Question about Mitsubishi VS-50605 50" Rear Projection Television
The color and picture is not alligned - Mitsubishi VS-50605 50" Rear Projection Television
  • 1,476 Answers
You have defective convergence. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on May 13, 2010
My rear projection television is showing a double picture with the blue out of allignment. It also shows a bow on the top and a bow on the bottom.
The tv have a problems known as a convergence problems,tv convergence board it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it is dead.Must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv picture convergence problems.The tv shop,will cost u like $300-350 for parts and labors.
Apr 24, 2011 | Zenith IQC50H95W 50" Rear Projection...
The colors are unalligned and the picture is blurry
hello,,the deffective part of your tv probably the convergience ic,it is a 2 pcs big ic with heatsink mounted on the mainboard you can replace it with a new one..or try to adjust first the allignment of your cathodes the RGB cathodes..on your front pannel there is a convergeance manual allignment button use this button to allign the convergeance..on your remote control there is also an allignment command consult your manual for the command .after the adjustment you must save the adjustments before exit the convergeance adjust..if thris adjustment do not work replace the convergeance ic ..mostly the ic is labeled STK XXXX..
GOODLUCK i hope i this helps you..
please rate my help tnx.
May 29, 2010 | Philips 51PW9303 51" Rear Projection...
Picture bounces
Chances are the mirror is out of allignment or loose that projects the image on the screen from the lights below. This is a delicate adjustment that should be done by a professional service center. I hope this helps, good luck.
Sep 24, 2009 | Televison & Video
Blurred color images
I'm not sure of what brand and/or model you have, but most have a maintenance mode to do color alignment.
Jul 16, 2009 | Office Equipment & Supplies
I replaced the convergence board and ICs, but picture stil bowtie
Did you go into the convergence menu and allign the colors? Here's the link where i fixed mine... it's got the remote control button layout to adjust everything.
Jun 23, 2009 | Akai PT5598HD 55" Rear Projection...
Double images-picture on tv is in unalligned red and green colors
You need the Phillips DPTV305 - DPTV345 Chassis convergence repair kit which is available at the following link. the kits contain the parts and detailed instructions on how to do the repair.Just click on the phillips repair kits page.
http://tvrepairkits.net/
Jun 23, 2009 | Philips 60PP9202 60" Rear Projection...
Temporary losing picture
CHCK THE OPTIONS MENU SEE IF IT HAS A COLOR CONVERSION OPTION ,,TRY THAT,,ALLIGN THE COLORS
May 14, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Double picture & color problem
see if the mirror in side is broke or cracked
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
Align Print Cartridge Failure
hello..
You may be need to buy a new color cart., becuase the allignment page depend on the Yellow color when it become to scan..
or you can pring any allignment page from a friend and put it in the scanner instead that one you printed out....
Hope it's work
Yasser
Feb 20, 2008 | HP PSC 950 All-In-One InkJet Printer
HDTV 1080i studio series
hi there, its a color allignment problem, the adjusting ring is in the neck of the picture tube, the unit is on while adjusting it to the correct image. ty
Dec 23, 2007 | Orion STV2763 27" TV
Mitsubishi VS-50605 50" Rear Projection Television Logo
153 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
