Question about Cameras
I am trying to open a video with the extension WLMP
I am trying to open a video wth the extension WLMP and don't know what program I must run to see it, if any. The video is about a Theatrical play made by a granddaughter of mine, probably taken by a homevideo camera. Something which I find surprising is that the video, which supposedly runs for quite a while, weighs ony 2.150 KB, extremely small.
  • Bill Aug 18, 2010
    Are you running XP, Vista or 7?
    Brigadier General:
  • 4,090 Answers
This is a windows movie maker file.
Thedre is a download option and a lot of info here
http://www.microsoft.com/windowsxp/using/moviemaker/default.mspx
Please rate my help++++Thanks for using fixya
Posted on May 13, 2010
  • Bill Aug 18, 2010
    actually it is a Windows Live movie maker project. You were thinking about the XP one.
PROBLEM OPENING MS WORD: This might be a backwards
Uncle, you found a great workaround to fix this problem. If you would like a more permement solution, try the one below. I found this answer here: http://windowssecrets.com/forums/showthread.php/136470-Word-2007-ERROR-quot-There-was-a-problem-sending-the-command-to-the-program-quot
It sounds as though the DDE setting for the .doc and/or .docx extensions are broken.
You might want to "re-register" Word's file extensions, which simply involves using the /r startup switch. This article provides more than anyone really needs to know: How to use startup command line switches to start Word 2010, Word 2007, Word 2003, Word 2002, and Word 2000. In brief:
Close Word
Start > Run > winword.exe /r {ENTER}
Does that fix it?
If you want to try manual surgery and are running Windows XP, you can view/edit the setting from Windows Explorer or My Computer: Tools > Folder Options > File Types tab > [appropriate extension] > select open then edit or modify. If you uncheck the "Use DDE" box and save, then the registry should be updated.
Oct 04, 2013 | Microsoft Word for PC
Can't find an app file to start a program. don't know what the extensions are or what a ubuntu equivalent of an .exe file is
Ubuntu doesn't use an extension for the executable binary. The command to run a program is ./<programname> or sudo ./<programname> So make a launcher with that command pointing to the dir with the program or a shell script with the command in it.
Feb 04, 2012 | Computers & Internet
I have made a disk image, with file extension .wmf, but don't know how to open it and get all the disk data back ??
wrong file extension. if you made a image of the OS it should have been a .iso this is burnable and easy to open with winrar or a dvd burner program for image burning.
The ISO file type is primarily associated with 'ISO-9660 CD Disc Image'. A literal dump of the data on the CD, byte-for-byte. The data is stored in the ISO-9660 format. IsoBuster can interpret these files directly.
The .wmf file type is primarily associated with 'Windows Metafile' by Microsoft Corporation. Microsoft graphic format. Xara X is a good program to edit this file type if you don't have Microsoft tools. There are several versions of a Metafile; each having a different header structure.
Jan 25, 2012 | Microsoft Windows XP Professional...
I did something to my pc now all my programs have the extension .ink and i cant run anything or open anything what can i do?
The .ink files are shortcuts. If they have no icon, or the same icon then you deleted the programs. Try reinstalling them. If not, don't worry, just launch you application by double clicking the .ink files. If it doesn't work no worries, that's not a biggie and can be easily fixed in a couple of minutes. There are a couple of ways to do it, read both:
Option 1:
- Go to Start -> "Control Panel" -> Click on Porgrams
- Click on "Default Programs"
- Click on "Associate a file type or protocol with a program." to open the "Set Associations" menu.
- Scroll through the list of extensions to locate the .lnk file extension. The listing will show the description and the current default program associated with it.
- Click on the extension (to select it) and then click on "Change Program."
- Select the program you would like to open *.lnk file types.
- Click on OK.
Option 2 (If Option1 fails):
Simply download following file, unzip it, and run it. It will make necessary changes to the registry. Restart the computer and it should be fine.
http://www.winhelponline.com/fileasso/lnkfix_vista.zip
Jun 17, 2011 | Microsoft Computers & Internet
Im trying to watch a clip in GR.wlmp but it wont open, i have viao laptop windows vista
Actually I'm unable to understand which software utility you are working on. What actually is meant by GR? Please clarify.
Thanks,
Mrityunjay.
Apr 03, 2011 | Microsoft Computers & Internet
I am having problem with one of my application in my pc. When I open it it says "browse for the application"
It sounds like you have a dead shortcut. Try using the original cd to repair the program. If you are running Windows Vista or 7, then try searching for the application using the search bar in the start menu to open it.
Mar 12, 2011 | Computers & Internet
I just downloaded this Vista theme for my Hp but it's saying there's no available application for it.
You must have downloaded a file file from the internet that is being called "Vista Theme". If this is true that its a file every file has an extension and requires proper application to run. There are many different types of files and this difference is marked by file extensions. Different files are different from each other because they have different extensions.
To run a file you need to know the file extension and have a related software to run it on your computer. How to find the file extension. Just right click the file and take the properties of it a window will open and show you the the file extension and if your lucky it will show an installed program on your PC that can run the file.
If you do not find a software indicated there you have to go to an internet search engine like Google.com or Yahoo.com. Type the file extension of the Vista theme there and augment with these key words FILE EXTENSION.
You will have access to the information that will tell you which program or application can run that particular file extension. Obtain or download that program or Application. Run it and enjoy!
Good Luck!
Jul 27, 2010 | Microsoft Windows Vista Home Basic Edition...
Problem opening some attachments
You need to tell Windows what program you want to use when opening the file since you don't have any program installed that knows this file.
Do you know what kind of file it is? If not, you need to find this out.
Usually you get powerpoint or pdf files in your mail. To read these you need Adobe Acrobat Reader or Microsoft Powerpoint Viewer.
Short, You need to install a program that can handle the files you get in your mail. What program depends on the file.
To know what kind of file it is you have to se what "extension" it have (the three letters after the dot). Normaly you don't see this, but to be able to see it open Explorer and do go through the following:
  1. select Start -> Settings -> Control Panels -> Folder Options
  2. select the View tab
  3. check "show hidden files and folders"
  4. Uncheck "hide file extensions for known file types"
  5. Click OK to finish
Now, save the file on your desk and check the last letters of the file. If it ends with .pdg it's a pdf-file, if it ends with ppt it's a power point file.
If it ends with something else, it needs a different program. To know which, just ask again :)
Apr 07, 2009 | Microsoft Windows? Vista Home Premium...
JVC 3CCD Cam - Playback issue
Probably you Media Player does not support TOD formate.
It is very recent one so you need to look for new softwear.
The solution is easy
Tod file conversion, download the UNLEAD VIDEO STUDIO11.5 with the update other wise he will not work properly http://www.videohelp.com/tools/Ulead_Videostudio
http://www.ulead.co.uk/vs/features.htm
Run the program(ulead) go to Edit and on the right hand side of the screen you see icon of a folder open that and import your file (tod) when it's imported put it on the time line as well.
Now to converter to any kind of format you wish is very easy.
Open share icon right on the top next to audio icon and go to any format you wish to create.
For me I use adobe premier pro I need 720X576 I do this method.
I open in share folder the ---create video file-after I have lot of choose I select ---DV------after Pal (4:3) and I give name and destination all done.
Note:
Please don’t use DV----Pal (16:9) it will stretch the footage to much
When you import the file tod strait from your JVC will help to keep the same quality of your converted file.
Good Luck
Dec 22, 2008 | JVC 3CCD Digital Media Camera Camcorder
Cameras Logo
311 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
