Question about E-Machines eMachines Monitor E15T4
Screen is working but not lit up emachine d620
1. emachine 15in Lcd monitor comes on... all i see is the mouse arrow(yes it moves w/mouse) the rest of screen is black..... 2.how do i change the resolution without a screen to start with?
Posted on May 14, 2010
  • 11,361 Answers
I need to reformat my laptop but can't find the driver for my emachine d620 ms2257..pls. send me the link wer i can download such driver
Go to this like http://support.emachines.com/em/driver/nb/d620.html
hope this problem solve here...
Mar 23, 2013 | Computers & Internet
I have an Emachine D620 5133 Laptop that the screen stays solid white when powered up, any ideas?
No ideas
Just definite facts
Problem is;
A) Graphics chipset
Or.
B) Video Cable
Or,
C) Screen Inverter
Or,
D) LCD screen
Diagnose
LOT of reading ahead.
1) Graphics chipset:
Connect a VGA monitor to the blue VGA port, on the right side of the laptop.
http://www.geeks.com/largePic_all.asp?invtid=D620-5133-OB&pic=D620-5133-OB-box.jpg
This is a general example of a VGA port (Connector), and VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
You can use a CRT type of monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA Cable.
Turn the monitor on. If a CRT type allow it to warm up
By factory default settings the display should show on the external monitor.
IF not;
There are at least 3 display options;
A) Internal monitor of laptop ONLY
B) Internal monitor of laptop AND external VGA monitor
C) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the Same time tap once on the F5 key.
The F5 key is the Display Toggle-Over key.
Still no display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F5 key.
No display, (Or solid white), on external VGA monitor, suggests problem with graphics chipset. If this is the problem post back in a Comment.
Good display?
Problem is Video Cable, or inside the Display Assembly.
(screen Inverter or LCD screen)
There are no eMachines D620 service manuals, available on the internet for free that I have seen. Supposedly a few paid for versions, but I have my reservations about that.
(Probably a Generic User Guide, which you can get for free)
I also have never worked on this model yet.
But this isn't rocket science, and this isn't 'my first rodeo'.
2) Video Cable:
The Video Cable plugs into the motherboard, in an area under the Keyboard, and under the Palm Rest Cover.
Judging by;
A) Top View of motherboard,
http://www.ebay.com/itm/eMachine-D620-Motherboard-48-4BC01-011-MBN240100-08226-1-Yukon-MB-/121076931939?pt=US_Motherboard_CPU_Combos&hash=item1c30bf5d63
Set your mouse cursor in the middle of the photo. This enables the Zoom In feature.
Looking at the rectangular metal plate, with the opening in the middle of it; come from the Top/Left corner.
See what appears to be a fairly long white strip?
That is where the Video Cable plugs into the motherboard.
Now here is the D620 with the Keyboard removed. (And Display Assembly),
http://www.ebay.com/itm/eMachines-D620-Motherboard-CPU-base-assembly-/110847874891?pt=Motherboards&hash=item19cf0c574b
Here you see the white connector again.
Middle, and towards the Top; in the small rectangular opening.
The Palm Rest Cover has to be removed, to access the Keyboard Cable's motherboard connector. This connector.
Going on....
The Video Cable then goes up by the left Hinge, and then up into the Display Assembly.
From there the main portion of the Video Cable, connects to the back of the LCD screen.
There is also a separate small cable, coming from the Video Cable; that connects to one side of the screen Inverter.
Example of the Video Cable,
http://www.ebay.com/itm/eMachines-D620-LCD-Video-Cable-50-4BC03-021-/130862506637?pt=US_Video_Cables_Adapters&hash=item1e7803628d
The white connector you see at the bottom, with the black pull strip; is the motherboard plug connector.
The small cable extending to the Right, connects to the screen Inverter.
The large connector shown at Top, connects to the back of the LCD screen.
Just from normal repeated opening, and closing of the laptop; the Video Cable may become pulled on, and/or pinched.
This can cause a loose connection at the motherboard side, or LCD screen side.
Screen Inverter cable connection may be pulled loose also
Can also cause damage to the Video Cable. Stretched/Broken wires
The procedure is to;
A) Remove ALL power. Remove the AC adapter (Charger), and Battery.
