Question about John Deere Garden
I am fabricating a 3 point rototiller and i am using a john deere rototiller as the main platform. I need to know the gear ratio in the gear cluster so that i can figure out the proper size drive pulley compared to my tractors PTO speed. the serial numbers and ID tags are not legible, The tiller is roughly 2.5 - 3 ft wide and was belt driven from the original JD Lawn tractor. from the belt drive there is an elbow drive connected to a chain drive down to the tines. I am assuming anywhere from a 100 - 200 model tractor. Any help would be greatly appreciated.
  • John Deere Master
  • 7,515 Answers
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link.
Best Manuals
Posted on May 17, 2017
SOURCE: Ariens rear tine tiller. What direction are the
The tines should turn counter clockwise or from the ground up toward the tiller not toward you .Owners manuals can be obtained from a local dealer on most often on line..
Posted on Apr 09, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
  • 61 Answers
SOURCE: Roper 16 hp Lawn Tractor: belt replacement
you need to remove the mower deck there you will see the pullys.
Posted on Sep 06, 2009
I have a John Deere D110 tractor. Can you tell me where to fill the rear end with gear oil. I can't seem to get any answers.
There is no rear end to fill with gear oil; the transmission is a sealed component; no maintenance is required.
There are grease fittings on the front axle and pivot points for regularly scheduled maintenance.
Feb 24, 2017 | John Deere Garden
Fix the monitor on the conveyor auger for a 9750 sts john deere combine
There is a John Deere manual for the cutting platform -
Sep 29, 2014 | Garden
What replacement engine would I need for my John Deere 624 Rototiller?
I have had a great experience with Green Dealer Customer Service
They have had most everything
Apr 25, 2014 | Garden
I go with the same motor. I wound try e-bay.
It is a 1993 john deere 6100. there are 3 forwards and 1 reverse on one gear stick- 1, 2 ,3, r and the other is a, b ,c ,d ,e. the 1, 2,3, r gear stick has becoe loose and u cannot select gears 2 and 3. I...
The shifters do run cables to the transmission but you likely only need to remove the panel from the right side that covers the shift rods and then you can tighten the 13mm nut that brings the linkage rods together,the nut is on the shift lever not the range lever,Let me know how you make out and if i am wrong also let me know and i will dig deeper.
Sep 28, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 445. I would like someone who knows about this tractor answer the question as to why after replacing the camshaft why the motor backfires through the carb. If you read through all of my...
Of the 100+ camshaft replacements that I personly have done on the 425/445 and John Deere Gators I have come across 3 that backfired when completing the replacement.2 were do to bent valves coming in contact with the piston after gear failed and 1 was from a sheared flywheel key.The only other time I had this same injected engine backfire was on a John Deere gator 620i that had a faulty computer and fired @ 90 derees off.Do a compresion check and that will help out alot.
Aug 06, 2010 | John Deere Garden
How do I get the rocker arms to move? I want to but a 3 point hitch on my 60 but i do know how to get hte rocker arms to move. Are there valves that need to be adjusted?
You need to put your hydraulic pump in gear and the lever that runs the hydraulic outlets will run your rockshaft it might not go down if there is no load on the 3-point.
Jan 14, 2010 | John Deere 3-point Hitch Kit A,b,g,50,60...
I need to know where to add hydraulic fluid in a John Deere 2010
... should be between operators seat and 3rd link arm. A large nut/cap on top of the transmission cover, near the rockshaft of the 3-point hitch arms.
Nov 04, 2009 | John Deere 4000 201000-> Gas & Diesel...
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
