Question about IBM Lenovo ThinkPad T61 Notebook
How do I put my spacebar back on?
How do I put my space bar back on my Lenovo Y530?
  • 3 Answers
Firstly ensure you have all the parts - there may be one or two sets of small plastic hinged brackets. These go on first to the laptop - then the key should snap in.
Be careful to check the brackets are not broken or worn first!
Posted on May 13, 2010
How to replace space bar on laptop
Some spacebars have a long wire on the bottom that snaps into two protruding notches on keyboard base plate.
Jul 21, 2014 | Lenovo Computers & Internet
Wired and onscreen keyboard space bar doesnt work
Keyboards are cheap. If you need to use this one then you will need to carefully pop the spacebar key out, turn the keyboard upside down and give it a good shake. You will see a ton of junk fall out ;)
Mar 08, 2014 | Computers & Internet
My dog knocked over my Compaq keyboard. Now the divided spacebar is opposite what it should be. Instead of spacing on the right spacebar I have to hit the left side. How do I fix this?
Pull the space bar off by using your fingers. Underneath, you'll find a metal rod. Take note on which way it is facing, and how it fits. Make sure nothing in broken under the space bar, then put the space bar back on making sure it hooks in correctly.
Mar 08, 2011 | Compaq Keyboard
I need to remove to top panel (with Keyboard) of the Lenovo Ideapad Y530 in order to access and replace the Monitor hinge. I removed everything else the top panel seems that it is free except for one screw...
Hi. I think the best thing to do here is to contact Lenovo tech support regarding this matter because you will not find any manuals online on how to disassemble this Y530 but I thing Lenovo tech has a manuals on how to disassemble this machine. I am a Lenovo tech that's why i know this information, try calling them and they would best help you on your problem, also double check if you're still under warranty. If I could just have a copy of that manual then I would gladly send it to you or teach you onthat issue. This there tech support hotline 877-453-6686. Hope This Helps..
Jun 08, 2010 | Lenovo IdeaPad Y530 PC Notebook
THE SPACE BAR ON MY LENOVA y530 CAME OFF- HOW DO i GET IT BACK ON?
You could try pressing the space bar key back into position since it has a small clip on the same part where the space bar key was held in position and incase if the key still pops off you would need to contact technical support to get the keyboard replaced.
Jun 01, 2010 | IBM Lenovo ThinkPad T61 Notebook
Space bar is sticky du to liquid accident ( soft
Get a Electrical/Electronic solvent spray from RS, give it a good spray (with Power Off!) and operate it lots of times. The spray will evaporate naturally and may remove the gunk! Ian.
Sep 17, 2009 | Acer TravelMate 5530-5207 Notebook
How do I reseat the space bar on the mx 3200 . the logitech keyboard accummulates cat hair behind the keys, easily removed. But the space bar has a spring and white gunk and does not reseat easily. Mine...
Use a credit card or plastic Id, insert it and bend it gently. If it fails, you can use 2 cards, one on each side of the spacebar.
If after all you are unable to remove the spacebar, try removing the keys around it, just remember their distribution.
Beware, the spacebar is a little more complicated to put back in place compared to the other keys, as you said, there is a spring.
Sep 04, 2009 | Computers & Internet
Spacebar on IBM Lenovo ThinkPad X61 came off.
I took mine off to clean under it and had a similar problem. After a bit of struggling I figured it out. I will try to explain it as best as I can, but forgive the non-technical language:
There are two gray plastic pieces on the space bar that must be that must be latched to the two white plastic pieces on the computer. The gray pieces pop off the space bar easily. Take them and put them on the white pieces on the computer so that the white arms lay across (and snap into) the top and bottom of the gray piece. The middle of the gray piece will sit in between the two arms that are not "holding" the gray piece. Then take the space bar and put the metal part into the hole on one side (outside of the plastic pieces) and then push it over so you can put the opposite metal part into the other side. Then push the space bar straight down and it will snap into place.
Apr 12, 2009 | IBM Lenovo ThinkPad T61 Notebook
Acer laptop spacebar fell off
The space bar key is connected tothe keyboard a little bit differently then any other key.
There is a metal retainer connectedto the space bar key (on some keyboard models). Separate the retainer from thespace bar key with a flathead screwdriver.
Install the retainer back inplace as it shown on the picture. You have to engage the retainer with thesmall hooks on the keyboard.
Put the space bar key back inplace and gently press on it with fingers until it snaps back in place.
That’s it. The space bar key isinstalled back in place and should work as before. If you still cannot fix yourkeyboard, then you’ll have to find a new oneand replace it.
Pleas rate my solution on fixya if you are done.
Dec 28, 2008 | Acer Aspire 1360 Notebook
Mx3200 First the spacebar won't work andthenitworkstoowell.
did you check to make sure that the springs and bar under the spacebar are seated correclty?
Sep 30, 2008 | Logitech 967437-0403 Keyboard
Open Questions:
See all IBM Lenovo ThinkPad T61 Notebook Questions
IBM Lenovo ThinkPad T61 Notebook Logo
508 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
