Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Chevorlet silverado 1995 4x4 1500 problem: when starting it just clicks and then sometimes it will start. bought new battery,still wont start, bought new starter and everything worked fine for just over a month then same problem. returned starter for new one and it worked for about amonth and a half now it doesnt!, just click click click click......... ahhhhhh............. any ideas???
  • jamiepierott May 15, 2010
    thanks for the info and yes the service engine light comes on here and there recently. what does this mean??
    Problem Solver:
  • 7 Answers
Sounds like a wiring problem. Have it diagnosed on a computer at a local dealership or someone you know that wont charge to see whats wrong! Then go from there. Are u getting a check engine light?
Posted on May 14, 2010
My2002 sierra with a4.8 with a good battery, all my dash lights and cd player come on but the truck doesnt turn over right away sometimes it takes 5-10 minutes 2 start of repetitively turning key over
battrey is good but truck makes no sound and wont even click
www.cargurus.com > Questions > Chevrolet > S-10
CarGurusbattrey is good but truck makes no sound and wont even click ... Asked by Jennifer May 15, 2013 at 03:21 PM about the 2002 ... quite obviously the amps aren't getting through~ how do you know the battery is "good". the date ... If it turns over your power and starter are good but the ignition circuit ... Used GMC Sierra 1500".Missing: a4
Intermittant Failure to Start : Chevrolet Silverado 1500 ...
repairpal.com > Problems > Chevrolet > Silverado 1500
first start engine turns over alot. 2000 Chevrolet Silverado 1500. Hard start. When starting my truck it often takes two or three attempts. It kicks over but does not ...Missing: a4
Chevy Silverado and GMC Sierra Starting Problems - Car Forums at ...
forums.edmunds.com > Chevrolet > Chevrolet Silverado 1500
Oct 20, 2008 - 30 posts - ‎19 authors
i got a 2001 silverado 1500 and it wont start it turns over and fires and .... Put the key in and the truck barely starts due to the battery being weak. .... If it was really 8, the lights would be dim? .... I have a 2002 GMC Sierra 4.3L 2WD. ... I bled the fuel filter looking for air, but good fuel came out the top bleede ...Missing: a4
Jan 01, 2016 | 2002 GMC Sierra 1500
I bought a new battery for my 97 chevy silverado and now it wont start
battery fuse maybe you need new positive and negatives wires make sure ist grounded
Sep 10, 2012 | Chevrolet Silverado 1500 Cars & Trucks
My 2000 silverado wont start sometime when hot wait 10 to 15 min to start
What fault codes do you have if any? What is the ECT sensor reading hot?
May 25, 2012 | 2000 Chevrolet Silverado
1999 chevy silverado 2500.6.0 l.if truck sits all week sometimes it rolls over slow and wont start.sometimes it will start.new battery starter and alternator is good.if truck does roll slow then starts...
2 things come to mind, first check and clean all battery and starter connections. second, maybe you have something draining the battery. next time it rolls slow, put on a battery charger and see what happens. also, even though it is a new battery, it still could have a weak cell.
Oct 30, 2010 | 1999 Chevrolet Silverado 2500
Wont turn over intermittent. new battery, new starter relay, lights and gauges always ok. Sometimes starts first try, sometimes many tries.
Check battery to body and battery to motor ground bolts for corrosion. Also check motor to frame ground strap for corossion. Bad ground can cause all kinds of electrical problems.
Sep 07, 2010 | 2001 Chevrolet Silverado 2500HD
Wont start
you obviously , have a drain in the system, could be a simple as the glove box light staying on, otherwise, run you car down to the mechanics and ask him just to check your alternator is working, he shouldn't charge you to do that. all the best and good luck
Jun 01, 2010 | 1988 Chevrolet Silverado 2500
My 1994 chevorlet lumina apv-3.1 motor: when you
when you say car lost power bought a new battery.sound like alternator not charging battery.with car running your voltage at battery should be 13.5 volts or 14.5 volts it not alternators need replacing.have garage replace alternator if faulty because 1993 to 1994 cars if you disconnect battery car would lose memory causing car not to idle.the car will stall out at a stop light or stop sign whole lot.it would relearn itself but the stalling out dangerous around a lot of traffic.
Nov 26, 2009 | 1994 Chevrolet Lumina APV
88 Ford Aerostar clicks and wont start
Check the starter solenoid next to the battery. Sometimes it will not energize and just click.
Jan 23, 2009 | 1988 Ford Aerostar
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
680 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
