Question about Mtd 22" Yard Machine Push Mower
Mower gets flooded by fuel and will not run. fuel leaks out of carb
  • Mtd Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
The carb floods on this tractor at anytime. Ihave two of those tractors and swapped the carbs and fuel pumps. They all run fine on the Running tractor but not on this one.
Search Results
    Rider mower carburetor flooding - help ! - YouTube
    ? 1:30
    www.youtube.com/watch?v=ZYqtKvLXYtY
    Sep 29, 2010 - Uploaded by Joyce Boncal
    I took the carb off & cleaned & soaked it in gasoline. The parts I replaced: float, float bowl & gasket, needle ...
Sep 26, 2015 | Garden
Hi , need help my mtd ride on mower was leaking fuel so I changed the fuel pipes it is now misfiring
if the fuel is leaking from the carb and its also misfiring then it could be that the carb is flooding. to cure this you will need to remove the carb, remove the fuel bowl off the carb,remove the float and needle valve and either blow out all the jets and air wys with compressed air or if you dont have compressed air try using carb or brake cleaner with a straw pipe in the nozzle to blow through the jets etc. check that the float and tip of the needle valve are in good condition before refitting them
Mar 21, 2015 | Mtd Garden
Lawnmower leaks fuel from carb
It sounds as though your float and needle are stuck open or not closing properly, thus flooding with fuel. However it is hard to give exact fix/problem without a model number of the engine to be able to see the specs and design of the carb.
Aug 27, 2014 | Garden
Mower will start but runs rough & stops
Is the carb flooding?is there black smoke coming from exhaust when running, if so it could be the carb over filling with fuel. Is there petrol leaking out of the carb? If not check the fuel pipe is in good condition
Jul 22, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Kohler 20hp Craftsman mower started leaking fuel out of air filter and exhaust
i have been finding that the needle valve in the carb has not been seating from the newer fuel replace both the needle valve and the seat change the oil and you should be good to go i add a shut off valve to the ones i service and advise that the fuel be shut off when not in use and run the carb out of gas when not using for ever day
Jun 18, 2012 | Garden
12hp brigg & stratton engine gas mixing with oil in engine block..when start engine runs high rpm can not idle & look like gas come out carb air cleaner overflows & flood out & stop engine...
Sounds to me like the float needle valve in the carb is leaking. This will cause fuel to over flow out of carb, and will even get into the engine oil. Check to be sure that float is not got gas in it the can go bad. Also check float adjustment. Check needle and seat very carefully for dirt or wear. Just the slightest bit of dirt or wear can cause it to leak. Hope this helps.
Sep 17, 2010 | Parks Optical 13.5hp Briggs And Stratton...
I have a Toro 1984-85 self propelled pull start lawn mower and I can get the fuel and air mixture just right it won?t stay started, it runs great but gets flooded now (I think), does anyone have the fix-it...
If the mower floods, it may be a float problem, if you have a carb with a float. New fuels can destroy older floats, dirt and gum can keep them from closing off the fuel supply. If you are comfortable taking your carb apart I would start there.
You will need the engine make and ID to get a manual.
Jun 03, 2010 | Toro Lawn Mower With Toro Power Tools
Runs with choke out.. dies if pushed in. Will only run a short time then seems to flood. After that it will continue to leak fuel from under the air filter somewhere until the tank is empty... crazy....
Try rebuilding the carb. It might be your float is messed up. You can also get some carb and choke cleaner and take the sediment bowl of and clean everything in it. Give extra attention to the float and needle valve. They might have some build up that won't let it work properly.
Also your gas cap might not be venting properly.
Oct 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
The engine on my Sprint 375 floods when trying to start
Check the float in the carb. bowl for gumming and clean your carb.. If you haven't done so already. Or you can try running a fuel treatment through your fuel. That may help you with your flooding issues. Good luck.
May 04, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Yard machine 139cc will only run short time with choke
Check the float and the adjustment screw on the bottom of the carb. Usually if the float stays up it will continue to leak gas and also will only run on choke. Spray some carb cleaner in there and try to get rid of any debri also try changing your air filter or cleaning it
Feb 08, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Mtd 22" Yard Machine Push Mower Logo
163 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
