Question about HP Compaq T1500 XR (204203003) UPS System
Why is the Utility light steady red?
The manual describes the utility light to be either blinking red, steady green or flashing green but not steady red?
4 Suggested Answers
  • 166 Answers
SOURCE: Micro code update error
Go to the HP Download Site
http://welcome.hp.com/country/us/en/support.html
Input your model number and then select Drivers and Downloads. Click the little arrows next to that box. Then select your operating system and you will be able to download what you need to install it from there.
Posted on Jun 16, 2009
  • 120 Answers
SOURCE: TOP LIGHT ON PRINTER KEEPS BLINKING - I'M UNABLE
This should help you. It details what the blinking lights mean and should allow you to diagnose what the problem is.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00061319&lc=en&cc=us&dlc=&product=305980
Posted on Oct 13, 2009
jadiazq
  • 2878 Answers
SOURCE: my hp ml370 g4 startup and the health led is green but when the dignostic utility appers on screen the health led become red and the keyboard not responding help plzzzzzzzzzzzzz
Open the case and turn on. There should be a corresponding led lit inside. That, or you could run Insight Manager. It will tell you exact details.
Posted on Mar 01, 2013
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
Power light flashing green to red
Assuming the "squiggle line" is the Utility LED the unit has proper power. The light is steady green and not flashing, correct?
Have you reset the unit?
Try removing all but one attached device to verify it's not an overload condition.
A photo of the control panel would help.
Dec 23, 2012 | HP Compaq T1500 XR (204203003) UPS System
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
The top light of the two is flashing green/red back and forth very fast and the light on the bottom is a solid red. how do I fix this so that way it will work normally
The steady lower light indicates the unit needs a new toner cartridge, MLT-D108S. Did you previously see this light blinking or blinking rapidly? (Those indicate the toner being low.) Replace the cartridge and check for any other error lights. Turn off the machine and let it cool. Then open the front cover and pull the old toner cartridge. Open the package with the new cartridge, remove the packing tape and paper that protects the cartridge and gently shake it (avoid touching the blue or green parts of the OPC drum). Press the cartridge into the slot until it is fully seated. Close the front cover.
The green/red blinking power light is not one I'm seen before. The printer indicates a non-toner failure (open cover, no paper, LSU failure, etc.) with a steady red light.
Aug 02, 2010 | Samsung ML-2240 Laser Printer
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Epson stylus c45 light blinking alternately
The most help I can offer is a link to a utility program designed to reset most (if not all) parameters of a variety of Epson printer models. You need to determine if said utility program will work with your particular model. This utility is SSC Service Utility for Epson Stylus Printers and may be downloaded from here. Additional information may be viewed here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 27, 2008 | Epson Stylus C46 InkJet Printer
Epson stylus c45 (Problem)
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C45 Service Manual". You will often find them
for sale very cheaply on E-Bay.
Jun 14, 2008 | Epson Stylus C46 InkJet Printer
HP Compaq T1500 XR (204203003) UPS System Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
