Question about Westinghouse TX-47F430S 47 in. LCD TV
4 HDMI jacks, all stopped working at once
Westinghouse 42 inch LCd 1080p tv 4 HDMI jacks, all stopped working at once
    President:
  • Westinghouse Master
  • 749 Answers
TV probably had a power surge, which distroyed the IC that handles the HDMI input multiplexor.
If restarting does not help I am afraid you'll have to change main board.
Board ID 48.70E01.01A or W421TAFX69 is what you are looking for.
Hope this helps!
Bobby @ coppelltvrepair
www.coppelltvrepair.com
Posted on May 13, 2010
Vizio 42 inch smart tv Model # M420sv
You have to check the audio settings of your tv. There would be n option which allow you to choose the option between internal speakers or external speaker. You have to choose it as external speakers of amplifier.
If you wish to get some more details then check the following link
http://electro-medical.blogspot.com/
Jul 22, 2016 | Vizio M420sv 42 Inch Class Edge Lit Razor...
HDMI from computer to TV gets sound but no picture??
Check with an other HDMI cable. Sounds like a cable fault. This type of fault is common to HDMI connections.
Dec 05, 2015 | RCA 42la45rq 42-inch 1080p Lcd Tv Black...
My 42 inch westinghouse wont turn onDTV 1080p TX-42F430S
If you are referring to that you are unable to select the the 1080p setting in the TV menu, first try changing the aspect ratio in the TV Menu.
If that does not do it, you have to change the display setting ion your device, if you can not or it does not have 1080p the problem is that resolution is unsupported by your device
Jun 07, 2012 | Westinghouse LVM-47w1 47 in. HD-Ready LCD...
My tv goes from 1080 to 720 while I'm playing my ps3 how can I make it stay on 1080
You have make sure the game can run in 1080p first by looking at the back of the box. If it can, and you're using hdmi etc then simply do the following:
1. Go into display settings.
2. Select HDMI, then "custom"
3. Uncheck 720p and 1080i, leave 1080p selected.
4. Start up the game and double check it is on 1080p.
Otherwise, you're stuck because the majority of games are in 720p to avoid lag within the game.
Dec 10, 2010 | Westinghouse W4207 42 in. HD-Ready LCD TV
How can I use my lg lcd tv model m1994a for my ps3 there's no video signal,I try it all inputs to my lcdtv from av cable.component video,and hdmi cable still there's no video signal,but if I'll connect to...
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Nov 21, 2009 | LG 42LC2D 42 in. LCD HDTV
Westinghouse 1080P 42" LCD TV - HDMI stopped working
I know this is late, but this happens frequently. If anyone else has the same problem try unplugging the TV for 60 seconds. Plug it back in and then hold the power button down for 30 seconds. That will reset the TV.
You should see the Westinghouse logo come up and the HDMI should work. This has happened twice with my TV in 1 year.
Apr 10, 2009 | Westinghouse TX-42F430S Television
Help
Best would be hdmi next would be component, both can carry 1080p signal, but hdmi beats component as it can upscale to 1080p.
Jan 21, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Open Questions:
My Westy 47 TV has a very strange power-up problem! First, I found that the power supply was bad, I couldn't repair it, so I bought a replacement from ShopJimmy. The replacement seems to be working fine, and sometimes the TV works fine. The little green LED near the bottom edge of the controller board lights up when you connect the AC power, as it should. There is also a small green LED near the upper edge of the controller board that apparently lights only up when the controller is working properly. I've replaced the 470 mFd, 16 V. 'Lytic on the controller board, as everyone says to do. I still observed about 0.8 Vp-p of digital signals on the 5 Volt buss with the replacement capacitor these signals looked kind of like a 300 kHz clock and some other misc. digital stuff, so I added a couple of 0.1 mFd disc ceramics directly across it on the bottom side of the board. That reduced these signals to about 0.4 Vp-p, but the TV still won't turn on. The orange pilot light on the front is lit, but neither the buttons nor the remote will turn it on. The only way I can get the TV to turn on is to do the following: 1. disconnect the two power cables going to the two lamp inverter boards; 2. plug the AC power cable in. The 2nd green LED on the upper portion of the controller board now lights up when AC power is applied. 3. plug in both power cables to the two inverter boards while the power is on. The TV now works fine - all of the lamps light up, good picture, blue LED on the front panel, the remote works, etc. However, if I turn the TV off, and try to turn it back on, the small green LED on the upper controller board goes off, and the set won't come on! I've tried holding the on/off button down for over 10 seconds I read that this might re-boot the controller to no avail. The only way to get it back on is to go thru the 3 above steps again. I've read that there appear to be several versions of the firmware, and I wonder if this might be a firmware problem. If so, how/where can I get the proper firmware to install? Any suggestions? HELP! Please If someone would like to call me, please do at ************. Thanks, Gary W3DTN
Dec 28, 2015 | Westinghouse TX-47F430S 47 in. LCD TV
See all Westinghouse TX-47F430S 47 in. LCD TV Questions
Westinghouse TX-47F430S 47 in. LCD TV Logo
519 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
