Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
(90s) Jenn-air single wall oven locked
I have an older model (90s) Jenn-air single wall oven. It has two control knobs on the left and a small LCD screen on the right with 3 small knobs (start time, stop time, and the middle one sets the timer/clock). I obviously lost the manual and don't know the model number. Tried to use the self-clean today...the clean light didn't come on but the fan was running. Sounded like it was cleaning but never got hot so I turned off the knobs. And, now I can't unlock it. The lock is a lever. HELP!!
  • jillp384 May 13, 2010
    Thanks... I also forgot to mention that the clean light doesn't even go on when I turn the selector and temp knobs to clean. The fan turns on when I turn the selector knob, but when I turn the temp knob past 500 it gets loose again like it doesn't work. I know the lights work because when I turn it to any temp and bake the bake light goes on... so I feel like the clean function is busted. But the damn door is still locked! Honestly- who even comes to your house to fix ovens? Haha...Sears or something?
    President:
  • 949 Answers
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
Posted on May 13, 2010
Oven is finished cleaning but the door says "locked". The panel just shows the time and "locked" in red, under it. Help
I have Jenn Air oven S136-C with a locking bar. After cleaning cycle wait for the oven to cool down and the lock light will go out (but the oven is not yet unlocked.)
Set SELECTOR knob to OFF
Set TEMPERATURE knob to CLEAN
Press CANCEL button (on right) twice.
Slide the locking bar to the left and the oven door will open
Jan 16, 2011 | Jenn-Air JJW8530C Expressions Collection...
My Jenn Air oven digital display went out, what I
Apr 10, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
How do i remove a jenn-air built in wall oven? (older oven model W131B)
IF YOU OPEN THE OVEN DOOR THERE SHOULD BE SCREWS FROM THE SIDE OF THE OVEN INTO THE CABINETS THERE COULD BE MORE THEN SIX
Mar 07, 2010 | Jenn-Air JJW8330D Electric Single Oven
7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air wall oven control panel not working
my jenn air wall oven controls are not working how do i fix it
Nov 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Older jenn air wall unit oven / turn knob
Yes, I just had same problem. The probe receptical is on the right inside wall of the oven. A little flapper door is secured by a single phillips screw. Remove this screw and the flapper door. Gently remove the receptical and its attached cable adapter. With your screw driver short the connector extension to the housing, just as the probe would. This should reset the meal temperature sensor. Try the bake and problem should be gone. If not permanently short this connection with a wire. You won't be able to use your probe, but the oven will work.
Feb 23, 2009 | Ovens
Locking mechanism for jennair
I have Jenn Air oven S136-C with a locking bar. After cleaning cycle wait for the oven to cool down and the lock light will go out (but the oven is not yet unlocked.) Set SELECTOR knob to OFF Set TEMPERATURE knob to CLEAN Press CANCEL button (on right) twice. Slide the locking bar to the left and the oven door will open.
Dec 24, 2006 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
262 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
