Question about Canon Image Runner 3320I Copier
Cannon imagerunner 3320i has excess toner coming out of toner cartidge area. I can clean it and its fine for two copies, but after that... all copies start turning black.
    New Friend:
  • 61 Answers
You need a black image unit , I can give you a price on one and walk you thru replacement. My e-mail is geminibusiness@att.net
Posted on May 15, 2010
How do I prevent excess toner from spilling out of cartridge and affecting copies?
If you 'replaced' or refitted the original cartridge, then I would suggest that the toner cartridge has failed. If this is the case, please try a new one.
If the original has not done a fair (check manufacturers specification) number of prints, you may be able to ask for a replacement.
If this was a new cartridge, and printer uses separate drums and toner cartridges. Then it could be a faulty drum. Above replacement path could be tried.
Aug 01, 2015 | Sharp AL-1631 Laser Toner Cartridges
Tonner low message coming still when the tonner is full
If the toner cartidge had been refilled, then either a chip had not been replaced correctly or a "low toner bar" inside wasn't cleaned properly while the cartridge was being rebuilt. If the cartridge was OEM new, it probably had a faulty or missing chip.
Nov 28, 2013 | Cannon Office Equipment & Supplies
There is a black dotted line whenever I make copies on the cannon imagerunner 400s
It's either a speck on the scanner glass for the document feeder, or a smear of toner on one of the rollers. Check the skinny band of glass inside the document feeder for specks and clean it with a lint-free soft cloth and a little rubbing alcohol or a very little bit of water.
May 30, 2012 | Canon imageRUNNER 400S Copier
Cannon IR 33201 error e000019-0000
this is error for waste toner, and the waste toner needs to be cleaned.
On left sideway of copier, in lower left corner you will see the plastic cover with one screw.
Remove the plastic cover and remove waste toner box by pulling toward you. Empty it and clean the neck of the bottle. Put it back in and restart copier,
Hope that helps!
Aug 18, 2011 | Canon Image Runner 3320I Copier
How do i change the waste toner container on a canon imagerunner 3320i?
Hello tandi,
I can help you. First, lets establish a point of reference which will be you satnding at the copier as if you were about to make a copy. The waste toner bottle is located on the left side,lower rear corner. If you have a stapler/sorter you will need to release it from the copier and slide it away from the copier. Notice the small cover that is @ the lower left corner of the copier. Remove the single screw that holds the cover and then remove the cover. The waste toner bottle is now exposed. It even has a hande so that you may slide the bottel STRAIGHT OUT not up or down. Carefully empty the bottle into a trash bag while keeping in mind that holding it low and pouring it slow will avoid a Hiroshima style mess. Once the bottle is empty, look at the "neck" of the bottle. There are "clear windows" at the top of the neck of the bottle. But right now they are not "clear" since they are covered in toner. That's how the copier determines if the bottle is full or not. It shines a beam through the lenses and as long as the beam is not broken the copier is happy.When enough toner rises in the bottle to break the beam the copier "assumes" the bottle is full. So now that you have emptied the bottle you need to use a Q-tip or such to clean your windows ! :-).Re install everything. Turn the "TRUE" main power switch off, or unplug, and then power back up. Happy copying. Please let "fixya" know if I helped. SPINAL
Mar 31, 2011 | Canon Image Runner 3320I Copier
E000019-0000 in cannon 3300 xerox
E000019-0000 indicates that the Waste Toner container is full.
Feb 26, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Do i need to remove all the toner cartidges out before i clean the window
Unsure what window you are asking about here that would involve the toner. If you are asking about the glass for the copy area then no, the toner is not near that glass so unless you are planning on pouring gallons of cleaner on it you should be safe.
Jul 16, 2009 | Epson ACULASER CX11NF All-In-One Printer
"shadow" copies
is the shadow off set from the original image?
if so it could be the cleaning unit for the fuser (heater) may have to be changed. If the cleaner does not clean the fuser rollers a residual image will be passed onto the page.
Apr 15, 2009 | Sharp AR-M237 Copier
Photo copy comes out like tire marks are on it
Power the unit down. Let it cool for at least an hour. Remove toner carts, using a soft cloth and q-tip clean toner surfaces. follow warning stickers on unit. Examine cart/drum rollers for wear and baked on toner. Reassemble and clean platen glass and scan bed area with water or non-alcohol cleaner and soft cloth.
Jan 26, 2009 | Canon imageRUNNER 210S Copier
Light and streaky copies, and a powder residue.
make sure that the machine is level first. then you will have to change both the drum unit and toner cart with new units not just change the drum in the drum unit.
Nov 25, 2008 | Sharp AL-1641CS Laser Digital Copier
153 people viewed this question
old marine
old marine
