuntu flavour seeming to be the best one for the windows to linux switcher (IMO). I would try a live Ubuntu disc first to make sure it's what you're after, which can be downloaded here
http://releases.ubuntu.com/intrepid/ubuntu-8.10-desktop-i386.iso
or if you're ready to dive straight in, here is the full version that you burn to a cd and then install
Nov 29, 2008 | Toshiba Satellite P15-S470 (PSP10U-0GGPGR)...
Ubuntu sound problem
Hi Josh
First of all check system setting.
It seems like your modules are not loaded, if you just installed, I recommend you to
re-install Ubuntu, if this is not the case, try to run -
sudo apt-get -f install
If everything fails, try this - sudo /etc/init.d/alsa-utils start
Jul 29, 2008 | Canonical Ltd. Ubuntu
Acer EMACHINE 1GB/160 DESKTOP  Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
