Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Water hammer makes a loud vibrating noise when filling
The noise has got worse over time. It seems as though its probably water hammer where the water goes into the machine at the valve.
  • 189 Answers
Hey- most hammer is removed by simply replacing the water valve. Have solved this way many times. Exceptions required spring suppressors on lines to faucets. Valves run about 40-60$ and are easy to install. Let me know if this info helps- have more if needed- Thanks- Ed
Posted on May 13, 2010
Loud banging noise when filling
Most likely a water hammer noise in your water pipes. Probably not your washer. Google water hammer.
Mar 10, 2015 | LG Washing Machines
Loud hammering noise with vibration on piper when the cistern fil
You're experiencing "water hammering" it's solvable too.
You can buy anti-hammer add-ons which you can put under a nearby sink, or even on an outside hose bib. This will give the water pipes an air "shock absorber"... since air compresses it cushions the abrupt changes in the pressure where as if it's just water, it'll slam and hammer and vibrate...
Try an anti hammer device added to you supply... you should be able to add it with out too much tearout.
K
Jun 18, 2009 | Caroma 270W-RF Reflection Round Front...
When tap or cistern is filling loud noise from pipes
This could be one of two issues.
1. You may have high water pressure, causing the internals of the fill valve to vibrate and that vibration wave being transferred to your water pipes causing a reverberation noise called hammering.
An easy fix for this would be to reduce the flow to the fill assy. by turning down the units supply valve from wide open to about half way open. A few more permanent solutions may include, The installation of a Water hammer damper device - installation of a PRV pressure reducing valve - Although not intended for this issue is an air charged bladder style expansion tank installed, this device has been proven to reduce water hammering.
2. Water pipes that are not properly secured, loose and allowed to shake when there is a sudden surge of flow pressure. Much like a garden hose flexes when the nozzle is quickly turned on. This issue is most common with CPVC (plastic) water lines due to their flexibility and will require many more secure points.
A fix for this is a bit more labor intensive, due to having to access the un-exposed water lines in walls and ceilings so as to inspect and/or re-secure them to their surrounding structures.
A tip for securing the pipes where they penetrate through wall studs is to inject an expanding foam product in to the studs penetration, hence when the foam expands and cures it will form a very snug fit.
Note: if ether of these are the case, the problem should not be allowed to continue, because water pipe leaks could occur at the solder or welded connections and/or at locations where the pipes are rubbing against an abrasive surfaces causing a rupture.
Good luck
Aduz
Mar 27, 2009 | Caroma 270W-RF Reflection Round Front...
My r85 rinnai water heater vibrates significantly and makes
Sounds like there is something loose in the line.Like cut off valve,check valve.
Mar 09, 2009 | Rinnai Digital Remote Water Heater Control...
Thundering noise coming from hot taps,bath,sink taps...
Sounds to me like you need to have a water hammer device installed into your plumbing, I have only run across this just once before, the noise is very loud and very bothersome, you will need to contact a plumber and have him install a water hammer device into your system, also vibration dampers would probably help as well, if your water lines are running through floor joists and touching them, hope that helps
Jan 18, 2009 | Bosch Exxcel KSR34423 Refrigerator
Clunking noise in sink
You are describing a problem known as water hammer. This will ultimately cause damage somewhere in your plumbing system so it should be addressed. If you are handy you can install an air chamber near the sink. If you want more information let me know. good luck.
Jan 17, 2009 | Home
Water supply line vibrates making very loud noise.
these vibration in water pipes or cooper lines come from air in thewater supply system..dont take your appliances apart...
Dec 26, 2008 | Kenmore Elite 45986 Front Load Washer
Loud noise
The vibrating sound you hear could be due to "water hammer" when the fill valve tries to close against high water line pressure. I had that problem and solved it by putting a small valve in the line to the ice maker and closing it little by little until the vibrating went away. You know, the banging could also be water hammer. It only happens at night when the entire neighborhood is asleep and the water pressure is at its highest. You need to check this out because water hammer can be very destructive to the plumbing and the valve.
Tom
Sep 08, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Kenmore 90 Series Washer Noise--Won't spin
For Tegres
If the noise is only when there is water flowing, check tighten the screws that mount the water fill solenoid valves to the case. The solenoids operate on line current so they vibrate at 60/50Hz (local suppply frequency) if they are loose at all, the noise is loud the body acts as resonators
For SRONEAL, that symptom describes coupling failure exactly, have you removed the coupling to check, often times the motor side hub is stripped, but there is no visible external damage
Jul 23, 2008 | Kenmore 15864/15862 Top Load Washer
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
364 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
