Green lights...no power. HELP!
My computer will not turn on. Whenever I press the power button, green lights will flash, then nothing. What is the problem?
  • 23 Answers
This could be a problem with your power supply. If the motherboard sees that the voltages from your power supply are low, it will turn itself back off.
You can test your power supply by unplugging all of your internal power cables, ground out the green wire on the 20-pin/24-pin ATX connector and check your yellow (12v), red (5v) and orange (3.3v) wires. If the voltages come back more than 10-15% off, you will most likely need a new power supply.
Even if you have good voltages using the test method above, it is only an indication that your voltages are good at zero load. Your power supply may still fail under normal load. If you have recently added any hardware to your computer, remove it and try again. If this still doesn't work or you haven't added any hardware recently, replace your power supply.
Posted on May 13, 2010
I have canon ip2000 printer, the screen shows error 5B00(The waste ink tank is full). the LED flashes, 1 Green(stable about 2 sec.), then orange/green, orange/green ..... 7 times(fast about 1/2 sec....
In case you haven't tried this before, here is a tip that should reset the printer.
Copied from site: http://www.cyber-ink.com/member-canon.html
To Reset ip2000 / 3000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Also note that if the carriage is not moving as it should, it has nothing to do with printer drivers or your computer. It is an internal function of the printer and no external connection (usb/ethernet) should affect its operations.
Oct 16, 2013 | Canon PIXMA iP2000
Canon Color Bubble Jet Printer i550 wiil not print - (greenlight then orange light blinks 8x - then green light) When attempting to print receive "Printer not responding" - "Paper thickness lever...
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Office Equipment & Supplies
When I turn on my Canon i560 printer the light blinks orange and green and will not print anything. I've tried to turn it off and on, unplug it and nothing seems to be working. What can I do to fix it?
power button.)
Aug 04, 2010 | Canon BubbleJet i560 InkJet Printer
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
Error 22
1. Turn off printer
Jan 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon IP2000 printer. The power switch is flashing intermittantly green and orange and as a result it seems to be stuck as anything I do has any effect - any ideas?? Many thanks in advance for your...
this may work for you
1. Turn off printer
Nov 29, 2008 | Office Equipment & Supplies
Flashing lights
Canon IP 2000 / reset
1. Turn off printer
Aug 26, 2008 | Canon PIXMA iP2000 InkJet Printer
Printer will not respond
Canon S330 Turn off printer
Press the Power button and the printer should turn off, if not, press the Power button once more.
Jul 22, 2008 | Canon S 330 InkJet Printer
My canon ip2000 won't reset
Canon IP 2000 / reset Hi there you can try this.
1. Turn off printer
All the Best Pineworks
Apr 06, 2008 | Canon PIXMA iP2000 InkJet Printer
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
