Question about Dyson DC25 All Floors Bagless Upright Vacuum
My DC25 Animal is making a howling, whistling noise. Primarily when turning off (winding down to shut off)
  • Joseph Belmont
    Joseph Belmont Mar 21, 2015
    My "howling" disappeared completely when I replaced both air filters with new ones; exact replacements are available on Amazon.
If it started after you cleaned the filters, it is because when you smack the filter that is in the ball like they tell you to, it pushes the gasket in so air can sneak past it. take it back out and pull the rubber gasket away from the filter so there is about 1/16-1/8" away all the way around, then put it back in. it will seal it and stop.
Posted on Sep 13, 2012
  • 1 more comment
  • Amy N Sjoholm
    Amy N Sjoholm Sep 11, 2015
    What an easy fix! Thank you so much!
  • Anonymous Feb 05, 2018
    Thank you! Virtual life-saver.
  • Anonymous Apr 04, 2018
    YOU are a GENIUS!!!! How did you ever figure this one out!!!
    New Friend:
  • 3 Answers
The noise is caused by the air blowing out of the motor leaking out between the rubber gasket of the filter and the motor housing. Smearing a very thin film of silicone grease on the rubber gasket should stop the noise completely.
My DC25 Animal is making a howling, whistling - c2dec2d4-2074-4dec-9fd3-5bf8d226b66b.jpg
Posted on Mar 31, 2014
  • Dickie Fix
    Dickie Fix Jun 02, 2014
    Another way of stopping the noise is to take a length of nylon cord or string about 16 inches (40cms) long and 1/8 to 3/16 inch (3 to 4mm) in diameter and insert it in the 'v' on the inner surface of the black rubber seal on the filter (it's hard to describe, but when holding the filter, it's easy to see where it goes). It only takes a minute and requires no tools, just your fingers. Fitting this cord raises the outer part of the seal just a bit to form a better air seal and prevent air being sucked in past the seal - it's this that causes the whining noise. This works well for me in my Dyson and is much better than the lubrication fix I posted above which solved the problem only for a couple of weeks.
  • Dickie Fix
    I've retrospectively added a photo of the filter with the last 3 inches of the nylon cord still to be fed into the seal.. Hope this helps to visualise things.
  • Dyson Master
  • 1,468 Answers
The dc25 model tends to allow air to bypass the HEPA filter. The air makes a whistling sound. Remove the filter cover and try moving the filter around a little a see if it changes the sound. Sometimes it can be adjusted to stop the noise.
Posted on Jan 17, 2015
    New Friend:
MINE WAS THE SEAL IN THE TOP PART OF THE DUST BIN PART NUMBER 911077-01 FOR THE DC25 ANIMAL. I HAD TO USE A STAR SCREW DRIVER TO TAKE OUT 6 SCREWS AND THE FOAM GASKET BROKE THROUGH. nOW IT IS QUITE AS A MOUSE
Posted on Jan 16, 2015
    Habit-Forming:
    New Friend:
  • Dyson Expert
  • 89 Answers
Bottom line is the air cant pass thru the flter any more They are not permant filters they need be changed If they where permant Dyson would not sell them
Dyson DC25 Post Filter oem 916188 05 envirocare f978
Posted on Jan 24, 2015
  • emer usa
    emer usa Oct 25, 2016
    Do not attempt to seal these filters they need to be changed air cannot pass thru anymore and is pushing out thru the seals on the side. Filters need to have air go thru them to filter. If you leave them the motor will run hot and burn out Dyson DC25 Post Filter oem 916188 05 envirocare f978
    New Friend:
  • 3 Answers
It is the filter in the ball, the nylon mesh vibrates as the suction decreases. The mesh should be stuck to the inner filter but does loosen over time. Cured mine with a couple of thin lines of contact adhesive.
Posted on Jan 10, 2014
  • Justin Saechee
    Justin Saechee Jun 28, 2014
    Where exactly do you apply the contact adhesive?
3 Suggested Answers
  • 183 Answers
SOURCE: whistling noise on dc25 Animal
there may be a small cut in the tube or there is something stuck restricting the suction check all hoses
Posted on Jul 28, 2010
SOURCE: WHEN I TURN OFF DYSON
I am experiencing the same problem with dyson 25 when the motor is shutting down - i hear a strange noise ....
Posted on Jan 24, 2011
My dyson DC25 Animal, wont turn on. Is there something I can do to fix the problem
I called Dyson because I had a similar problem. When I pushed the red button down on my dc25, but it would not stay down. The vacuum would turn on when the button was pushed down, but of course when I let go of it the vacuum would shut off. The helpful telephone tech. Recognized the symptom right away and told me to push down on the button fully and let It flick up like a lighter. I about fell off my chair when that worked right away! Anyway for what it's worth, she said sometimes the mechanism in the buttons gets consnarlitated (my tern, not hers!) and this resets the spring...
Feb 28, 2017 | Dyson Vacuums
Whistle noise from filter
Try moving the filter a little while it is running. This is a common problem caused by the air bypassing the filter. The more clogged the filter is the more it will whistle but sometimes it will whistle with a new filter. Sometimes you may get it stopped for a while but then it will start up again or come and go.
Sep 01, 2013 | Dyson DC25 Vacuum
Why does my Dyson animal squeal on carpet
Hi, there are a number of different Dyson vacuums and they vary widely in construction. Unfortunately most models have an "animal" version so that's not helpful in identifying your particular cleaner. If you know the actual model number, I'm sure I might have some ideas of what will cause squeeling.
Off the top of my head, DC25's often have issues with "whistling HEPAs" but not usually carpet related, DC17's may exhibited brush roller noises if the belt is damaged. DC07's, 14's, 33's all have a clutch drive which sometimes fail causing "racheting" or other strange noises.
Feb 16, 2012 | Vacuums
My DC25 has started to make a whistle noise (more of a toot) as the vacuum blower decelerates on power-down
I'm sorry to hear you're having difficulties with your DC25. I'd encourage you to get in touch with us directly, as I'm confident we can resolve this issue for you. Please call our Helpline free on 0800 298 0298 (UK), or 1-866-693-9766 (US) so we can provide assistance.
Best wishes,
Jack
Dyson Online Customer Support
Jan 31, 2012 | Dyson DC25 All Floors Bagless Upright...
WHEN I TURN OFF DYSON DC25 ANIMAL..GET A LOUD NOISE AS THE MOTOR IS SHUTTING DOWN....
Jan 05, 2011 | Vacuums
Whistling noise on dc25 Animal
Jul 23, 2010 | Dyson DC25 Vacuum
Makes a whistling sound when turned on
bearings in the brushroll might be siezing.
If you start snapping belts, change the brushroll.
Jun 05, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC25 All Floors Bagless Upright Vacuum Logo
10,638 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
