Our tv was dropped on the concrete. Now it has pits on the screen. TV works great. Any suggestions on how to help cover the pits.
  • 8,617 Answers
No way to fix the screen. You will need a new crt if its a directview TV. If its a projection you will need a new screen assembly.
Posted on Mar 29, 2008
SOURCE:
What is the correct ratio for mixing concrete?
generally about 2:3 water to cement. it should say on the bag, if it is too watery add more powder, if it is too thick add more water
Jan 15, 2013 | Building Materials
My husband scratched our Sony FD TRinitron screen when dropped it on our concret step corner bringing into our home. How can we fix it.
This is a CRT, right? If the screen is damaged in any way, I'm pretty sure your Outta Luck. However, I'm not familiar with this particular model. There might be a protective cover over the screen, though I doubt it. It's not a solution, but it will save you some time.
Oct 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Few water drops in the TV - 1997 Magnavox
check the vertical section,look for burn resistor or try replacing the vertical ic.
Aug 06, 2009 | Quasar SP-3235 32" TV
Salt got on small piece of my concrete and now it is breaking down. i am getting all these pitted holes about the size of a baseball. it actually looks like the concrete is peeling.
Salt is evil when it omes to unsealed concrete. Hose down the area and remove any remaining salt. Then go to a cement block/brick yard and speak with the clerk about your problem. There are several very excellent concrete patches that will do the repair. Finally, I would seal or reseal the entire concrete pad.
please mark my answer as a fixya!
Mar 11, 2009 | Calculated Industries ConcreteCalc Pro...
Plays for 10-15 min.then pic.goes black,sounds stays on.
Resolder FBT pinns flyback transfomer on deflection board also CK capacitors 3 of them cp114,120,150 if anmy of them is puffewd up on top it is bad.cp150 2200uf 16v other 2 are 220uf 35v replace all 3.
Jan 28, 2009 | RCA R52WH73 Projection Television
TV screen broken
Yes, but you may have to consider gewtting a new unit. since the cost of repair may not justify the cost of new TV set.
Jul 22, 2008 | Televison & Video
Retrace lines and poor convergence
you have bad solder connections on the convergance board solder then and get back to me k
Oct 30, 2007 | JVC AV-48WP74 48" Rear Projection...
TV Powers off after 30-45 mins
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 24, 2007 | Philips 26MF231D 26 in. LCD Television
Black square covering up most of the screen
Try goeing into your Menu and see if you have the closed Caption on that will produce a black box on the screen if you have the owners manual look in there,if you don't have it you can go on line and download it from the manufactures website under Downloads Good luck Walter Grzybowski
Sep 17, 2006 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Ekse
