Question about Zebra 203DPI Printer
Hey, I m with zm400 printer. In printer control panel printer is ready.when we give print, label not come from printer.when we use feed button the label come one by one and some times not come from d printer. we clean platten roller, sensor.but problem persist.please give me advice
jigeo
  • 57 Answers
SOURCE: Zebra 2844 Not printing at all
Antztech,
if the red light is coming on and staying on, it might be a sensor problem. Try pushing on the lid and see if the light goes to green. If it does, it' s the gap sensor. This is how the printer "reads" the labels gaps-the little spaces between the labels. We've solve this in the short term by covering the sensor and manually setting the gap through the programming command prompt,
Posted on Apr 19, 2008
Ajkill
  • 2035 Answers
SOURCE: label sheets won't feed, jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
good luck..
Posted on Dec 22, 2008
jwr1914
  • 31 Answers
SOURCE: Zebra 105SL label issues
I am surprised that you are using that sequence of buttons to solve this problem. I am pretty sure that they want you to go into the "Media Sensor Calibration" setup in the config menu. It is a bit more complicated than what you have described. I also believe that the size of the gap on two of your labels might be out of tolerance (they are usually 1/8" gaps between the labels). The black marks are a problem for the transmissive sensors. You may need to move the transmissive media gap sensor (remember it has two parts: upper and lower). I would usually setup mine for a place beyond the black mark so that you are looking at just the white paper.
To start out:
1. Load the backing of a 6" strip of media (no label attached).
2. Remove a ribbon (if you usually use one).
3. Close the printhead.
4. Press SETUP/EXIT and then NEXT/SAVE until "Media and Ribbon Calibrate" appears.
5. Press "+" to start the calibration procedure. You should see the "Load Backing" in the LCD Display. You already have the backing loaded so continue to the next step.
6. Press "+" to answer the message and the next screen should say, "Remove Ribbon". You have also removed the ribbon.
7. Press the "+" to continue. You should see the screen say, "Calibrating Please Wait". After the sensors are setup by the machine a new screen should appear, "Reload All".
8. Open the printhead, and move the labels until they are loaded correctly to print. Smooth out the ribbon and load it correctly.
9. Withe media and ribbon now loaded, press "+" to continue and the machine should say, "Media and Ribbon Calibrate".
10. Press the Setup/Exit button once. It should say, "Save Changes Permanent". Press Next/Save to finish the process.
11. Do a normal calibration of your stock and print a label.
You are done. The machine will run for the labels you have setup the sensors for. Unfortunately, you must do this for each of the media types. To automate this, you could run a Configuration listing, capture the settings you just created for each type of label. Take these to a programmer to have them send the setup to the machine before the job. This is beyond the scope of this type support to really help you.
Posted on May 29, 2009
komguy
  • 2306 Answers
SOURCE: Tape on Brother PT-65 wraps on roller
If the end is already messed up you may need a new cartridge, if you can remove the tape and feed the end under the guide on the cartridge and re-install it should work properly again.
Posted on Sep 17, 2009
  • 7 Answers
SOURCE: zebra zm400
check the size of the document and the Zebra Fonts;
Install Zebra font if not install and its resolv
Posted on Oct 06, 2009
Zebra ZM400 drops interface on port 515
make sure you have no network traffic for your printer and decrease the printing speed, and make sure you are using a free port not a used and default port for the service..
Jul 20, 2014 | Zebra ZM400 Thermal Label Printer -...
Printer ready, Feed option does not working. Other power supply settings printer working properly.
the problem may be in the control panel button itself. the feed button aways works, no adjustments necessary. It's main purpose is to advance the labels.
Jun 27, 2014 | Zebra ZM400 PRINTERS 4 Inch DT/TT 300DPI...
Z4MPLUS doesn't recognize the MEDIA(LABEL) automatically.
you should recalibt=rate the printer.
Are you sure that your previous label was not longer?
With the autocalibrate function activated the printer should try to detect the correct length. If it doesn't the yoou have
- A problem with the label border
- Preprinted stuff which the printer detects as to fo feed
Dec 09, 2013 | Zebra Z4Mplus Label Printer
Zm400 feed
Please uninstall the printer driver and reinstall it again
Nov 04, 2013 | Office Equipment & Supplies
The print out of ZM400 misalign to the left. How to make it back to the centre of the label?
Printing from an Internet Browser can cause this result if you have not set the margins, footers, and headers.
File ' Page Setup
Change all margins to 0.01 (or as close as possible, it may override you) and all SIX bars below that to Blank or Empty.
Apr 10, 2013 | Zebra ZM400 Thermal Label Printer -...
Have A Zebra Z6M Plus 300dpi printer Z6M00-2006-0000, then purchased a Zebra ZM400 300dpi printer, attempting to print using formats from Z6Mplus, result is a print approx 150 % larger ??? Downloaded...
Print configuration from both printers and compare. Print config- Hold cancel button 10 sec. while power on. Check Resolution parameter. 203dpi=8MM Full , 300dpi=12MM Full. Sounds like perhaps they are different dpi.
Apr 03, 2011 | Zebra ZM400 Thermal Label Printer -...
Zm400 print a part of a label. Hello, my Zebra ZM400 only print 1/5 last part ot the barcode label. Could you please tell me how to fix it?
What part, rigth site or bottom site?
check the lengt and the with from the driver and print the testpage (have to print on full label)
if is one of the sides, try to give more pressure to that side on the printhead.
Nov 17, 2010 | Zebra 203DPI Printer
How to load new labels
http://www.scanonline.com/Online-Store/ZM400-600
Download the ZM400/600 Quick Reference Guide on the right hand side of the page. They have a diagram on how to load labels.
There should also be one inside the printer - printed on the back wall...
Jul 10, 2009 | Zebra ZM400 Direct Thermal-Thermal...
I can't print label from ZM400 PRINTER thru' serial port
There are a number of parameters for the serial port that have to match the pc. i would print out a config page from the printer via the menu, or power on with the cancel key held. then compare it with the settings on the pc. on the config page you should be looking for things like data bits, host control, parity etc.
Jan 19, 2009 | Zebra 170XiIIIPlus Thermal Label Printer
Zebra LP 2844 prints blanks
If the printer is printing nothing but blanks, try another roll of labels.
If the printer is printing blanks in between labels, it probably needs to be gap sensed. You can do this by:
1. turn the printer off.
2. hold the feed button down and then power the printer back on while still holding the feed button down.
3. release the feed button when the light flashes.
4. the printer will then regap itself
5. when the regapping is done, press the feed button once. It will print on the label that it is 'out of dump'
6. the printer should then be ready to go.
May 03, 2008 | Zebra LP 2844 Thermal Printer
Zebra 203DPI Printer Logo
85 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
