Question about Toto C743S01 Cotton Drake Round Bowl Only C743S
I have two new Drake toilets that were installed. The first one is working great but the second on is leaking from the bolt & nut that is connecting the tank to the bowl. Can You help?
    Scholar:
  • 102 Answers
It sounds like the tank bolts are not sealing. Make sure you used the rubber washer on the inside of the tank under the bolt. Also make sure bolt is fairly centered before tightening. You can purchase a set of tank bolts from your local home improvement center that contains rubber washers that will seal on both the top and bottom of the tank. In proffessional installations this is what I do. I hope this helps. Please vote on advise. Thank you.
Posted on May 13, 2010
Testimonial: "Thank You for the help. I will buy new Bolts and washers. You have really taken my stress away with this soluiton."
How can I remove the Flushmate 503 to access the mounting screws at the bottom of the tank?
You will need to remove the china holding tank from the toilet bowl by removing the nuts on the underside of the china tank.
After you have the tank off the bowl, remove the two plastic lock-nuts used to mount the Flushmate into the china tank and slide the Flushmate out of the china tank.
After you install the new tank-to-bowl bolts & washers, reverse the process to reinstall the Flushmate unit and remount the china tank.
Mar 01, 2013 | Home
The water level in my Toto Drake toilet bowl is normal right after a flush, but often is very low a few hours later.
The bowl is cracked and is leaking down the drain. You will have to replace it. It may have cracked if the bowl hold-down bolts were overtightened, or the bowl was not able to sit flush (pardon the pun) on the floor. If the bowl rocks when it is first installed, instead of tightening the hold-down bolts, use a couple of tapered shims under the edge of it, then caulk to fill the gap and hide the shims.
Good luck.
Jun 09, 2012 | Toto CST744SLR Elongated Drake Two Piece...
Tank to bowl leaks
Turn water supply line of to toilet. Flush and hold handle down to drain water from tank. Take lid of tank off and use a towel to soak up the rest of the water inside tank. Remove nuts on bottom of Tank bolts. Lift off and lay down on its side. Remove the rubber or sponge type gasket that is on bottom of the tank that covers the nut from standpipe assembly. Buy new gasket and install back on bottom of tank over Nut for standpipe. Put tank back on toilet bowl. Install bolts and tighten. reconnect water line and turn on.
Aug 25, 2011 | Jacuzzi Bath Perfecta EZ33 959 White round...
I tried to unscrew a toilet seat on a lowboy now the screws won't screw or unscrew.
If the screws won't turn either way, they're probably "cross-threaded" or stripped. You'll have to unscrew them with force. I'd use a ratchet and socket on an extension (you might want to use a deep socket, since the bolts often extend an inch or two past the nut).
Once you get them off & can remove the seat, head to the hardware store or Home Depot & pick up a new set of bolts & nuts. They're very inexpensive. When installing them, make sure that the nuts screw onto the bolts with finger pressure alone, before taking a wrench or pliers to them.
If using force to unscrew them ends up damaging the toilet lid/seat assembly (this is the worst-case scenario), then you'll have to spring for a new toilet seat. The up-side of this is that new seat/lid assembly come with the screws and nuts, and - depending on what you want - can cost as little as $15 for an "economy" model, and up to $30-35 or so for a "deluxe" model.
Mar 03, 2011 | Kohler - Toilet Seat - Moondance -...
My toilet only leaks when flushed. It seems to be coming from the connection at the tank. The tank is not cracked and a new hose from tank to shut off valve has been installed. The toilet is only 4 years...
If you have 2-part toilet, then tank is attached to bowl with 2 bolts.
Look inside tank and you can see bolts with rubber washers located on either side of flush valve.
The 2 bolts hold tank and bowl together and between tank and bowl is a washer called the spud washer.
So spud washer could be leaking ... or 2 bolts could be leaking.
1) If bolts are leaking, there is usually dripping all the time, and drips are visible on bottoms of bolts
If spud washer is leaking, then tank could leak only when tank is flushed.
