Question about Shure UR2 Handheld Wireless Microphone Transmitter UR2BETA87CL3 Microphone
I have UR2/ microphone w/ KSM9 capsule on it.. when I screw on the battery cover, the transmitter and the reciever looses signal, the mic is still on and the recever both are on, but have no connection between the two. Then I began to unscrew the battery cover and the signal comes back..
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
You should send it to Shure for repairs. My guess is that there is something loose or broken on the circuit boards.
Posted on Jun 18, 2010
Wireless microphones vhf transmitter green light no sound
Either mic "mute" is on or mic capsule is dead...dropping these low-end wireless mic's are usually fatal. Upgrade and you won't regret it.
Jan 31, 2013 | Gem Sound GemSound GMW-60 Professional...
My shure mic receiver SLX4 is showing Ready indication but not recieving the Audio from SM58 mic...whether it is reciever problem or transmitter.. what is the solution
If you shout into mic and the audio signal LED on receiver lights everything is ok.First check your receiver to amplifier jacks and cables,If ok check muting transistor inside the receiver next to the audio output terminal.As an expert on cordless microphones I'll be glad to answer your questions. Send me an e.mail if you wish at moska.1982@yahoo.com
Feb 15, 2012 | Shure SM58 Professional Microphone
Dont know what size battery to use for a nady ht-3 mic transmitte
To insert the battery, You will need to unscrew the below button part of the hand held mic (anti-clockwise), and after unscrewing, you will see the space to fix in the 9 volt battery..
When you buy the battery,before fixing the battery in, check the polarity before placing the battery in (positive + and negetive -)...After inserting,screw back the cover in and locate where the power switch is..It always has an indicator to know if the power is on...
Note..make sure the Transmitter is on for it to be able to work properly with the hand held microphone....
Good luck..
Sep 07, 2011 | Nady Systems HT-3 Professional Microphone
Remove antenna cover
Carefully remove the bezel that surrounds the switch. Wiggle the dome cover back and forth to remove the antenna cover.
Feb 11, 2011 | Shure UR2 Handheld Wireless Microphone...
Have a Shure SLX Wireless System. The only way the microphone SLX1 or SLX2 is if they are right up to your mouth. If you put the lapel mic on a persons tie you can't hear them. The transmitter is set to...
The Shure SLX2 hand-held microphone has similar performance characteristics to the much-loved (cabled) Shure SM58 vocal microphone. It has a 'cardoid pick-up pattern' intended for close work - being spoken / sung straight into the top of the capsule at no more than about 8 inches from the mouth of the user- to minimise feedback and extraneous noise. If you double the distance between the mouth and microphone the sound level will drop four-fold so distance really matters.
The SLX1 lapel/ lavalier is a semi 'omni-directiona'l pick up pattern microphone, which should work satisfactorily up to 12 inches from the speakers mouth, but closer is better. Always try to get your users to hang it about 6 inches below their chin, at most, and preferably with the top of the microphone capsule pointed upwards towards the mouth.
Here are a few other things for you to try:
  1. There is a volume (gain) knob on the back panel of the SLX receiver unit. Try turning this up to maximum (needs a small screwdriver)
  2. Make sure that both aerials on the receiver are fully extended at different angles to each other and in a clear 'line-of'sight' with the transmitter pack, with no large bits of metal in between which could block the signal. Ideally the receiver should not be more than 25metres from the transmitter. If distance is a problem locate the receiver near to the transmitter and run a balanced (xlr) cable to your mixer/ amplifier.
  3. The angle that the receiver aerials are at should be broadly similar to the angle that the transmitter antenna is at to optimise signal reception.
  4. Make sure the receiver is not located too close to other electrical equipment which may be interfering with the signal (especially voltage transformers, CD or DVD players and hearing loop induction amplifiers which have a strong magnetic field)
  5. Always use good quality batteries - Duracell Ultra or equivalent ( do not use rechargeable batteries as they seldom achieve optimum voltage)
  6. Check that the antenna is tightly screwed into the SLX1 transmitter pack and not damaged.
  7. The SLX2 hand-held microphone has an adjustable level switch inside the body - unscrew the top of the microphone to access it - switch to maximum.
  8. Another possible cause could be an impedance mis-match between the SLX receiver and your amplifier or mixer. There are two outputs on the rear panel of the receiver. One is an XLR (large 3 pin socket) this is LOW impedance and needs connecting to a low impedance input on your mixer/amplifier. You should normally be using this output even if your amplifier has a jack-socket input (use a proper balanced XLR to 6mm trs jack cable rather than a adapter plug). The other output on the receiver unit is a 6mm HIGH impedance, unbalanced, standard jack socket (labelled 'line in'). This would normally be to connect to a guitar amplifier which has a high impedance 'line level' input socket. If you are using this output you may need to use a pre-amplifier to get a big enough signal for a microphone.
You can find the Shure SLX user manual here http://www.shure.com/idc/groups/public/documents/webcontent/us_pro_slx_en_ug.pdf
Jan 27, 2011 | Shure SLX1 Body-Pack Transmitter for...
Mic not working
On some mics, one of the lights will NOT turn on unless the battery is low. The mic is the transmitter, so I am not sure what you mean by it not lighting, but the transmitter is lighting?
Make sure the mic's freq. is within the scanned range of the receivers. Often the mics get mixed with other receivers and the resulting pair are incompatible.
The receiver should show if signal is being received. If it is, then the module in the microphone dynamic cartridge MIGHT have been damaged. If it is damaged, it has to be replaced.
Apr 27, 2010 | Shure SM58 Professional Microphone
Mic is popping
It sounds to me like you have a short in the cable. Power up unit like normal and move the wires at each end of the cable, mic end and connector end, being careful not to move the mic. If you hear popping it's a bad cable. If not, now gently shake the mic, does it pop, then it's your mic's capsule and needs replacement.
Apr 03, 2009 | Shure ULX1 Body-Pack Transmitter...
Sm 58 dropped and cuts out
Under which circumstances did it fail? Might be due to internal wiring getting loose or a damaged capsule after you have dropped it. Can you take it apart to confirm that?
Cass
www.surek.co.uk
Apr 20, 2008 | Shure SLX24/58 Wireless Microphone System...
157 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