B) PHYSICALLY check to see if the motherboard connection is tight. Try to plug in tighter.
Reinstall power. Turn laptop on see if this was the problem.
No?
Remove all power again. This time remove the Display Bezel, and see if the Screen Inverter cable is connected tightly.
At this point it is just going to be a visual observation, and record.
Next is to check the LCD screen connection of the Video Cable, and it may loosen the Screen Inverter connection, anyway.
[The plastic frame in front of the LCD screen is the Display Bezel,
http://www.ebay.com/itm/eMachines-D620-LCD-Screen-Bezel-41-4BC01-001-/300798380595?pt=UK_Computing_Other_Computing_Networking&hash=item4608fb0a33 ]
If plugging the connections of the Video Cable in tighter, does no good; the Video Cable is then checked for continuity.
A multimeter is used, and set on OHM's. (1K)
Electricity is sent through each wire. The reading itself isn't as important, as just seeing IF there is a reading.
No reading indicates stretched/broken wire.
You can take the Video Cable, down to the nearest small computer repair shop; and have the resident tech check it out for a few bucks.
The Video Cable MUST be ruled out as the problem, before going on. Otherwise you may be buying parts needlessly.
(LCD screen? Around $70 to $100. You have seen the price of a Video Cable)
Video Cable proves to be good? Go on.
3) Screen Inverter:
The screen Inverter is located behind the Display Bezel, and mounted to the bottom of the LCD screen. (Screen Frame)
To test a screen Inverter requires a sensitive multimeter. Read fairly expensive,
http://www.fonerbooks.com/test.htm
Do to this, the ease of access to replace, and the general low cost; the screen Inverter is just replaced,
http://www.ebay.com/itm/LCD-Power-Inverter-Board-for-eMachines-D620-Backlight-Replacement-for-Screen-/120819595221?pt=US_Laptop_Screens_LCD_Panels&hash=item1c2168b7d5
If this doesn't repair the problem, the problem is the LCD screen.
Replace.
I can guide you, and I believe step by step; if you wish to attempt repair.
Post back in a Comment.
Regards,
joecoolvette
Mar 16, 2013 | eMachines eMD620-5133 Notebook
My emachines D620's screen doesn't work, is there anything I can do to get it working?
Hi! this is Alex Walker expert to help you for this issue call me on +1(518)348-9393 I will be glad to assist you
Aug 18, 2017 | Acer Computers & Internet
Hi There, When I turn on my emachines D620 lab top the screen does not come on. It seems that the lab top is booting correctly but no screen. Can you help with this problem?
I would like to understand if the screen atleast flicker when the system is turned on. Is the screen power led lit on or flickering. In case you have no signal on the screen or no blinking also, you may have to get the lap for a HW repair as it could be a lap monitor HS issue. Else it should show atleast the initial screen while boot up as the screen would be working with the basic Bios Instructions which doesnt have any driver or complicated OS Code to run the screen. So ideally it should work at the initial stage of Bios to confirm that the screen has no hardware issue. Good Luck.
Feb 14, 2010 | Computers & Internet
Emachine D620 Laptop
its broken, if less then oen year old call acer and get a replacement
acer owns emachine.
Nov 12, 2009 | Acer eMachines 520-2890 Notebook
Monitor broke
Go to Ebay, (Computers and Networking>PC Components>For Laptops and Notebooks>Screens,LCD Panels>Emachines D620)
Or here is a website I found,
http://www.screentekinc.com/eMachines_D620-5777--14.1-inch--1280x800-wxga-laptop-lcd-screen.shtml
Here is information on removing the old LCD screen,
http://www.sparepartswarehouse.com/LCD-Removal/laptop-lcd-screens-repair-removal-instructions.asp
Another one,
http://www.screentekinc.com/lcd-removal-instructions.shtml
Jul 19, 2009 | eMachines eMD620-5133 Notebook
Emachine d620 how to factory reset
when you restart the laptop press f2 then disable the f10 boot menu then restart your computer again after the emachines logo appaeres press f10 repaetedly until the factory defualt festore screen apeares then follow on screen directions
Jul 04, 2009 | eMachines eMD620-5133 Notebook
E-Machines eMachines Monitor E15T4 Logo
388 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
