Question about GE Microwave Ovens
I have a GE Microwave that has the door the glass then the screen. When cooking the food splatters through the screen to the glass and I can't clean the glass. How do I take the screen off and switch it around?
  • darlenekay20 May 17, 2010
    Thanks a bunch I will try it today!
  • 1,284 Answers
Hi, i figured it out, with the help of an exploded-view diagram from GE's website (not the other site mentioned above). You may want to remove the door first. To do that, unscrew the vent grille at the top of the microwave (2 screws) and lift it off. The door then lifts up easily, off its mounting.
The first step in disassembling the door was to pop out the plastic bezel that surrounds the window on the inside of the door. It is held in place by a bunch of hidden catches. On some microwaves one can insert a putty knife into the gap between the frame and the bezel to release the catches, but I don't think that would have worked on my microwave. I broke some of the catches getting it out, but it did go back together fine afterward. Try the putty knife first.
Once you get the bezel off, remove the two screws that hold the door handle on. (My door handle stayed attached--perhaps there is glue as well as screws. This is OK.) With those screws removed, the metal frame of the door (which includes the grille), is held to the plastic outer frame by a bunch of plastic catches. Disengage these with your finger or a screwdriver. I found it helped to wedge a screwdriver between the metal frame and the plastic outer frame, to keep the catches from re-engaging. Once you get the catches released, the metal frame lifts out of the door. The glass is held in slots in the plastic outer frame and can be easily cleaned at this point.
Important addendum: on my microwave, there was supposed to be a plastic film on the inside of the door, to keep food from getting in there in the first place. I don't know if the microwave was built without it by mistake, or if a former owner removed it. If you are going to take your door apart to clean the glass, make sure you order a replacement "door film" to put on the inside of the door when you're done. It's a heavy plastic film with adhesive on one side. You just peel off the backing and stick it on the inside of the door after you're done cleaning. To get the part number, go to the parts search on GE's website and look for your model. Check the list of parts and/or the "exploded view". Once you have the part number, you can order it from GE or copy the part number and get it from any of several parts suppliers online. The latter are slightly cheaper, and many offer very fast delivery.
Take care
Posted on May 17, 2010
  • GE Master
  • 8,220 Answers
You have to have that screen stay put. That keeps the microwaves from escaping. Use a splatter proof microwave cover to cook with.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
  • Dan Webster
    Dan Webster May 17, 2010
    You must replace he door, you cannot remove the screen. It would make it dangerous.
    ADVANTUM MANUAL
  • Dan Webster
    Thanks
I have a GE Profile convection/microwave oven, Model No JVM1790 BKC01. One of the plastic clips that holds the oven rack in place caught fire. Location of clip is top front right hand corner next to the...
Most rack support problems I have seen are from food splatter or grease getting around the support and even seeping behind it. Once it starts burining it must be replaced. It is really important to keep the area around them clean and dry and free from food splatter. A Microwave cannot tell what is on a plate or on the wall or rack support, and every food particle cooks each time the unit is run, until it turns to a carbon deposit and starts to attract the microwave energy and starts to ARC to that point.
Then it burns up the part it is arcing to. Have to replace support and scrub the area and inside of the cavity perfectly clean.
Oct 25, 2017 | GE JVM1790 Convection / Microwave Oven
My microwave has a hole burned through the door.
This can start when food splatters on the inner door, then from that point the microwaves that do the cooking are attacking that splatter eventually burning a hole in the door. Do not use the microwave oven in this condition. You will need to have the door parts that are damaged replaced
May 08, 2010 | Westpoint TV-201 Microwave Oven
Food splatter behind screen on door of microwave
If you take the glass out you have to find a deaker or someone who the tools to check for leaks around the glass.
Mar 17, 2009 | GE JVM1640 Microwave Oven
Cleaning inside of microwave door
THE DOOR ON MY MAYTAG MICROWAVE OVEN HAS A SCREEN OVER IT. I HAVE SOME FOOD SPATTERS THAT PENETRATED THE SCREEN AND I CAN'T CLEAN THE GLASS THAT THE SCREEN PROTECTS. HOW CAN I REMOVE THIS SCREEN TO CLEAN THE GLASS?
Oct 01, 2008 | Maytag MMV1153A Microwave Oven
GLASS ON THE DOOR
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 30, 2008 | Whirlpool MH1150XM Convection/Microwave...
Removed splatter shield
The parts can be ordered from the Panasonic authorized parts rep. You have to contact Panasonic for details.
I strongly recommend to have any work on a microwave oven done professionaly. There are radiation leakage issues if the door is not re-assembled properly. After doing any service the microwave oven must be tested for radiation leaks. I doubt that you have the radiation testing equipment to make sure that there are no leaks.
From US Food and Drug Administration (Microwave Oven Safety)
http://www.fda.gov/cdrh/consumer/microwave.html
Excellent Wikipedia Article About Microwave Ovens
http://en.wikipedia.org/wiki/Microwave_oven
Jerry G.
Jul 26, 2008 | Panasonic NN-S753 Microwave Oven
XL1800 Microwave Problem
A LOUD ticking sound could very well be a High Voltage Arc. This is usually caused by a breakdown of insulation on High Voltage Wires, or components. It can also be arcing between the door frame and the cavity. Usually where the bottom of the cavity floor meets the door frame. Indication of this will be small areas on the door where it looks like the paint has been chipped off, but if you look close you will see it is small burned marks. Another area is the Splatter Shield located inside and at the top. It looks like a Plastic Cover. It is not plastic, but a fiber material. Grease, and food will get trapped on and under this Splatter Shield. Over a period of time the grease and food particles will break down from being cooked over and over again. They will then form Carbon. Which will Arc when Microwaves are present. Remove Push-Pins holding Splatter Shield. Clean by washing with dish detergent . If burned (arc) spots are still present after washing, replace Splatter Shield or arcing will continue. Once Carbon has burned through, it will continue to burn.
Jan 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Dirty Door Glass inside the choke - how do I clean it?
Its very hard to take apart the doors They normally have a lot of screws. May have a plastic snap on cover that's covering them up. Some of them are even sealed and can not be taken apart.
Anytime you work on a door you must check it with a microwave leakage meter. The door has metal gaskets and a screen that blocks the microwaves upsetting them will cause it to leak.
This is not a do it yourself repair.
Dec 24, 2007 | GE JVM1870 Microwave Oven
Microwave Ovens Logo
95 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
