Question about MA Audio MA589 Car Tweeter
Power and ground
Is the wire from the tweeter with the red stripe indeed power or is it ground?(The other is solid) I am getting conflicting answers and little help from MA. Need to know before hook up so I don't wreck em. Thanks!!
  • 31 Answers
The wire with the stripe is normally the negative (no the same as a ground when it comes to speakers), and the solid wire is the positive. Wiring a single speaker backwards won't blow it, it will only cause it to be out of phase. In some cases speakers are wired out of phase or creatively intentionally to create a desired effect or impediance.
Hope this helps.
Posted on Mar 29, 2008
Pioneer deh 15ub wire diagram
Yellow - Constant 12 Volt (battery)
Red - Accesory 12 volt (switched) only 12 volts when car in accesory or on position
Black - Ground (chasis)
White/white with black stripe - Front left speaker (black stripe is negative polarity)
Gray/Gray with black stripe - Front right speaker (stripe negative)
Green/green w/ black - rear left
purple/purple w/ black - rear right
solid blue - power anteanna (not all have this wire)
blue w white stripe - remote turn on (used to turn amplifier on or power anteanna)
yellow w/ black stripe - mute (for cellphone handsfree kit)
Jan 21, 2014 | Car Audio & Video
No sound with Sony XAV-60 when playing DVD
The problem is with your ant. wite. It is the blue with a stripe. You need to hook either the solid blue or the blue with a stripe to the red ignition wire. For me I didn't have a power antena so I took the solid blue and hooked it to the striped blue out of the wiring harnes, then took the stripped blue and hooked it to the two red wires. I had no clue what was wrong, and no one had an answer. The problem is not with the ground it is with the antena and amp wires. Try to try one way and check it out and see if it works. The first way for me worked, but the head unit would not turn off when I turned the car off so I took the solid blue off the red and put it back with the stripped blue, then stripe blue out of the unit to the two reds, also give Sony support a call, they were great and I had it figured out in no time.
Jun 19, 2011 | Sony XAV-60 Car Video Player
Which wire coming off the back of the unit is the ground? I have a solid red wire and a black wire with a red stripe
the black wire is ground. It only has a red strip because it was split from the red wire. Red is positive.
Sep 27, 2010 | Cobra 19 Ultra II CB Radio
Wiring diagram for pioneer deh-p41
Yellow for memory.
Red for power acc.
Black for ground.
Blue for remote turn on(amps and accessories).
Gray pair is for right front speakers, solid for positive,striped for negative.
White pair for Left front, again solid is pos, striped is neg.
Violet or purple for right rear, same with solid or striped.
Green pair for left rear, same solid/stripe configuration.
Nov 17, 2009 | Pioneer DEH-P410
Can i get wiring diagram of sterio for Acura Rsx 2004?
Generally there are two types of wires , power , and sound. The power wires will usually be black , red , and yellow or orange. Might also have a blue one. Black is ground , Red is constant power , yellow or orange is accessory power ( only energized when key turned on) .
If you have a blue wire , it sends out power when stereo is on , to power an electric antenna or turn on an external amp. All other wires will be in colored pairs. For example Green and Green with a black stripe , Grey , and Grey with a black stripe , purple and purple with a black stripe.......These are all speaker wires , the solid color one is the + and the one with the stripe is the - , EG: Grey might be right front + , and Grey with black stripe would be right front -
May 03, 2009 | 2003 Acura RSX
I was wondering which wires are which to hook up an after market stereo in my 1991 plymouth laser. i need to know what are the power wires and the speaker wires on my stock wire harness.
I don't have the exact wire pinout, but I can offer you a generic method. Usually wires in an automotive wire harness that are Red, are power.
I would suggest you buy a cheap multimeter, (If you don't already have one), and set it to the DC volts-50 volt range. They have multimeter's that are relatively inexpensive. $10 or $12 dollars.
There will be a Red lead to a probe, (Positive), and a Black lead to a probe. (Negative) Hold the Red lead to the red wire. Touch the Black lead to any good ground. Any clean of paint, metal surface on the car. The needle should go up to 12 volts on the DC scale.
Ground wires are generally Black or Green. Should you see a Green wire with a stripe on it, this is not a ground wire.
Wires that are of a solid color and have a stripe on them, are usually speaker wires. They will be in pairs. There should be a wire of a solid color with a stripe on it, and a wire of the same color, but no stripe, to make up one pair. One pair is for one speaker. For example:
Blue color wire with a White stripe, and a solid Blue color wire.
There may be two pairs of wires, or four pairs. Two speakers in front, two speakers in back, for the four pairs of wires.
After you find the power wire, and have it attached to the stereo, plus a ground wire, I suggest you make sure ALL the other wire ends are not touching each other, on the stereo. Put a small piece of Black electrical tape on them.
Take one pair of speaker wires, from the car harness, and attach them to the stereo. Turn the stereo on, and see which speaker wires you have. Move the Front/Back, and Left/Right controls.
Now it's just a matter of finding out the correct hook ups for those wires. Match them up.
Apr 16, 2009 | Car Audio & Video
Need to know is the wire with the black stripe (+) or(-)
The solid red will be your positive wire, the solid black or black stripe is your negative (ground) wire.
Mar 27, 2009 | Kicker Car Audio & Video
My wife bought a kenwood z828/uf4. there are wires in the back but none of them are labeled. can anybody help me
red - 12v ignition
yellow - memory 12v cont.battery
orange - illumination
black - ground
white- front right speaker +
white/black stripe - front right speaker -
gray - front left speaker +
gray/black stripe - front left speaker -
violet - rear right speaker +
violet/black stripe - rear right speaker -
green - rear left speaker +
green/black stripe - rear left speaker -
blue - remote, amp
blue/white stripe - power antenna
if you don't have a blue/white strip wire than the solid blue wire goes to power antenna, amp and remote...........
hope this helped you
Feb 26, 2009 | Kenwood Car Audio & Video
Wiring a new radio in 1991 ford explorer
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Open Questions:
See all MA Audio MA589 Car Tweeter Questions
MA Audio MA589 Car Tweeter Logo
47 people viewed this question
Top MA Audio Car Audio & Video Experts
Mark Skinner
jamie suver
Level 1 Expert
Robert Rankin
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
