Question about Maytag 24 in. MDB5651A Built-in Dishwasher
Washer does not switch on. - Maytag 24 in. MDB5651A Built-in Dishwasher
  • Maytag Master
  • 12,061 Answers
When I turn the switch to my 2006 Cadillac DeVille CTS windshield wiper it does nothing no sound no movement what is wrong
Hard to say what's wrong without testing thing's . Is there B+ voltage to the wiper switch ? B + voltage to the wiper motor ? Do you know how to use a voltmeter ? How to test electrical circuits ?
Here is a factory service manual list of componets involved .
Wiper/Washer System Components
The Wiper/Washer System consists of the following electrical components:
• Accessory relay
• Heated washer nozzles w/XA7
• WASH NOZ 10A fuse
• Windshield washer fluid level switch
• Windshield washer pump motor
• Windshield wiper motor
• Windshield wiper motor module
• Windshield wiper/washer switch
• Wiper/washer switch 10A fuse
• Wiper motor 30A fuse
Do you know how the wipers work ?
Windshield Wiper Motor Wiring Tutorial
Wipers Inoperative - All Modes ?????
Wiper Motor Switch Troubleshooting
Sep 05, 2017 | Cadillac Cars & Trucks
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
Washer doesn' t drain
Fill switch is either dirty or has failed. That is that is the problems that it could be.
There is also a tube that goes to the same switch and it is a pressure switch and tells the washer to stop filling when it's full. The switch may have failed or the hose came off this switch.
The switch is behind your panel. Be sure to please unplug the power from this washer before working or checking this. Don't want no accidents to happen.
Aug 27, 2014 | Kenmore 22642 Top Load Washer
What fuse for wiper washer motor
The wiring diagrams in the Haynes book should show the washer pump circuit? Often the washer pump shares the same fuse as the wipers.
You could pull off the electrical connector for the washer switch, or the multi-function switch if so equipped, and check for voltage on the pump wire going to the switch, key on. Then check if power going out of switch to the pump-key on and pump switch on. If power on both, the wire from switch to pump must be broken. Run a new wire. If power into switch but none out-switch is bad. If no power into switch for the pump, may have to keep looking for a bad fuse or the wire from fuse panel to the washer switch may have a problem. Hope this helps, good luck.
Feb 08, 2013 | Cars & Trucks
My washer keeps giving me the code F35 and it wont let me open my washer
Replace the analog pressure switch located under the top cover panel in the back right corner of the washer (as viewed when standing in front of the washer looking down at the top). I called the Whirlpool customer service 1-800 number that I found in my washer's instruction manual to order the switch. The part number of the switch is: W10156252. The model number of my Whirlpool Duet Steam washer is: WFW9600TW01. I paid a total of $89 for the switch and overnight FedEx shipping.
What I learned in the process:
1. The "Analog Steam", and "Analog Pressure", switches that everyone speaks of are the same thing (at least according to the customer service representative with whom I spoke).
2. I read somewhere that you can determine if the switch is broken by blowing into it and listening for a click. Allegedly, if no sound can be heard the switch is broken. This is not true!! The broken switch on my washer did not make a sound when I blew into it, but neither did the new switch that I received from Whirlpool (which ended up fixing the washer).
3. The customer service representatives will barter on the price of the switch!
Hope this post helps you remove and replace your bad Analog Pressure switch. I tried to upload a labeled photograph of the washer and switch but this site would not cooperate.
Jun 16, 2011 | Kenmore HE2 Plus Front Load Washer
Have to trip washer lid safety switch with something more substantial than little 'plunger' attached to the washer lid to get washer to drain and spin during rinse cycle. do i need to replace the safety...
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet to replace it.
It comes as a complete unit and you can't replace just the plunger.
May 03, 2010 | Kenmore 23812 Top Load Washer
Kenmore washer 44722 water pumps out no spin. Brake actuator activates ,but motor does not turn on to make tub cylinder spin. Is this a Pump short or maybe control panel problem. Thanks,Ed
Ed,
I had a situation such as this with our washer, in the end I had found that the safety switch had failed open. You'll note on the washer door the small pin thats drops down from it which closes the safety switch when the door is closed (if the pin broke off this would do it too) In my case the switch had failed and would not allow the washer to engage into a spin mode. (first unplug the washer) You can check this switch by removing the wires from the switch and using an ohm meter check the switch for continuitty when closed; I expect you'll need to remove the top of the washer to access this switch. It would be possible to connect the wires together going to this switch bye-passing the switch; if it runs you know the switch had failed. AS this is a safety device do not continue use of the washer untill the switch is replaced.
