Question about Maytag Performa PAV2200
Where is the tumbler belt located on a Matag Performa Dryer model # PYE2300AYW?
  • Maytag Master
  • 12,061 Answers
Www.servicematters.com/maytag_library/docs/16023083.pdf
service and repair manual above, everything is in there.
Posted on May 13, 2010
Not sure of year but i have a Maytag Performa, Model #PYE2300AYW and serial # 107-861-51YY..It wont do anything when I press the button to start the dryer it doesnt click anymore. I think it could be some...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 28, 2011 | Dryers
My Maytag Performa electric dryer will not start. The Model # is PYE2300AYW, Serial # 10923714ZB. It was working fine but will not turn on now. I have checked the breaker box and it is in the on...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 16, 2011 | Maytag Dryers
Dryer stopped running with 30 minutes left and will not restart. Maytag Performa PYE2300AYW
Reset the circuit breaker for the dryer. Allow the motor to cool, It has over temperature protection that will shut down the motor.
The belt that turns the drum may have broken. I am not sure about this model, but most dryers have a limit switch on the base of the dryer next to the motor that shuts down the dryer when the belt brakes.
Dec 15, 2009 | Washing Machines
My maytag dryer heating element gets hot but motor will not run
Sounds like you have something shorted out.
The element issue could be a contact fused shut.
With both problems I would be looking for wires melted together, or a relay/sequencer welded shut melted etc.
You do have a potential fire hazzard here. If after removing the panel you cannot locate the problem, do not run the unit.
Oct 20, 2009 | Maytag PYE2300AY Electric Dryer
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
Need belt diagram for Performa PDET920AYW dryer
Flat side of the belt goes agaist the drum. The diagram is on the new belt
Aug 08, 2009 | Maytag PYE2300AY Electric Dryer
My maytag performa pye2300ayw dryer will start but will not heat up. No matter how long I leave it on, it just won't heat up. what could be the source of the problem? the model number - pye2300ayw rev - 10...
You have a thermal overload switch that may be bad. It is located under the top of the dryer. Check first the breakers. Turn them off and then back on, then check the wiring in the back of the dryer and then the element itself. It may take 30 minutes to do all of this, but it will save you a lot in the long run.
Mar 04, 2009 | Maytag Dryers
No power to dryer was working fine no warning would not start
Most likely a bad fuse. There is one above the heat element, also may have one on the blower housing. Test with an ohmmeter or bypass. Hope this helps!
Feb 16, 2009 | Maytag PYE2300AY Electric Dryer
Washing Machines Logo
219 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
