I can't attach the yellow, white and red cords correctly to watch a dvd on my Vivo 42'' LCD. I've got an austar box attached, but when putting in TV mode the DVD player won't work. Where, in ''simple'' terms do i put the cords, the manual is NO help!!!!!!!!!!!!!!
ImWireless
  • 113 Answers
SOURCE: Copying video from camera to DVD Recorder attached to TV
You can visit this link for any information related to this camcorder http://esupport.sony.com/US/perl/model-home.pl?mdl=DCRHC90®ion_id=1 This also allows you to download the user's manual. Cheers
Posted on Mar 07, 2007
lukster
  • 217 Answers
SOURCE: my dvd player keeps coming up in black and white
sounds like the video processors on the input are bad
Posted on Apr 30, 2007
SOURCE: hooking up dvd player
Your cables are coded red(right audio), white(left audio) and yellow(video). The cable inputs on the dvd player and tv are likewise coded. Just connect color to like color. In setup, do not
change NTSC! If you should go to PAL you'll never get out of setup and all you'll have is screen roll, as though the vertical hold gave out.
Posted on Jan 05, 2008
djnick989
  • 1067 Answers
SOURCE: Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Posted on Feb 02, 2008
skotkolr
  • 558 Answers
SOURCE: tv-dvd connections
first what model samsung? second if the tv has yellow red white then you need to change the tv to the input you are using. for best picture I would use an s-video cable it will give you superior video images since I don't know what brand dvd player I only say this if you have an output on the dvd player
most important is to make sure the tv is on what input you have plugged in. and dont forget to power up both units.
Posted on Apr 28, 2008
I'm trying to hook up my DVD player to my TV but my TV doesn't have a yellow jack only red and black
If your TV doesn't have a Video IN jack (Yellow) then you would have to attach your dvd by antenna (Coaxial) cable. What does the DVD have on the back ? EG: Video Out is Yellow, Red is Right Audio, White is Left Audio. If your DVD has Ant in & Ant Out you can use a coaxial cable from Ant out to your tv's antenna In socket and put your antenna cable (from your wall socket) to Ant in on the dvd. Turn on the dvd and put your tv on a blank station and tune your tv till you see the dvd screen . lock it in and that becomes your DVD channel to watch your dvd's.
Hope this is some help.
Sep 07, 2015 | RCA Televison & Video
Surround Sound
RED and White attachments are Audio. The Yellow is Video. Do not plug the Yellow into the Red/White/or black (if available). If you have HDMI, all of this would be solved with one cable attachment.
Mar 05, 2014 | Proscan Televison & Video
Trying to hook up panasonic veira flat screen tv without a manual. Not sure where to put the red, yellow and white cord.
These cable is to connect your tv to other hardware like a dvd player. Just plug the yellow cord on the yellow input in the TV and in the yellow output of the DVD, and the same thing for the other two colors. The yellow it's for the image, and the white/red are for the stereo sound (right and left channels).
If you don't have extra hardware you wont need to connect that cable.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I'M TRYING TO HOOK UP MY INSIGNIA 42'' 1080P FLAT-PANEL LCD HDTV TO OUR DVD PLAYER USING THE COMPONENTS (RED, BLUE, GREEN, RED & WHITE CABLES) PROVIDED AND THE PICTURE IS IN BLACK & WHITE....
The three picture cords (red/blue/green) often are a little larger around than the sound cords (red/white). If they are they same size, they are often grouped separate by picture and sound. Double check to verify if you have the "red" cords correct. Good luck.
Jan 20, 2011 | Insignia 42" LCD Flat-Panel HDTV
How do I attach my dvd to the 42 inch tv to watch a movie? Do I just attached the RGB connections?
An HDMI cable is best however a set of Component cables will also work. The Component (RGB) will also carry a high def image. You will need five cables in all. The Red, Blue, Green for the video and two additional RCA cables for audio (red and white). Color match the inputs to both the DVD and the TV. Select "Video" source from the Input menu of the TV. Confirm this worked.
Jul 01, 2010 | Haier HL42R 42 in. LCD TV
Prolem with attached DVD player
u are using composite red,white,yellow. then connect it on video1. as there is only 1 yellow connectore on the tv.
Jan 23, 2009 | Sanyo DP42746 42 in. Plasma Television
No signal on tv
Manually change the TV to the relevant AV channel.
Also you don't need both the S-video and the yellow RCA connection. Use one or the other.
May 03, 2008 | Jwin JD-VD135 DVD Player
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
DVD and PS2 in Black and White
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Jan 20, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Not enough av ports on t.v to connect dvd player and austar
may need to go to an DIY electronic store and get adaptore extenion boards
LG Support Search Results LG AU
Apr 10, 2017 | LG Televison & Video
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
