Question about Dell Powered Subwoofer Set A425 Computer Speaker Set W8037
My subwoofer and speakers wont draw power when i plug it in, could it be the fuse or something else?
  • 23 Answers
The Altec Lansing A425 doesn't appear to have a fuse. Check for a circuit breaker on any surge protectors it might be plugged in to and make sure they haven't been tripped. Confirm that the power cord is firmly plugged in. Additionally, you could check the wall transformer with a multimeter to make sure it is providing the correct voltage needed by the speakers. Check the back of the subwoofer for a hidden power switch. If everything is plugged in and turned on, but you still don't have power, you will either need to open the device up and troubleshoot it or replace it.
Posted on May 13, 2010
Where is fuse in velodyne dps-12
Just a guess, but the drawing in the manual shows a fuse rating of 2 amps where the power cord enters the box. Is this a combination fuse/connector. Have you looked if the rocker switch accommodates a fuse? Sorry if no help.
Nov 28, 2013 | Velodyne DPS-12 Subwoofer
KLH ASW8 Powered subwoofer keeps blowing 3A-250V fuses
The transistors at the output stage of the sub amplifier circuit might be shorted so each time you power on, the circuit draws a very high amount of current which causes the fuse to blow. It's definitely a problem with the circuit so using a higher current rated fuse would probably just result in damaging the amp even more. You should ask a qualified electronics technician to take a look at it. I hope you can fix it.
Oct 17, 2012 | KLH ASW8100 Subwoofer
I have no green power light on my subsonic 5i which screws do i remove to replace a fuse inside
Make sure you the plug eorks before you do anything. Plug in a lamp or something. The fuse is inside where you plug the input.
Sep 01, 2010 | PSB Alpha Sub Zero Subwoofer
The fuse keep burning
Somethings shorted inside. Could be the output IC or transistor, diod in power supply, power transformer. Somebody will have to open it up to find out.
It could be a cheap fix like a couple $4 transistors or it could be expensive, like a
Apr 17, 2010 | Cerwin Vega V-10S Subwoofer
Can I plug 5pc home theater speakers directly into pc tower or will I fry something? The speakers (made by LG) R from an old Sanyo DVD/VCR/Audio Home Theater System which no longer works. Home Theater...
Attaching speakers to an under-powered amp won't DRAW too much power. And we're not talking about an amp here, we're talking about a PC which can
only provide enough juice for headphones. All it provides is Line Level (millivolts) output for an external amp to process.
The speakers are NOT self amplified. If they were they'd have batteries or wall power cords and RCA style input connectors.
What you will need is a replacement for the dead Sanyo electronics that can handle 4-ohm speaker loads. Then you can draw the output of your soundcard into IT with RCA cables..
Mar 19, 2010 | Audio Players & Recorders
Their is power in the fuse and in the power line but unit wont start is their an internal fuse or am i missing something
Hello paul543,
First check all the fuses. The primary and any onboard fuses.
Then, in addition to the power wire, check the ground and make sure that there is +12V on the remote turn-on terminal when the head unit is turned on.
Hope this helps
May 01, 2009 | Car Audio & Video
Fuse on subwoofer keeps blowing
Subwoofers draw a tremendous amount of power. With the amount of heat generated by amperage flow and the movement of the voice coil, you may have burned out the coil. Do a resistance check across the coil. Easy check? Temporarily attach another speaker to replace that one. Use LOW VOLUME and slowly work the vol up,and, if the fuse does not blow, it's the other speaker.
Mar 10, 2009 | Dahlquist ORBIT 5.1A System
Klipsch ksw subwoofer wont power on
The power supply switching transistors are likely fried. Dangerous high voltages involved. I would remove the plate and send it to Klipsch for repair.
Jan 16, 2009 | Gem Sound SUB-650M Speaker
No power
Just call JBL parts.  They'll mail them to you.  Around $2 per fuse (two per speaker)
Jan 03, 2009 | EON JBL EON10 G2 Main / Stereo Speaker
214 people viewed this question
Top Dell Audio Players & Recorders Experts
dochubert
dochubert
Level 1 Expert
Rick Davis
Rick Davis
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
