Question about Philips HTS-3555 System
Is there a reset button on a Philips DVD Home theater system hts 3555
  • gordito5043 May 13, 2010
    I was so ready to throw the system in the trash but "pabloloca' you saved me!!!!! I unplugged it from the wall for about 10 minutes and plugged back in and it has come back on!!! Thank you so much! This is an awesome website!
  • 2,335 Answers
I can help you with your Philips HTS-3555 DVD Home Theater System.
There isn't a reset button per se, but most home theater / av receivers do perform a reset when they are unplugged from the wall for several minutes and then plugged back in.
Additionally, there is a Factory Settings Reset option you can access by:
  1. Pressing SETUP on the remote control,
  2. Use the arrow keys to select the Preference Setup page,
  3. Use the arrow keys to select DEFAULT,
  4. Pressing OK to confirm.
I hope that helps.
___________________________________________
Philips HTS3555 Manual Download
Posted on May 13, 2010
  • Paul Sager
    Paul Sager May 13, 2010
    You're Welcome!
    Thank you for choosing FixYa.com.
    Please tell your friends.
    (Oh, and get them to ask for 'Pabloloco', with an 'o'.)
    Enjoy your day.
Wont stop reading "no disc" on the display even
If it will play a CD but not a DVD then it could be the Laser is failing. If it won't play either then its more than likely that the Laser has failed.
First thing though is to try cleaning it with a Lens Cleaning DVD.
If after this it still won't recognized a DVD you need to remove the Main Cover followed by the DVD Tray cover. You can then clean the lens directly with some lens cleaner fluid and a QTip. Make sure you only use a little cleaner fluid and wipe off with a dry QTip. Do not touch the lens with your fingers.
After you've reassembled the unit if you still have the same fault then the Laser has failed and would require replacing, although this is not normally cost effective.
Please leave feedback
Cheers
Andy
Apr 27, 2011 | Philips HTS-3555 System
The power supply, LCP106830-0001 is bad. I need a schematic for Philips HTS-3555/37 and new poser supply to repair.
You won't get voltage if you completely disconnect the lcp106830 power supply from the board. The connection to the front panel is required and is used as feedback. I just repaired one and found one of the power diodes faulty.
Dec 20, 2010 | Philips HTS-3555 System
Need a replacement remote control for the Phillips HTS-3555 system, where can i get a replacement remote control
You can buy required remote control for HTS-3555 from Remotes.com
Click above link to see required remote price info.
Thanks.
Sep 06, 2010 | Philips HTS-3555 System
How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
May 25, 2010 | Philips HTS-3555 System
Plays cds not dvds
Hai,
This is is due the lense and motor section problem, to resolve this issue you need to replace the lense and motor set.
Feb 11, 2009 | Philips HTS-3555 System
Where can I buy replacement connectors?
Have you found them yet? If not go to ebay and look for bogue engineering products, they should have it.
Jan 19, 2009 | Philips HTS-3555 System
Region code
I have a region Code For A Philips HTS-3544 which is 1 model Down. You can try it, it may work or it May Not.
Heres How:- power on the TV/DVD without any disk in the player.Press open/close eject.
Press Stop 7.3.4.4.6.6 ( on the Remote )
The menu code appears On The Screen.
Press 0 for region Free, or the region Code Required.
Power Off and then on Again, if the codes have worked, your dvd player is now region free.
If this works please rate as Fixya.
many thanks mike @ Compurepair.
Aug 28, 2008 | Philips HTS-3555 System
Unlock HTS 3555
Press "Door Open"
- after the door opens perform the following sequence with the remote control:
Press STOP-7-3-4-4-6-6
a Region settings page will be displayed showing the current region on the TV (usually the default is region 1), using the remote control select the region number by pressing the number on the remote (select region 0 for region free) and press OK.
May 05, 2008 | Philips HTS-3555 System
Trying to play hddvd onhdmi player
i don't think this model plays hddvd you will need a seperate player for these discs.
you can only play normal dvds not HDDVDs
good luck
smeags
Dec 31, 2007 | Philips HTS-3555 System
Philips HTS-3555 System Logo
826 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
