Question about Aiwa AV-D77 Receiver
AIWA AV-D77 Power Trip
I've read about the same issues that I'm having. Power/enter buttons, clicking, not turning on. It's been going on for years, and with patience, it would eventually turn on. Now, nothing but clicking.
It does seem like it's tripping something, but seems to be a common problem - doesn't the manufacturer have any solutions?
I too would like to avoid a landfill with this thing, but enough already.
Any idea of cost for prof. repair?
My Aiwa AV-D58 receiver won't turn on, only sits on 'Eco Mode.' After letting it sit for about a month, i plugged it into a power outlet and it worked, so I unplugged it and carried it into the room...
Have someone check your house wiring to see if the live and neutral are reversed.
Beyond that - you may have some leaky capacitors. If you're tech savvy, open up the unit and see if any of the electrolytic capacitors are bulging at the top or leaking at the bottom, and if so, unsolder and replace them. This is actually the most likely issue.
Feb 21, 2011 | Aiwa AV-D58 Receiver
Aiwa AV-D77 receiver power issues
Please confirm 9 volts on Power Board as shown in below picture...
Regarding click-click-click sound of relay its caused by Serial Clock and Serial Data signal failure in digital ICs. Please confirm above signals by using Oscilloscope.
Nov 22, 2008 | Audio Players & Recorders
AV-D77 power issues
Please let me know symptoms of AV-D77 receiver.
Nov 14, 2008 | Audio Players & Recorders
Issue with the power. Reset doesn't work.
If you know basic electronics and can recognize parts inside receiver, then I'm here to help you but please don't call it as junk. Its beautiful piece of Aiwa.
Nov 08, 2008 | Aiwa AV-D77 Receiver
Aiwa AV-D97 Power Issue. Just clcks when you hit the power button
The unit is most likely in protect mode. This means that the output section has a problem and the protection circuitry is preventing it from being turned on. This is to prevent further damage. The typical defective parts are the output transistors. Figure on $20-$40 for parts plus the local labor rate for repair.
Dan
Jun 10, 2008 | Aiwa AV-D97 Receiver
Aiwa AV-D58 wont power on
this happened with mine two. all i did was press powert and enter at the same time and it clicked for like 2 hours or so and then it turned on. it was cool
Dec 09, 2007 | Aiwa AV-D58 Receiver
Power on but no display
Hello Coach T, Reset Instructions: 1. If pressing the power button does not turn the unit off, unplug the unit, then plug it back in. 2. Press the power button while pressing the ENTER button. This will bring the unit back to factory defaults. Please let us know if you need any additional help. Best regards, nightdiver
Aug 21, 2006 | Aiwa AV-D57 Receiver
Sudden failure to power up
I've had this happen a number of times with my receiver. This trick from the Troubleshooting guide in the owner's manual usually does the trick: To reset If an unusual condition in the display window or malfunction occurs, reset the unit as follows. 1 Press the POWER button to turn off the power. 2 Press the POWER button while pressing the ENTER button. Everything stored in memory after purchase is canceled. If the power cannot be turned off in step 1 because of a malfunction, reset by disconnecting the AC cord and carry out step 2.
Aug 01, 2006 | Aiwa AV-D77 Receiver
Subwoofer output
There could be a number of reasons causing this malfunction, try replacing the subwoofer's cord, it might be damaged, you can also try reseting the system to the factory settings according to the following instructions: Reset Instructions: 1. Press the power button to turn off the power 2. Press the power button while pressing the ENTER button. (note: this will reset all memory) Good Luck
Jan 09, 2006 | Aiwa AV-D57 Receiver
Aiwa AV-D77 Receiver Logo
109 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
