Question about Cobra microTALK LI 7200-2 WX VP Two Way Radio
Everthing on the radios work but there is no sound from the speaker.The RX shows on the display and the the vibrate work when called. Whats up?
    Scholar:
  • 157 Answers
#1 bad speaker, #2 external speaker jack bad/shorted, #3 volume control bad/open, #4 squelch control bad, & #5 is it both radios no audio?
Posted on May 14, 2010
Permanent RX on Binatone 750
RX simply shows it's in receive mode, to check that the speaker is not faulty plug in an earpiece, if that is clear then you know the speaker needs replacing. Chris B-R
Nov 09, 2013 | Binatone Terrain 750 Twin - Black
On incoming calls i get vibration sound only i have tryed everthing
Your phone software is damage or speaker is damage. Please visit samsung
Jan 30, 2011 | Samsung SGH-D500 Cellular Phone
I have two uniden GMR1088-2CK radios, If I press the transmit button on the side and speak into the Mike you can see tx appear in the display, the 2nd unit receives the call, rx appears in the display and...
What this code indicate mean that your radio have have been compress with power however the can also be an indication of lower power supply but most of the time is always power compress.
What you need to do to solve this code problem is to put off the radio for some time allow it relax, then remove the battery if possible after some time replace it if you are able to remove the battery then put on the radio and operate it.
Good luck.
Jan 15, 2011 | Radio Communications
The Yamaha Reciever RX-V465 is connected to my digital TV by fibre optic cabel. I have sound when I connect my MP3 to the V-Aux and the speakers are displayed on the display window of the Reciever same as...
Please check your TV settings and the optical cable.
The speaker icons disapper from LCD display when the receiver does not detect any input signal throught the optical/coax/hdmi cable.
Dec 13, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Yamaha RX V 657 - No Sound Output, and No input detection
Bad DSP chip. The only other possibility is if you have the "Direct" on. On the front of the receiver it's a small button. Also make sure your "Speaker Select" A/B is "on" You will see it on the display, it's also a small button on the front of the receiver. If all this is correct and you still have no audio, it's a bad DSP chip. Not worth repair, it's 400-500 repair. Not very common in a Yamaha RX-V series, but I have seen it. I'm a Yamaha Dealer. If you need further help, post a comment and I will be glad to help you further.
Aug 23, 2009 | Yamaha RX-V663 Receiver
Harley Radio and display is on but stuck with no sound or functn.
Software locked up. Iron Cross Audio may be able to clear it. (www.ironcrossaudio.com)
Aug 17, 2009 | Harley Davidson 426290 AM/FM Radio
RX-V1600 when i turn on no sound or channels display on
If you are sure that the speaker wiring is correct and connections are good, then:
  • Check the input and output connections are correct for each source.
  • Check that the input mode is not set to DTS or Analog - rotate the input selector to the source and the press the input mode, set it to Auto.
  • Also check that the front speakers to be used are selected A or B (or A+B).
  • If there is an optimiser microphone supplied with this receiver, ensure that it is not still plugged in.
Hope one of these solutions work for you.
Jul 19, 2009 | Yamaha RX-V1800
Center Console Display Not Working
Changed the battery yesturday in my Mazda rx-8. Now my radio/CD and my A/C won't work! It's all black! Wot to do???
Jan 28, 2009 | 2004 Mazda RX-8
Only one walkie talkie produces sound
Check for Squelch Codes you can see on the display channel number and sub chanel number this is the squelch code
Both displays must show the same icons
If both are the same, try with and audio accesorie, if works may be your speaker is broken.
Dec 23, 2008 | Bell BE1400FRS (14 Channels) 2-Way Radio
No display info on receiver
Try plugging a video monitor AKA your TV into that monitor output connector on the rear of the yamaha.
Select video in on the TV and see if anything shows up from the yamaha
Sounds though like the receiver has serious issues. If you can get your moeny back , do so
Feb 24, 2008 | Yamaha RX-V661 Receiver
Cobra microTALK LI 7200-2 WX VP  Two Way Radio Logo
403 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
