Question about Dell 922 All-In-One InkJet Printer
My printer prints no color and streaks - Dell 922 All-In-One InkJet Printer
  • 68nerd May 13, 2010
    Have you ensured that you have full ink carts and that you have performed system maintenance throught your printer's software?
    President:
  • 1,335 Answers
This sounds like the nozzles are clogged. The chances are that you are using aftermarket or refilled cartridges and the ink is not up to manufacturer specifications. The easiest solutiion is to insert new OEM cartridges, run the cleaning utility at least 3x, the alignmnet process and a test page. If the nozzles were clogged they should be cleared by this procedure.
Be careful with aftermarket inks. If you can, take the cartridges back to the vendor and get replacements or a refund.
Let me know if this procedure clears the problem.
Posted on May 13, 2010
Streaks or lines
Vertical streaks:
Check,which color/s streaks are appearing on print out,remove that cartridge/s check on drum surface for streaks.. if found replace that cartridge/s..check.
Horizontal streaks:
This problem appears when the cartridge/s image drum not rotating properly. Resit the cartridges properly, print 20nos of blank pages, then check.... replace the cartridge..
Dec 29, 2012 | HP Color LaserJet 2600n Printer
Streaks on color only
your printer has two ink cartriges one with black ink and the other for color when they get ready to run out they will leave streaks
Dec 07, 2012 | Office Equipment & Supplies
My Ricoh 3500 color printer no longer is printing in color--just greys. It does not seem to be a problem with the color cartridges. Also, it streaks from left to right across a page from light to lighter...
The streaking could be anything internal to the printer, such as the transfer belt or a drum unit. As for the lack of color, that sounds like it is a setting in the print driver that got changed from printing in color to printing in monochrome or grayscale. Look through your print driver settings to see if you can locate this setting and change it back to color. Also, once you print in color again you may notice that the streaking is a specific color, which will help to troubleshoot that issue.
Jul 02, 2010 | Ricoh Aficio CL3500N Laser Printer
Red is printing very light and streaking. The other colors print
1.clean the printer head using printer service utility
2.Buy a new catridge and fix it
note: if you are not use the printer the ink will be dry.so it cant able to print
Feb 12, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
HP L7700 officejet printer leaves streaks on black ink lines only. Have cleaned heads repeatedly, changed black and color cartridges - nothing works.
Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Nov 28, 2009 | HP Office Equipment & Supplies
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Streaks in prints
What I would do is remove all cartridges, wipe the belt w/clean cloth use an air can to clean the machine, check the drum on each cartridge see if there is something, it could be there was a change in Voltage and it burnt the drums. change 1 more toner cartridge to see if that color goes away, if it does then you will know if the drums are the problems.
I've had a problem w gen toners doing the exact same thing, so I had to OEM and it went away. Good luck>
Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
Color Streaks down length of page
My rep advised that if this problem is occuring when using the feeder, the small glass strip to the left of the glass can have some sort of either high lighter or white out stuck to it. He suggests cleaning this with some alcohol.
Jan 09, 2008 | Ricoh Aficio CL2000N Laser Printer
Gestetner DSc332 streaks and smears when printing in color
Check to see if you have a paper jammed near the drum near the color ink cartridge interface.
Nov 28, 2007 | Gestetner DSc332 Copier
Dell 922 All-In-One InkJet Printer Logo
59 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