Good luck,
Tom
Aug 14, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Need to replace Lid Switch for Maytag Atlantis 2002 Washer
Hello, I can help you.
Let me explain to you how the Maytag washer lid switch works.
The lid switch is located on the controls panel, and is activated by opening and closing the washer door. The purpose of the lid switch is to prevent the washer from working with the door open.
It is a safety device to prevent the user from sticking their hands inside of the washer while the washer is agitating or spinning.
When the washer lid switch stops working, the result could be that the washer won't wash, drain, spin and in some cases the washer will not work at all.
You will need a multimeter to check the internal contacts on the washer lid switch.
You will also need to use the wiring schematic to see what contact should be close when the lid switch supposed to be on.
You will need to remember that the Maytag washer lid switch is one of the first parts that you will need to check, when the washer don't want to start filling, agitating, draining or spinning.
Jun 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
99 Nissan Quest real wiper runs continually when ignition is on
Principles of Operation
Operation of the windshield wiper and washer is controlled by the front wiper/washer amplifier assembly. The front wiper/washer amplifier input comes from the multifunction switch by means of a voltage divider circuit. A constant voltage is applied to the multifunction switch by the front wiper/washer amplifier. When the multifunction switch is moved into the LO, HI, or intermittent position, the voltage is directed through a series of resistors. This results in various voltages being returned to the module for each switch position. The module then grounds the appropriate circuit, based on the voltage signal received back from the multifunction switch. This causes the wipers to run intermittently, or at the appropriate speed. Voltage is supplied to the wiper motor by the CJB fuse F46 (20A).
When the multifunction switch wash button is depressed, it bypasses all of the resistors returning a full voltage signal to the module. The module then grounds the appropriate circuits to operate the windshield washer pump for as long as the switch is depressed. The windshield wiper speed is dependent on the position of the windshield wiper/washer switch.
Voltage for the windshield washer pump is also provided by CJB fuse F46 (20A).
Operation of the rear wiper and washer is controlled by the rear wiper/washer switch.
Voltage is supplied to the rear window wiper motor by the fuse junction panel fuse F44 (10A).
The rear window wiper motor ground is made or broken by the rear wiper/washer switch. When the rear wiper/washer switch is moved into the WIPER position, it grounds the rear window wiper motor circuit, causing the rear window wiper motor to run once every 10-15 seconds.
Voltage to the rear washer pump motor is also supplied by the CJB fuse F44 (10A). The rear washer pump is directly controlled by the rear wiper/washer switch which makes or breaks the ground for the washer pump motor, depending upon its position.
If the vehicle is equipped with a movable liftgate glass, a liftgate glass switch is utilized to prevent rear window wiper operation when the liftgate glass is open. This same switch also causes the rear window wiper to drop down approximately three inches when the liftgate glass latch is released.
  • The wipers stay on continuously — rear wiper
  • Circuit.
  • Rear wiper/washer switch.
  • GO to Pinpoint Test L .
Measure the resistance between rear wiper/washer switch C288 pin 6, component side and rear wiper/washer switch C288 pin 2, component side.
  • Is the resistance less than 5 ohms with the switch depressed, and greater than 10,000 ohms with it released?
sxv~us~en~file=arrow.gif~gen~ref.gifYes GO to L2 .
sxv~us~en~file=arrow.gif~gen~ref.gifNo INSTALL a new rear wiper/washer switch. TEST the system for normal operation.
Measure the resistance between rear wiper/washer switch C288 pin 6, circuit WB08 (BU/YE), harness side and ground.
  • Is the resistance greater than 10,000 ohms?
sxv~us~en~file=arrow.gif~gen~ref.gifYes INSTALL a new rear wiper /washer switch. TEST the system for normal operation.
sxv~us~en~file=arrow.gif~gen~ref.gifNo REPAIR circuit WB08 (BU/YE). TEST the system for normal operation.
Dec 08, 2008 | 1999 Nissan Quest
Maytag washer
replace the micro switch and your problem is solved.Its a very small switch right next to your door switch and fuse.It has 3 wires and must be replaced to fix this problem.
May 22, 2008 | Maytag Legacy Series Top Load Washer
Maytag 24 in. MDB5651A Built-in Dishwasher Logo
183 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
