Question about Compaq Presario Notebook
Time troubles hi, my gateway mx 6960 laptop has a time problem. Sometimes, when I turn it on , the clock shows 12:00 am, july 1, 2005. whats wrong?!?!?!?
  • kedar1jgd Aug 25, 2008
    changing cmos
  • 655 Answers
Your BIOS battery might be down. Becoz your board clock needs power from the board battery. So changing the battery on board will fix your problem.
Thanks
Iqbal
Posted on Mar 29, 2008
My printer HP6960 will print word documents, but when I try to print pdf's the 6960 is not one of the optional printers. What do I need to do to configure adobe on my computer??
Make sure your 6960 is set as default printer.
sometimes when you want to print PDF it will ask if you want to print as word document, try that as well.
can you right click on PDF to select printer?
Last look at Adobe properties notice if in Setup for Adobe allows you to select default printer.
Sep 30, 2016 | PRINTER Office Equipment & Supplies
Led lights will not come on on my Gateway MD2614u
You should buy a new battery for your computer. Sometimes battery's
get too old.
Apr 13, 2013 | Gateway MD2614u Notebook
Inspiron laptop clock occasionally reverts to July 2008
There is a small 3 volt battery on the motherboard which is the backup for the circuit clock .So if the battery has gone low in voltage the clock will be reset as the CMOS setting will be reset. The clock will then go back to the time of the laptop set-up which is in july 2008.
Replacing and then correcting the CMOS set- up on booting will set the clock to work to the current time/date.
Sep 16, 2011 | Dell Computers & Internet
All usb ports on my gateway laptop aren't working... I've reinstalled the drivers several time, still no progress there... checked system BIOS all settings are correct, dont kno what else to do
http://support.gateway.com/s/Manuals/Mobile/8510913.pdf
this shows the user guide But I did not see anything for USB specific trouble shooting.
Other wierd things I have sceen...check ALL USB ports to make sure that they are not broken or have something stuck in them and are shorting out, can cause a MB functions to expire. Try a lighted item in the ports, is the say USB mouse lighting up? If so then this is a software issiue.
Turn off all usb functions and try rebooting then turn off and try them again only turn them on this time. You mentioned that you checked bios setting but did you also check to see if the bios needed upgraded?
Apr 30, 2011 | Gateway M360 Notebook
How do i set the clock on my jvc mx-d301t
Hi, I just set the time on my mx-d301t and it goes like this: First you need to put the device to standby mode (red light and the time are showing). Then you take the remote and press first SHIFT button and then CLOCK button (number 1) one after another and the time should start blinking. Next you can set the time by using the SELECT buttons - (number 4) and + (number 5). When the time is right you just need to press SET button (number 8) and the time should stop blinking. There you go, the time is set. -amigo
Jan 25, 2011 | JVC MX-D301T Shelf System
Wlan is disconnected. How do I get it conected please. Thank you Julie
If it is showing that it is "Disconnected" that simply means you are not connected to a wireless network. To connect to a wireless network simply double click on the wireless icon by the clock (bottom right side, looks like a computer monitor with waves) and select the wireless network you wish to connect to.
Oct 21, 2009 | Acer Aspire 5315 Notebook
9800M GTS gpu instability in gateway p-7805u fx laptop....
Maybe a little late of a response, however... Ive had the p-7805u for quite a while. I had the same problem which I noticed that was triggered specially by old games rather than demanding games like Crysis. In fact, the computer never gave me a problem on the most demanding gpu applications, but crashed within minutes in games like Warcraft III. The screen showed artifacts, crashed and then recovered giving me the "driver has recovered" message, and ultimately and almost always hard froze after a couple minutes. I was getting really frustraded, even got an rma for warranty service, but didnt send it in because i couldnt survive without a computer at the time being.
I started monitoring my gpu clocks. Almost all gpu's, being more dramatic in mobiles, lower their clocks when they are idling. I finally noticed that the computer started artifacting and crashing when the clocks lowered for idling and lower energy consumption purposes. Simple solution: download desktop drivers from www.latopvideo2go.com , any in the 19x.xx branch, and use their modified inf so that you can install it in your laptop. In the nvidia control panel go to 3d settings and under global change "Power management mode" to "prefer maximum performance". This doesnt allow the gpu to lower its clocks, solves the problem permanently =). Ive run crash free for months, and battery life is only lowered by maybe 10 minutes, which you can always prevent by changing the setting when you plan to go on battery.
Jul 21, 2009 | Gateway P-7807u Notebook
Webcam
hi friend,
it dons't matter you can change the display setting in the my computer properties . i tell you the method how to get that
  1. Right click the My Computer icon in the desktop
  2. Goto the setting tab
  3. Advanced settings
  4. trouble shooting
  5. In that trouble shooting go to the Hardware Acceleration set it to the full .
  6. now try it and use your web cam to test it
if prob comes again please inform to fixya.com
bye
Jun 13, 2008 | Computers & Internet
Gateway Laptop W350A
what memory board use gateway w350a
May 21, 2008 | Gateway M305CRV Notebook
Compaq Presario Notebook Logo
55 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
