Pluging in a turntable
I have sherwood rec. model RV-5030R . I am looking at a turn table ( ion ittusbo5) they have warning about pluging in rca cables that are line level cables I would like to know if i can plug them into my phone input on my receiver.
my email is hens1@localnet.com if you can help thank you
Roger Henstorf
  • mrwood Mar 30, 2008
    correction on spelling i meant phono jack. I wanted to know could i plug this into the aux/ or tape jack would i have the same problem with impedence because there is a pre amp in the turn table
    Roger
  • 19,396 Answers
It is not just the cable, it is the signal out from turntable that is dangerous from your phone. If you connect the turntable straight to your phone using the turntaple regular audio output, you have a good chance to blow your phone, because of the phone input impedence.
Your turntable should have an headphones jack plug output. You can build a cable to connect from turntable headphones out to your phone. This should be quite safe.
An alternative is to pass turntable signal through a computer and connecting the computer output to your phone.
Regards
Posted on Mar 30, 2008
  • Ginko
    Ginko Mar 31, 2008
    Use your phone headphones cable if you can. For example Sony ericcson have a phone jack adapter , ending with a female, if your phone do have such a cable then use that one, otherwise cannibalize a pair of headphones for your phone and build the cable. The preamped signal from your headphones jack should not be dangerous, his maximum power is far less that any amplified signal coming from the finals .
  • 13,433 Answers
I dont understand why you would want to connect a turntable into your phone. Can you explain?
What would it cost to purchase a styli/needle for Sherwood DEK7-U?
All you need to do is look at the cartridge and find the make and model number of it. Put that into google search and the information on the stylus should come up.
Jul 03, 2014 | Audio Players & Recorders
I can not hear what is being recorded to my pc from my ion turn table but I can hear the playback after
Probably something to do with the control panel of your computer sound system. You might have got one of the controls turned down or switched off.
Sep 10, 2013 | ION Audio iTTUSB Turntable
Sherwood rv 5030r
Sounds like it is going into protect. This is usually caused by a problem in the amplifier section. I would start by making sure none of the output transistors are shorted.
Jul 08, 2013 | Audio Players & Recorders
Sherwood 5 Disc Player CDC 5030R Error Message Discs will not play Should I just pitch it or is it something that can be fixed easily? Thanks
I have an Sherwood Model CDC 5030R Multiple Compact Disc player the is showing a disc error? The disc sat in a garage for quite a period of time so the may be a lot of dust inside the unit?
May 28, 2011 | Audio Players & Recorders
Distorted recording and loud
If you're using the RCA cables, how is the switch set on the TT?
From the manual....
2. RCA Audio Output Cables: These cables should be plugged into a CD or Auxiliary input on your computer. IMPORTANT:
There is a switch on the bottom panel, next to the RCA cables that selects between PHONO/LINE. Use PHONO level for
plugging into a turntable input on a home stereo. Use the LINE level for plugging into CD/AUX/TAPE inputs. WARNING: You
may damage your receiver if you plug in a LINE level into a PHONO input.
Mar 29, 2010 | ION Audio iTTUSB Turntable
Sherwood model RV 5050r - tuner is not holding radio frequencys in memory when the main switch is turned OFF and ON again. Is there a battery that needs replacing or a chip?
Try looking for one of these Memory Retention Capacitors, they cause a lot of trouble like that. It will be in the tuner section somewhere if it uses one. It could look a bit different to this one, so bare that in mind.
Mar 06, 2010 | Sherwood RV-5050R Receiver
ION TTUSB10 turntable plugged into Toshiba laptop,
Maybe the output is not good enough for line in on laptop try mic in, then double click the sound icon down bottom right where time is, goto options, properties, then recording inside of recording make sure all boxes are ticked so you have all options like mic wave stereo mix line and so on, click ok, now make sure what ever you have the turn tables pluged into is selected as your recording device and not muted try again, once this is all ok ., it should work. hope this helps. also make sure your software you use to record is also set up same. take care
Dec 03, 2009 | ION Audio TTUSB10 Turntable
Sherwood RX 4105 no input for a turn table
Check for a line level switch on the turn table, it may be under the turn table itself lift the rubber mat and spin the table by hand, it may not have one or it could be on the back.
You can buy a phono amp that will boost the phono signal. Check at Radio Shack or google it.
Jan 31, 2009 | Sherwood RX-4105 Receiver
I connected to the computer I turn on the turn table but no sound
http://www.ionaudio.com/contentmgr/showdetails.php/id/1089/tt/4
I found a link for the table , but they want an email address , to download the manual . good luck
Dec 25, 2008 | ION Audio iTTUSB Turntable
504 people viewed this question
 Grubhead
Grubhead
