Question about Averatec 3200 Notebook
I am having problem loading operating ysyem
When i am powering on my laptop it is showing a error message as follows : error loading operating ysyem
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 121 Answers
This is the problem if the system files have gone corrupt. you will have to do system recovery on the computer. recovery is the process of reloading the operating system with the recovery discs. by from the number given 678-715-3329. give the information they need of your computer and they will ship you the right set of recovery cd. put the first cd inside and shut the computer off then restart the computer and follow to put the rest cd as the instruction comes on the screen.
Posted on May 13, 2010
Always restart after loading OS . thus this a problem with power ?
The chances are very less. Does it show any error messages..like "Boot loader missing"..then you should reinstall the operating system.
else download a boot mode antivirus software and scan your computer with it. use this link to dowload :
Mar 25, 2014 | Toshiba Computers & Internet
Error 08-0E89-0000 satellite p205-s6237
Your operating system is crash thats why it is not able to load the operating system. If it is showing RAW FILE SYSTEM then you have to reinstall operating system.
Aug 02, 2012 | Toshiba Satellite P205-S6237 Notebook
"error loading operating system" message on dell inspiron 1420 laptop
only way to bypass this is use a recovery disk to boot from and then perhaps the issue will manifest itself
otherwise, it's the dreaded re format step
May 22, 2012 | Dell Computers & Internet
My computer wont boot up the fan and light turn on for a second then goes right off....
With the little bit of information presented, it appears that this is possible a power supply problem. One thing you can try is to unplug the power adapter from the laptop, remove the battery, then plug the power adapter back into the laptop. Then try to turn it on. If everything comes up normally, then the problem points, potentially, to the battery.
Hope this helps!
Feb 18, 2010 | HP Pavilion dv9000z Notebook
C640 can't boot up
Ok.Better reinstall the os.Because disk boot error cannot be solved is suppose...To install the os follow these steps.
Step 1:Power on your system and press DEL key
You will see a blue screen with some options on it in white. (you can only use your keyboard to navigate in this screen). Go to the Advanced Setup Options ---> then select Boot Priority ---> 1st Boot device to be Floppy drive , 2nd Boot device to be CD-Rom drive
Step 2:Insert the Bootable DOS floppy in your Floppy Drive. Press F10 to save the bios settings and exit. (Your system will re-start automatically)
Step 3: Let the Dos load from the floppy and A: shows up.
Step 4: Change the Command prompt to HDD Drive letter, it will be D: or E in which u have Xp cd contenet.And type If xp content in d:under x folder mean.D:cd\x and press enter.
Step 5: now type on the D:\ prompt -- setup.exe and press enter
Step 6: follow the prompts there after. and for more info contact http://tinyurl.com/m7ghqz
Jun 19, 2009 | Dell Latitude C640 Notebook
My printer dont want to print
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
Apr 12, 2009 | Lexmark X5470 All-In-One InkJet Printer
I WANNA INSTALL XP2 BUT MY SYSTEM SHOWS ERROR: C000022UNKNOWN HARD ERRORSYSTEMROOTSYSTEM32NTDLL.DLL
  1. This problem may occur if the file that is described in the error message is corrupted. The following files are checked for integrity when Microsoft Windows XP starts:
  2. All driver files (except those that are loaded by the system loader to start. the computer)
  3. All dynamic-link libraries (DLLs), including User, Graphics Device Interface (GDI), Shell, Kernel, Ntdll, Crtdll, and others.
  4. This problem may occur if you install an inappropriate driver for your hardware. For example, you receive one of the error messages that are described in the "Summary" section if you install a MIPS driver on an X86-based computer.
    This problem may occur if an Iomega Zip drive is on the same integrated device electronics (IDE) cable as the hard disk drive.
  5. To resolve this problem, obtain a new copy of the corrupted file or reinstall Windows XP. If you continue to receive any one of the error messages that are described in the "Summary" section after you reinstall Windows XP, a hardware problem or a network problem may exist.
  6. This error message may be displayed in many different formats, including an error message that is displayed on a blue screen or an error message that is displayed in a dialog box. The type of format that the error message is displayed in depends on how much of the operating system was loaded when the corrupted file was detected.
Apr 11, 2009 | Microsoft Windows Vista Ultimate Edition
On my lap top i receive message-"error loading operating system"
Trying booting into safe mode by pressing F8 while the computer is booting up.
Choose safe mode with the arrow keys and see if it boots that way.
Mar 20, 2009 | HP Compaq nx9030 Notebook
Laptop wont start up
THE PROBLEM IS WITH THE BOOT LOADER ... REINSTALLING THE OPERATING SYSTEM WILL DO ... REPLY IF YOU WANT ASSISTANCE WITH THAT ...
Sep 14, 2008 | Computers & Internet
Error E3 on Mitsubishi HS-U795
Try this :
If your VCR malfunctions, try the following steps prior to contacting your Mitsubishi Dealer:
1 Check the Trouble Checks below to see if there is a solution to the current problem that you are
experiencing.
2 If the problem is not addressed on the Trouble Checks, the safety circuits in the VCR may be in
operation, thus please try the following: (the clock setting and the timer recording will be deleted.)
1 If possible, press EJECT on the front panel and remove the tape.
2 Press TIMER RESET on the rear panel with a pencil or a ball point pen.
3 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, wait about 1 minute
until the tape protecting function is completed, then press POWER.
3 You may also try the following procedure if the above steps did not resolve the problem (All settings will
be reset to the default settings.).
1 Press POWER on the front panel continuously for about 8 seconds until the current time display on
the front panel shows "- : - -."
2 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, the tape protecting
function will work and "99" will appear on the front panel display to begin count down. Wait about 1
minute until it reaches "00" to show the tape protecting function is completed, then press POWER.
If the problem with your VCR persists, contact your Mitsubishi dealer for assistance.
Im looking for error codes.
Mar 10, 2008 | Televison & Video
Averatec 3200 Notebook Logo
88 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
