Question about Canon PIXMA MP470 All-in-One Printer
What is Error Code 5100 please - Canon PIXMA MP470 All-in-One Printer
  • Canon Master
  • 4,924 Answers
I asked around and this error ..its also instruct you to turn off and on the printer ..it is a warning for an obstruction in the printing process ...most of the times the obstruction having mechanical origins..So look around for sliding parts and in general parts that suppose to move in a certain pattern and now are blocked or not well lubricated or something is blocking them ..
Posted on May 13, 2010
    Guru:
  • Canon Expert
  • 183 Answers
Error code 5100 indicates that carriage unit movement disturbance occurs. Open the printer cover and look inside the printer,you will see film encoder out there. Sometimes,dirty film encoder cause that problem.
How it works?. Carriage unit read film encoder by using optical mechanism to move correctly. Some dirt,like grease or finger print may turn the light and make carriage movement error occurs.
Faulty carriage unit may also cause this problem. So,you can try clean film encoder with moistened clothes first. Do it carefully. Do not damage film encoder. Film encoder just likely negative film that can be easily broken.
If this do not solve your problem,replace carriage unit
Online source:
Printer Clinic
Service Manual
Join our affiliate program and get hundreds dollar per month!
  • Xanda Frederica May 16, 2010
    Error description of 5100 is CR error. CR= Carriage return. For details,problem occurs when carriage unit return to it's initial position (On cap unit of purge unit). Note that this error represented by blinking error 2 times in green and orange. This error is carriage case. It's completely different with Cartridge Jam problem where the printhead or cartridge being locked by faulty purge unit.
  • 23 Answers
Cartridge jam. Try removing the ink cartridges and reinserting them.
3 Suggested Answers
  • 2692 Answers
SOURCE: ip4200 error code 5100
Answer below taken from another web site:
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Wayne Lischynski - Ebytes Computers
wayne@ebytesonline.com
Posted on Mar 08, 2009
pineworks
  • 4041 Answers
SOURCE: MX850 - error code 5100 = can you help please.
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
Gives me a code 5100
Canon i550 Service Error 5100 ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/25975
Oct 6, 2006 - I recently dropped my printer out of my car by accident, and now everytime I try to print something, it gives me a Service Error 5100.
Canon Pixma MX420 Printer 5100 Error and Loading Ink ...
? 5:57
https://www.youtube.com/watch?v=tmTJdJTAhYU
Mar 13, 2012 - Uploaded by Dustie Meads
please help me,i have problem in my printer,wifi on printer can't search .... I too was given the generic "5100" error message just tonight.
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
How to fix canon printer MX410 5100 error occured
Hi Salar,
Please check the following useful article for this.
Error Code 5100
Dec 13, 2013 | Canon Office Equipment & Supplies
Error message: Service error 5100 on my Canon MP160 Printer
The main reason of Canon Printer error code 5100 If you receive Canon printer error code 5100 message this means you need to reset the printer. This also signifies that your computer does not recognize the printer. Your printer will show this error code because the LED is blinking. If your PC does not recognized the printer then it will also affect your printing jobs and you will not be able to do any printing work.
When the error code 5100 appears in your Canon multi functional printer then the Printer LED light will blink. This also means that you need to reset your printer. You must fix this error as quickly as possible. For instant technical support please contact Canon Printer Technical Support.
Tips to Resolve Error Code 5100
  • The Canon printer will show error code 5100 to warn the user that there is some problem.
  • In order to fix the problem, you require to opens the top of the printer.
  • In the right side of the printer you need to search for the waste ink absorber pad.
  • The next step is to clean the waste ink absorber compartment with a paper or cloth. This also completes the resetting process of the printer.
  • Inspect the paper feed area of the printer and confirm that there are no obstructions or paper jams in the printer that may be responsible for the error.
Dial our toll-free number +1-800-213-8289 for quick online assistance for resolving technical issues relating to the Canon printers. Our Canon Printer Support Number service is available for fixing technical glitches of our customers. Please get in touch with our tech support team and will receive online remote technical help at highly reasonable charges.
Our Epson printer support technicians are always ready to sort out each and every printer related issue with latest solutions offered to its clients. We are a team of fastest printer tech support solution provider for every issues related to all printers such as Software installation issues, Driver Upgrade, Change Printer ink, Printer Spooler and Paper Jam issues etc. If users are unable to solve this problem, they are welcome to drop us an e-mail and we promise to get back to them in short time span via our professional printer contact details. So, come and join us for tom experience our exceptional level printer solutions to your unexpected and critical issues. And also our Canon printer technical support technicians are always ready to sort out each and every printer technical issues with instant solution. We also provide instant remote support for Brother Printer technical support services for your common printer errors such as Software installation issues, Driver Upgrade, Change Printer ink, Printer Spooler and Paper Jam issues etc.
How to Fix Error Code 5100 in Canon Multi functional Printers
Jul 06, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Error code 5100 has appeared
Here is what I could find on the issue. -Error code 5100 describes a physical problem either with a paper jam or an incorrectly seated ink tank.
This was found on e-how. If you would like to read more please see the link below. hope this helps.
http://www.ehow.com/how_6497472_fix-code-5100-canon-mx700.html
Apr 11, 2011 | Canon MX700 Office All-In-One InkJet...
Error code 5100 i have turned off machine, unplugged at electrical source. After 30 min replugged in to electrical source, turned on printer. Pressed print button. Machine processes for a few minutes...
Hello and Welcome
Error 5100 means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed
Further assistance i am here to help
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Mar 11, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Canon printer pixma MP450 error 5100
Vittorio,
you should contact the manufacture during normal business hours error 5100 is not an error code I'm not familiar with. 404 => site not found is very common. More information please
Nov 26, 2010 | Computers & Internet
I get ERROR 5100 message for my i350 printer...of course it will not print. How is this fixed? Please help.
I had the error code 5100 for my canon pixma ip6220d printer and all it was a pen in the track of the cartridges. I've been looking for that pen for awhile too. So I would say look for something in the way of the cartridges. Hope this helps everyone.
Aug 03, 2008 | Office Equipment & Supplies
Canon PIXMA MP470 All-in-One Printer Logo
721 people viewed this question
old marine
old marine
