Question about Coffee Makers & Espresso Machines
I have a Mirabella cucina cafe express machine Model No SA001MIR (Madae in China). The water heating element burned out Can you advise where can I buy a replacement element? Thank you. Desmond de Ratz (desmondderatz@optusnet.com.au)
LaPavoniBoy
  • 36 Answers
SOURCE: Hi there,
Hi there
I supply all La Pavoni spare parts and dispatch all over the world. Go to www.theespressoshop.co.uk and click on the la pavoni machine on the right to access the full parts list. We have all variations of the elements.
All the best
LaPavoniBoy
Posted on May 28, 2009
  • 512 Answers
SOURCE: instructions for a cafe nabucco
Go to http://www.delonghi-accessories.com then go to customer care and ask them for instructions, they are very helpful.
Posted on Jun 17, 2009
SOURCE: dishlex 302 water not heating
My son fixed this problem with our DX302 dishwasher only this morning. Now works fine and hot. Found the solution on this site posted 11 august 2008 from dishwasher dishlex dx302wb no hot water. There are photos to help you. Take out the circuit board in the top of door and resolder the points on left hand side of green board there are 2 long solders and a half moon. The problem is at the top of the 2 long solder lines. Do not replace your element. There is a fault with the circuit boards on this model 302. I want to thank all the posters for helping me fix my no hot water problem.
Posted on Jun 27, 2009
VtToolMan
  • 704 Answers
SOURCE: have just bought a cafe roma de luxe cofe machine
Here's an online version of the cafe roma coffee machine. The owner's manuals this company provide are known to be very skimpy in the info they provide, so don't expect much
Hope you find this very helpful and best regards!
http://www.ariete.net/libretti_pdf/mod1315.pdf
Posted on Aug 07, 2009
  • 7 Answers
SOURCE: Astra Mega IIC startup issues
Go ahead and keep the sensor probe connected. Open up the steam wands before turning the machine on the let the air bleed off as it fills. The element should not turn on if the water level is too low and the circuit is working properly. As for the groups pumping water, try hitting the Brew Stop buttons. If that doesn't work, something may be wired wrong, or your group solenoids may be stuck.
Posted on Aug 29, 2009
Error code 5 on Krups ea8080
During the first few seconds of pump running there is zero water flow. Either there really is no flow at all OR the flow meter is not detecting flow for some reason.
Oct 19, 2014 | Krups Cafe Express FMA110 Coffee Maker
HEATING ELEMENTS
The heating elements are inside on the top and bottom
Jun 08, 2013 | Bella Cucina 13049 1500 Watts Toaster Oven...
Selection Buttons on GE Cafe Dishwasher
see this causes and fix it. God bless you
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Oct 02, 2012 | Dishwashers
I am looking for a hot water element for an Ariete Coffee machine cafe roma?
go to http://www.arietegroup.com/en/assistance on the internet and type in your request with the exact model name.
Sep 21, 2012 | Ariete Coffee Makers & Espresso Machines
My 3 year old Ariete Cafe Prestige has stopped heating water. The indicator light for the heater is also off. The pump and its indicator light still work. The problem occurred without warning, as the...
probably the resistence burned out or the wire connector is broken, contact a service...repairs are sometimes more expensive than buy a new coffemaker....think about that
Mar 08, 2011 | Ariete Cafe Retro Espresso Machine
Hi I have model No WF 740 1400 spin! However programme L is filling up with water, appears to be washing as normal until it reaches final 7 minutes, then machine becomes laboured and will not spin! the...
it appears that the pump is not removing the water that is spun out  if there is a belt on the pump then it may have fallen off or need replacing   if it is intact then the pump either failed or there is a blockage in the line
Nov 08, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My water doesn't get hot
you either have a bad thermostat, a wire off, or bad heating element. the heating element will burn out quickly if the pot is plugged in with no water, or if left unused for long periods of time. the water evaporates, and the element burns out. best thing is to remove top, and take a look.
Sep 26, 2009 | Bloomfield 8572 Coffee Maker
Hamilton Beach Brew Station
My brewStation 47214 stopped pumping water today, even though the warming element continued to get hot. A half dozen screws later I discovered a second heating element inside the coffee maker. The internal element is what heats the water and forces it into the basket. This element was burned out, religating my brewstation to the garbage. Probably last 3+ years.
Jul 11, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Cafe Nero turns on, but will not make coffee
I understand this unit has a fuse inside that blows out. I cannot confirm this as I need to find a special screwdriver to open it. I'll post back my results if possible.
Jul 05, 2007 | DeLonghi Caffe Nero BCO264 Espresso &...
Candy cd623 uk dishwasher water not heating up
not familiar with model. element can be inside cabinet in which case it will be obvious or may be in a cylinder heater mounted in the base. suspect stats as well or possibly the module
Mar 19, 2007 | Candy 24 in. CD622 Free-standing...
Coffee Makers & Espresso Machines Logo
242 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
