Question about Brother FAX-575 Plain Paper Thermal
HOW DO I CHANGE THE RIBBON?
HOW DO I CHANGE THE RIBBON ON THE FAX MACHINE FAX 575? ON THE RIGHT SIDE THERE IS A BUTTON AND I WHEN I PULL UP THE COVER OPENS PARTIALLY BUT NOT ALL THE WAY.THE PAPER HOLDER IS IN THE WAY.HOW DO I REMOVE IT TO OPEN ALL THE WAY THE COVER???
  • 240 Answers
You can use the below link that will take you to the brother FAQ website. Follow the FAQ to change the ribbon.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000500/000045/faq000545_001.html?reg=us&c=ca&lang=en&prod=fax575_us&Cat=7
Thanks,
Pat
Posted on May 13, 2010
Reset the ribbon on my 575 fax
No need for that. What is on the display ?
Oct 18, 2014 | Brother FAX-575 Fax Machine
Ribbon is empty in fax machine 575 what to do
Check if the thermal ribbon (ink) is finished . Open up the front panel and you will see the black film roll .
Sep 11, 2014 | Brother FAX-575 Plain Paper Thermal
Brother fax model 575 in Manual recieve Mode,won't change
Telephone Answering Device (TAD). This is the mode you use when you have answering machine active on your phone line.
Mar 27, 2009 | Brother FAX-575 Plain Paper Thermal
Can I reset the used ribbon to recieve a fax ready to print
You can rewind the ribbon. But the areas that has ben transferred from past fax's will be blank.
Jan 28, 2009 | Brother FAX-575 Plain Paper Thermal
Useing PC 102rf brothe ribbon film in a brother fax 575
I was told it no can do, or be done- whatever! I am not finished yet, that is a challenge!!
Jan 15, 2009 | Office Equipment & Supplies
Xerox WorkCentre Pro 575 error message
Could be the tab that actuates the top cover switch is broken off.
The process unit is your drum,toner, and developer unit. It sits right under the top cover. Big black removeable cartridge.
Nov 03, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Ribbon empty
Winding technique:
To wind a new ribbon, take the cartridge housing apart and remove the old ribbon and two cardboard cores. The new ribbon is fitted with the larger roll (the ink ribbon supply spool) at the rear side of the cartridge (as the housing is viewed when it is normally installed into the machine). The ribbon winds over the topside of the rear spool (the supply side) and feeds into the underside of the front spool (the take-up side). Make sure the ribbon is wound neatly, evenly and is tight. If the ink film has become detached or is too loose on the front spool it will not wind on and cause a machine error. If required, use a small amount of sticky tape to secure the ink film to the front cardboard spool and then neatly wind it on to the take-up spool a minimum of five turns, making sure the film does not overhang at the edges. Now reassemble the housing and refit into the machine.
If it’s still not fixed:
If problems persist after fitting a new ribbon, try replacing the entire ink ribbon unit (cartridge housing + a new ink ribbon) using a new, genuine Brother unit before requesting a service; this will be less expensive as the actual housing may have been damaged and is causing the problem and this unit is readily available as a consumable item through sales outlets. If the machine still has problems, book your machine in to be repaired with an authorised Brother Service Centre.
Feb 17, 2008 | Brother FAX-575 Plain Paper Thermal
Brother FAX-575 Plain Paper Thermal Logo
785 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
