Question about Polaroid PoGo Digital Photo Printer
When connecting the usb to printer and camera when i go to print it says usb error
  • 583 Answers
The two devices are probably overloading the USB power. The total power output on one hub in the computer is limited to 500mA. If they work separately, this is most likely the problem. The way to fix this is to purchase an inexpensive powered USB hub (it will have a power supply to plug into the hub as well as the USB cable to the computer).
Posted on May 13, 2010
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
Error e14 canon mp250
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
Aug 12, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Select picbridge at USB mode setting when printing (fujifilm camera A500)
You only use Pictbridge when printing directly from the camera to the printer. If you activate Pictbridge and connect the camera to the computer, you will get "communication error".
The printer also needs to be Pictbridge compatible.
May 08, 2010 | Fuji FinePix A600 Digital Camera
Error 9
E9 is "the connected digital/ video camera does not support Camera Direct Print".
Nov 25, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My canon MP210 gives E9 error. How does it solve?
Some of the error codes for your printer,
Direct Printing
E22 Carriage error
E29 EEPROM error
hope it helps
Jun 11, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
USB NOT CONNECTED ERROR WHEN IT IS CONNECTED
This is a HP hardware/software error and HP has not fixed it.
The C4250 may report that "USB is not connected" but the printer works just fine and when you use the Microsoft Scanner and Camera Wizard to carry out a scan, it works just fine too. So the error message is wrong.
The Microsost Scanner and Camera Wizard can be found on the Control Panel.
May 05, 2009 | HP Photosmart C4250 Multifunction Photo...
Canon MP150
E23 is a paper feed error. Check the rollers and the paper feed mechanism. Following are the various error codes for your printer:
CANNON Printers MP150/MP160 ERROR CODE
E9 The connected digital camera / video camera does not support Camera Direct Printing
E22 Carriage error
E29 EEPROM error
turn the printer off and lift  the front top and move the cartridge carriage manually at the center and then on the printer.
Mar 14, 2009 | Canon PIXMA MP150 All-In-One InkJet...
C4200 - says USB not connected when trying to scan
Mar 01, 2009 | HP Photosmart C4280 All-in-One InkJet...
Scanner not working on my HP C4200 all in one
Dec 14, 2007 | Office Equipment & Supplies
Alarm light is flashing. cannot print
hi dear
this the error code
Direct Printing
E22 Carriage error
E29 EEPROM error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Aug 31, 2007 | Canon PIXMA MP160 All-In-One Printer
Polaroid PoGo Digital Photo Printer Logo
226 people viewed this question
Top Polaroid Office Equipment & Supplies Experts
Joseph Gallucci
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
