Question about True Refrigerators
Sandwich bar Hi, I bought a true refrig. sand bar from a commercial kitchen store. It is so loud, I hate it. I know that it is not made for residentail but can we get some part replacement to make it quieter. It's outta control. I do leave room for it to breathe behind the unit.
I had a similar problem, & found out that what was making the noise is the cardboard siding on the condensor(bottom of the cooler) I placed a "shim" between the cardboar and that took care of the noise.
Posted on Mar 09, 2009
SOURCE:
How to adjust the temp on a true sandwich bar It's running to cold?
Sounds like someone needs to change out the thermostat control on your model. What is the model and serial numbers?
APPLIANCE 911
Dec 03, 2016 | True Refrigerators
What can i get wiring diagram for TPP-67 pizza table?
TRUE TPP-67 SPECIFICATIONS Pdf Download. - ManualsLib
www.manualslib.com > ... > True Manuals > Kitchen Appliance > TPP-67
True TPP-67 Food Prep Tables: Specifications. TPP-67 ... TPP-67. Solid Door Refrigerator. TPP-67. True's pizza prep tables are ... Heavy duty PVC coated wire.
Aug 06, 2014 | True TPP-67 Commercial Refrigerator
Where to buy mabe gas stove burner parts
Not sure what area you live in but check the yellow pages under restaurants/ equipment repair. You will find a local repair company that will sell parts and should be able to help you repair it as well.
Jun 24, 2014 | Blodgett Kitchen Ranges
Are kitchen bar stools any different from commercial (pubs/bars) bar stools?
Essentially, there is no difference in the function of the stool; however the height varies slightly. Kitchen bar stools are 23-28 inches from floor to seat whereas commercial bar stools measure 29-32 inches.
Jul 24, 2012 | Furniture
Compressor vibrates and unit only cools to 20 degrees. tech says it "may" be compressor pressure valve ($1800.00) but no warranty. I cant find any such part listed for True T49-F commercial...
Okay first True uses capillary tube not an expansion valve.
You say the compressor vibrates not cooling ?
If the valves of the compressor are bad, he may mean
internal valves but usually pressures would not be good.
Give a little more detail please.
Apr 26, 2011 | True 49 cu. ft. / 1388 liter Commercial...
We just bought a used True GDM26 that works but it is too noisy
NONE. This is a common complaint from customers who buy commercial units for use in residential atmosphere or quiet stores. These units are made for noisy commercial kitchens, convienience stores, etc.
May 19, 2010 | True GDM-26 Refrigerator
Compressor has been replaced,power wired correctly,compressor is very loud rattling and shutting itself down in a matter of 60 seconds run time. Not able to put full charge to it.
residential unit or commercial. commercial three phase sounds like a scroll comp running backwards. residential sounds like defective compressor, whats the ampdraw is the capacitor good how much refrig in the unit
Jun 05, 2009 | Heating & Cooling
Commercial Freezers
I have worked in a lot of kitchens and don't really have a preferance. The top mounted compressor is better for you as it is easier to service and leaves more cabinet room. Dirt and dust also stay near the floor. YOu won't have to clean the filter as often up high The disadvantage to this in a kitchen is that kitchens are hot and up high is hotter still. Order a cheaper model. No glass doors, no stainless steel. You don't need these features.
Jun 24, 2008 | Traulsen 7 cu. ft. / 198 liter Commercial...
True T-49 side by side is noisey
is unit cooling? if not suspect a deficient compressor. if it likes makes a rattling noise really loud suspect compressor wear hope it can help.
Apr 18, 2008 | True T-49 Side by Side Refrigerator...
Refrigerators Logo
123 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
Joe Palazola
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
