Question about Garden
Power Washer fails to work
I start my campbell hausfeld power washer (model# pw2502v1le) and it runs for approximately two minutes then shuts down. When I try to restart the washer I can't get it to run. If I wait about four or five hours it will start and run again for approx two minutes then die. Changed plug, new oil and gas I also tried a carburetor cleaning additive. Nothing seemed to work.
  • 313 Answers
SOURCE: pressure washer wont idle and run
check the pressure replace valve or a bypass valve
Posted on Jun 08, 2008
  • 174 Answers
SOURCE: My Simpson Water Shotgun shuts down about a minute into the wash
Have you checked the oil level? Some engines have a sensor that shuts it down if the oil is too low
Posted on Jul 17, 2009
  • 3 Answers
SOURCE: Toro 6.5 hp pushmower shuts off after ~ 5 mins of
It may have a gravity float residing in the carberator which may be cracked and will show same symptoms.If not garvity float, check for loose connection, heat and vibration my cause it to die, it cools and then restarts.
Posted on Aug 02, 2009
  • 12 Answers
SOURCE: 17hp b/s intek OHV after 30 min mowing starts running rough
if gas is in the oil the needle and seat in the carb are bad or some thing in it. the gas will go in to the crank case and load the cylinder with gas. you can take the carb apart to see if something is in the seat. or replace the carb
Posted on Aug 09, 2009
rcalorisian
  • 313 Answers
SOURCE: Honda GX160 runs fine for 5 minutes then dies like out of fuel.
I would look for the fuel filter. Blow it our. I know you have a new tank of gas, but you might want to empty it out and make sure the clean and put in new. Even with Stabil in the gas you might just have to much condensation in the tank
Posted on Sep 08, 2009
Need to see a diagram of a campbell hausfeld clean power 37 unloader valve
Most all of the manuals for campbell hausfeld tools are found at www.chpower.com , just look for your model number. Also , campbell hausfeld does not make all their pressure washer pumps. Yours may be another brand. To find who makes yours look on ebay. Make search for {pressure washer pump only} and look for one that matches yours. Then look for that breakdown. Good lu ck.
Oct 12, 2017 | Campbell Hausfeld Air Tools & Compressors
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
Need the connection for the wand hose to the pump for Blue Max Gasoline High Presssure Washer stock No: PW2200/03435
Your pressure washer is sold under various brand names, however I believe that it is made by campbell hausfeld. Parts are here:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/campbell-hausfeld/PW2200
Take a close look at the pump diagram to make sure it looks like yours. Good luck
Nov 10, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
What kind of oil do you use in a Campbell Hausfeld pressure washer pump? We are using my dads and we dont have an owners manual thanks
The pump uses SAE20 or SAE 30 non-detergent motor oil that fills up about half way
The engine uses 10-W30 motor oil that comes a bit more than half-way up dip stick.
Do not turn washer on its side or upside down to drain oil, or oil will run into carburetor.
If you have problems starting:
read:
http://www.fixya.com/support/t6504468-craftsman_2700_psi_pressure_washer
Nov 08, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
Stops running after a few min. of spraying and won't start up . campbell hausfeld 1300 pressure washer
hi sounds like the rong nozzel in the lance and it's pulling to many amps so it overloading the motor and tripping out, take the lance off then try regards
Oct 25, 2009 | Campbell Hausfeld Tools 1300 Psi X 1.4 Gpm...
I have a PW1686 power washer but it runs for a few minutes then cuts off. After a few minutes it starts again then goes through the cycle of on and off. Kindly tell me what are the possible causes.
The problem sounds internal (perhaps the temperature cut-off switch or the auto-start-stop switch). For safety and possibly warranty reasons, you should not open the case to investigate or repair; take the unit to your local service center.
Oct 08, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Electric power washer shuts off
Sounds like a coil.Run till it shuts off, then check for spark.If there is no spark you will need a coil.
Mar 17, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Campbell hausfield power washer Model #pw175500le
Hi
First priming hte engine(put some gas in the plug hole)and start the engine for few times until the engine runs constantly.If not there is a fuel delivery problem.Check the air and fuel filters,the fuel line,the muffler and screen inside.Disassembly the carb,check and very carefully clean it with compresed air.
best regards savumihai71
Nov 02, 2008 | Campbell Hausfeld Garden
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