2) First thing to try is tightening nuts on the 2 bolts. Nuts may be loose. Tighten nuts a few turns, and check if toilet still leaks.
3) To fix a spud washer, you usually need a new generic one from hardware store.
Newer tanks with 1.6 gallon flush have special sized spud washer.
geno_3245_105.jpgTank is upside down and spud washer is fit over flush valve
If you cannot find new spud washer, re-use old one and smear retorseal on it during re-assembly to make sure it seals. Rectoseal is good for many home plumbing repairs. More about that in a moment.
4) To take apart tank: Disconnect supply line to tank. Empty water out of tank. Remove nuts from bolts. Lift tank off. Wash out tank with hose. Make sure there is no sand or sediment left in bottom that might clog up flush holes located inside bowl after tank is re-assembled.
5) Remove old spud washer, and put new one on. Do a google-image search for 'spud washer' if you need more photos. New spud washer fits over flush valve. That's it. And then reassemble tank.
If you want to apply rectorseal to washer, put washer on as shown in photo above. Then smear-or-gawm rectorseal over area of washer that sits on bowl. Rectorseal will make sure there is no more leaking.
Nov 24, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
When you sit on the ring it veers off to the left and you are left sitting there crooked. How do we adjust it?
See if nuts on studs on bottom where it mounts to the floor & flange are loose. If they are loose tighten both of them evenly. If they are tight you will need to replace wax ring that is between toilet & floor.Turn off shutoff water valve to toilet. Flush once holding down handle to let tank drain. Remove both nuts & lift toilet off flange. Remove wax ring. Scrape all old wax off toilet & floor flange. Install new wax ring. Set down toilet on ring & snug nuts evenly. Sit on seat & apply your weight evenly to distribute wax & level. Retighten nuts. Turn water back on. Allow tank to refill. Flush toilet & check for leaks.
Sep 30, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
Handicapp Toilet Bowl does not fill - up as high as regular toilet > very small amount of water in bowl after flushing ie> about 10 cuos of water.. JUST INSTALLED IT NEW YESTERDAY...
Wiith all due respect, the Drake toilet is not a regular toilet and doesn't sound the same as a regular toilet when you flush it. It is in the design that allows it use only 1.5 gpf instead of 3.5 gpf. A rather unique thing is that while it is scientifically calibrated to release 1.5 gpf, it does not empty the tank of approximately 1 gallon of water. Therefore if one feels the need for a little extra umph, simply hold down the flush lever when you flush until the tank is emptied.
Aug 04, 2010 | Toto DRAKE ELONGATED HANDICAPPED TOILET...
Cannot get the bolts and rubber washers to seal properly in the holding tank of our new TOTO Drake toilets
Some manufacturers specify only to use rubber washers inside the tank, and only one bolt on bottom. I usually assemble the bolt with one metal washer on bolt ( or bolt with large head) then a rubber washer, then through tank, then another washer, then a metal washer (brass or stainless) then another nut. Snug these nuts up tight, but be careful not to over tighten or you'll break the tank. Do this to all the bolts. Then set the tank on bowl, with the bolts extending through the bottom. Make sure your gasket is up all the way on the nipple, so the tank will tighten to the stops on the bowl. Now put another set of rubber washer, and metal washer and nut (thumb nuts are fine here) Tighten till tank doesn't rock and is resting on stops. Now it doesn't have to be so tight, as the bolts are already tight in the tank. You can get a fluidmaster bolt kit at home depot that has enough bolts, washers and all
Aug 02, 2010 | Toto Home
Missing bolt for toilet seat
A standard toilet seat bolt should be fine. There are some with a rubber boot that expands as tightened but you should be able to reach the nut by reaching into the tank and under the lip. The new nut & bolt should be plastic so they won't corrode.
Apr 19, 2010 | Eljer Toilet Onepiece Canterbury ...
Toto C743S01 Cotton Drake Round Bowl Only C743S Logo
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
