Question about Samsung RS2630SH Side by Side Refrigerator
No cooling compressor is ruining no cooling in refrigerator.little cooling in freezer unit
  • Samsung Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
8
Posted on Sep 30, 2010
Frigidaire freezer compressor is hot to the touch and not cold inside
If the compressor is hot to touch and it is not cooling, contact a service professional as soon as you can. Sounds like you have a sealed system issue or cooling restriction and you don't want to ruin any food items in the unit.
Jul 26, 2012 | Frigidaire Refrigerators
Ro@hotmail.comtemp fridg& frezer will chang 30 to 40 degrees if you open either door it will take a long time for for temp to drop
The compressor is the part which cools the refrigerator.---------- First i will explain the working procedure of your sanyo refrigerator.---------- In the refrigerator, there is a part called compressor, the compressor is the part which cools the freezer section, When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold.--------- So the freezer section cooling/ freezing is must.If freezer is not getting properly cooled or not getting cooled, then fridge section will show the low or no cooling problem.--------------
In your refrigerator, its quite possible that compressor is got weak, nor complete faulty but little bit weak.So when you open and close the fridge or freezer door , the compressor is not that strong to maintain the required temperature.So its working hard to cool inside temperature, but its not doing it quickly as it should.---------.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- ----------------
There is manual reset procedure, sometimes the ice gets frosted all over and blocks the ventilation's for cool air to pass from one section to another, and this also causes problem.So directly going for compressor inspection, before that you can try manual reset procedure and see if that helps.---------
The manual reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take approx 4 to 6 hours for your refrigerator to regain its regular cooling/ freezing .So after 4 to 6 hours check , Is the refrigerator cooling properly or is it taking time or temp is dropping once you open close door. If this problems are not noticed, then reset procedure has helped.------- But if same problem is noticed after reset procedure is followed, then you can get the compressor checked. -------- This should help. Thanks.Helpmech.
Aug 22, 2011 | Sanyo SR-3620 Compact Refrigerator
Compressor kicks on then kicks off in a second or two. Cooling a little in the freezer. Not cooling at all in the Refrigerator. It is a side Xside.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
May 18, 2011 | Whirlpool Refrigerators
My compressor is running and cond. fan is running but freezer side nor fridge side will cool.
If the compressor is running their are 2 possibilities. The unit is low on freon or the crank broke and all you are hearing is motor in the compressor ruining.
Dec 28, 2010 | Refrigerators
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
My refrigerator and freezer temperature is not working. Everything in the refrigerator and freezer is ruined
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 02, 2010 | Samsung 26.1 Cu. Ft. Side-by-Side...
My freezer and refridgerator is not freezing or cooling any longer. 2 days ago it was working then all of a sudden temps went to 90* and all our food was ruined. What could be the problem?
A bad start relay on the compressor.
A bad fan motor on the compressor.
A bad compressor.
A bad freezer fan motor.
A bad defrost timer.
A bad thermostat.
A refrigerant leak in the system.
A bad defrost heater or thermostat.
Check each of these and report back.
Jun 27, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
Refrigerator not working, freezer works great
Yes, only one compressor. The refrigeration system actually only cools the freezer. Then there is a vent from the freezer to the refrigerator that allows the cold air to circulate to the refrigerator side. That little dial you turn to set the refrigerator temperature is actually only open or closing that vent. The dial for the freezer temperature is an actual thermostat that operates the compressor.
The temperature of the freezer should be between 0 and -10 degrees Fahrenheit. If it is in or near this range and the refrigerator is only at 55 degrees (the refrig should be at 38 to 45 degrees) then check for blockage or icing where the air from the freezer circulates into the refrigerator.
If the freezer is not in or near the 0 to -10 degrees then you have a refrigeration problem. First thing to do is clean the condenser coil on the bottom of the unit using rags and a shop-vac. Be careful of the wiring and tubing down there plus the sharp metal.
Unplug the unit before cleaning.
Otherwise, you'll need to call a refrigerator service technician to repair the refrigeration system for you.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Kenmore 52282 / 52284 Side by Side...
Freezer / Refrigerator not cooling
When the fans are running the compressor should also be running. If the compressor is hot but not running you have a compressor problem. If the compressor is running check for frost on back wall of the freezer compartment which would indicate a defrost system problem. At five years old have you cleaned the condenser where the heat is transferred to the outside air in the room?
Nov 19, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
1,437 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
