Question about Panasonic CT-2789VYD 27" TV
Noise will randomly cut out
Sound will randomly cut out
My 2006 f150 makes a roaring sound at random times when driving and will not quit until completely stopped then you can feel something disengage.
when the sound starts check the temp gauge and see where it is at
I'm thinking that you have a viscous fan hub and it cuts in when standing at lights or slow traffic or heavy loads at slow speeds
it will keep running until the engine temp comes down or you switch the engine off
or it could be a electrical controlled fan and the noise on shut down is the relay clicking off
May 23, 2016 | Cars & Trucks
I hear a random clicking sound when im on the phone but the person on the other end doesn't hear it
View topic - Loud clicking noise randomly during phone calls - Ooma
www.ooma.com/forums/viewtopic.php?f=4&t=13207
Jan 19, 2012 - The clicking noise can only be heard by myself ... ... Loud clicking noise randomly during phone calls ... I have not tried calling from a landline.
Weird Popping/Clicking Noise during Call ' MacRumors Forums
forums.macrumors.com > ... > iPhone > iPhone
Jul 4, 2010 - I have experienced the same popping and clicking sounds. .... I want tohear if what your phone is doing to see if mine is the same. share.
How can I tell if my Phone is being tapped? - Nathan M. Smith
https://sites.google.com/a/.../howcanitellifmyphoneisbeingtapped
May 4, 2010 - I have heard clicks while talking to some of my friends across the country ... in use and i hear a crackilng sound.. what is going on... im not a criminal....... Even on my cell phone i will hear unidentified beeping and random dial ...
I keep hearing a clicking sound in the background - Tested
Jan 29, 2016 | Lands Phones
Green tint on tv and picture randomly cuts out
Sounds like a Sony, if it uses a lamp the green cast is most likely the optical light engine in the set---major part.
Aug 28, 2012 | Televison & Video
My 2002 chevy malibu's radio seems to be shorting out, the radio will work fine but randomly the sound shuts off the radio still shows the radio station and even says which artist is playing but there...
I'd suggest using the balance and fade controls to cut out each speaker one by one. to possibly determine if you have shorted speaker or speaker wiring. As far as the turn signal clicking noise, the hazard switch is the actual flasher unit for the turn signals, and could be the culprit, but the most likely cause is the turn signal switch itself. It is usually caused by corrosion across the contacts, which can be cleaned out fairly easily, but more typically, the switch is just replaced
Jun 16, 2011 | 2002 Chevrolet Malibu
My dell inspiron mini 10 is making a random static noise
Muting does not mean turning off the speaker which means there can be occasionel static.
It occurs more if the is a magnet near!!
Dec 28, 2009 | Dell Inspiron Mini 10 Notebook
I'm having a noise by the passenger side. it
sounds like a typical whel bearing failure noise
Nov 16, 2009 | Porsche Cayenne Cars & Trucks
Sound cuts out.
Bad solder joint. Dirty contacts (servisol switch cleaner) or a broken switch. I would have thought!
Jun 14, 2009 | Audio Players & Recorders
Panasonic CT-2789VYD 27" TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
