Connecting my laptop to my Cello mtv21d flat screen LCD TV
do you know how to connect a laptop up to a TV. my TV has a VGA port and it says on the box that you can use it as a screen to hook up to a PC but im struggling to get it to work and i cant find the user manual.
any suggestions??
  • Anonymous Mar 19, 2014
    wireless laptop to flat screen tv viewing
    with no wireless rokue box
  • 504 Answers
Depending on the laptop, the usual way to do this is to connect the VGA cable to the laptop and the TV. Select the VGA input from the television remote and press FN+F4 to switch the image to the television set.
Posted on Mar 29, 2008
SOURCE:
How can i connect my dell inspiron 640m laptop to my sony bravia lcd tv?
Your tv should have vga port. if not you can buy a vga to hdmi adapter
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Feb 19, 2012 | Sony Televison & Video
How do i connect compaq presario x1000 to external monitor
Hi Judy,
The Compaq Presario x1000 notebook offers connections for external displays at the rear below the screen hinge as show in the picture below:
Identifying the back from left to right: Ventilation slots, External VGA Port, S-Video Port, USB Port, USB Port, RJ-45 Network Jack, RJ-11 Telephone Jack, Parallel Printer Port, USB Port and 1394 (a.k.a. "Firewire") Port.
You can connect a VGA monitor to the VGA port (blue colored jack) very easily. Any analog VGA monitor should readily connect to it. Additionally, the x1000 can output its display to TV or other monitor that accepts "S-Video" signals. An "S-Video" cable will be needed to connect between the "S-Video" jacks on the notebook (next to the VGA Port) and one on the TV. It is important to note that not all TVs support both or either "S-Video" or VGA inputs. When ever the there is a choice of using S-Video or VGA on a TV or monitor, the VGA will provide the best looking picture, and should be used.
I hope this helps and good luck! Please rate my reply - thanks.
Oct 03, 2011 | Compaq Presario X1000 Notebook
Cannot get computer video to the tv
Hi
If you want to connect your TV with laptop then you just check your TV or LCD have a VGA port. if there then take one VGA cable and connect your TV(LCD) and other end connect your Laptop VGA port automatically you get the video in your TV(LCD)
If my solution fix your problem give the Thumbs
Jun 14, 2011 | Dell Vostro 2510 Notebook
How to connect laptop to my coby tv?
Check if you have an HDMI or VGA/DVI port in your LCD TV and LAPTOP. Once you have those ports you can just buy an HDMI cable or VGA/DVI cable to plug it to your laptop.
Jan 31, 2011 | Coby TFTV2225 22 in LCD TV
Is it possible to connect the emachines E525 with an LG LCD tv if so how?
It is possible to connect your laptop to any LCD TV. For which you need to locate the external VGA port on your laptop. As your Laptop doesn't have S-Video port you would have to deal with the VGA port.
There are several adapters available in the market which can solve your problem:VGA to RCA orVGA to S-Video orDual VGA cable
Your LCD TV should be equipped with all the ports mentioned above that are:RCA (AV)S-VideoVGA In
But as I don't know the model Number of your TV I don't know whether your TV has S-Video or VGA ports but the RCA (AV) are the most common ones which I am pretty sure you would have.
Here are some pics of the cables.
^Dual VGA cable
^VGA to RCA or S-Video
You can buy these cables from the market and easily connect your system to the TV.
If you need further help, please feel free to contact me.
Aug 08, 2010 | Computers & Internet
Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
Feb 14, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Jan 31, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
LCD TV and VGA output
The resolution and refresh rates have to match exactly to the TV for it to work correctly with the computer.
The newer computers are using much faster refresh rates by default. Their default resolution is also different.
Consult the manual for the TV and see if the computer's external monitor output can be set to match to what the TV exactly requires. Both the refresh rate and resolution are critical.
Jerry G.
Apr 20, 2008 | Televison & Video
Connecting to a P.C
It it really has 11 pins I'm not sure but then my guess is that this is the service port connector which normally should have 9 pins. A vga connector has 15 pins and LG (as far as I know) uses standard 9 pin serial ports for service and plain old dvi or vga ports for connecting a computer.
Please visit Hardware Book for more info on connectors and cables.
Jan 15, 2008 | LG RZ-20LA70 20 in. LCD Television
Connect VGN-S460 Laptop Directly to a TV
VGA is not supported by most tv sets...If your tv is the standard flat-screen use S-video..And if its LCD or HDTV try DVI...Let me know if it worked..
Oct 27, 2007 | Sony VAIO VGN-S460 Notebook
Televison & Video Logo
358 people viewed this question
Top Televison & Video Experts
Ekse
