Question about ViewSonic VX2235wm LCD Monitor
View Sonic VX2235wm turns on everything works fine then about 30 seconds and the screen goes blank
  • unklejoes May 13, 2010
    very helpful thanks
  • 4,889 Answers
Is it totally dark or there is some dull glow on the screen(for determimining whether its the backlight or the LCD connector problem). Also gently tap on the screen when the picture goes out to see if the picture comes back. I have seen this happen due to cold solder joints so would like to verify if that is the case.
Sai.
Posted on May 13, 2010
  • 4 more comments
    the screen goes completely dark, and does nothing when you tap the screen
  • eagle338
    eagle338 May 13, 2010
    You have whats called a backlight inverter failure. A common problem on LCD monitors. AS the name suggested it is responsible for powering up the backlight behind the panel when the monitor is turned on. A failure on this board will cause the backlight to power off. WHat is the status of the LED at the front of the monitor? I suppose its on?
    the blue LED light yes it is on
  • eagle338
    Then Its confirmed its an inverter board failure. A replacement board should be installed by a qualified tech as the monitor's circuits hold significant amounts of voltages for several days(even after unpluggin). The inverter board costs around 30$ and expect a labor of about 25-30$. Get a quote before hand so that you can decide whether you wanna get it fixed or buy a new one if the labor charges are too high.
    Sai.
    thank you so much for your help! :)
  • eagle338
    You are welcome. Please accept the solution so that I will get the credit for it. Thank you for using Fixya!
    Sai.
I have a view sonic 1912wb a blank screen come on for 1 second then goes of. Can this be repaired?
The problem of this unit is bad or bloated electrolytic capacitors like this image:
bc3eb3e.jpg that is common to viewsonic monitor.
Sep 29, 2010 | ViewSonic VA1912wb Monitor
View Sonic Monitor
This model has a know issue with the power supply. Check out our repair guide at: www.ccl-la.com click the monitor repair link and then go to page 2, its listed under the Wetinghouse LCM-22W3 monitor, they use the same power supply - DAC-19M009. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 28, 2009 | ViewSonic VX2235WM Monitor
ViewSonic VX2235WM turns on than screen goes blank changed power cords cable cords viedo card cpu still same problem
The problem is most likely the monitor itself. Hook up an old monitor (usually someone has an old monitor laying around) if the computer works with another monitor you'll know for sure.
Look at your monitor using a flash light at an angle, if you can see a picture in the background you have a bad inverter.
Nov 28, 2009 | ViewSonic VX2235WM Monitor
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Screen goes blank at first try. Works after 1-2 tries.
this may be your inverter going bad. Inverter is the board(s) on the side of your TV that powers up your screen.
May 16, 2009 | Vizio L37 Television
White screen when power on view sonic 22'' lcd model # vx22335wm thanks
The Viewsonic VX2235WM has a known issue with the power supply going out. The flashing power light or blank white screen are classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 25, 2009 | ViewSonic VX2235wm LCD Monitor
Vx2235wm lcd flickers a bit then turns white
White screen is an indication of a faulty video board.
A blown fuse in the actual screen will cause the same effect but usually these do not reset on a fresh startup.
You can check the ribbon going from the video board to the back of the screen to see if it is somehow working loose, but I think based on your description that this isn't the problem.
ebaysbammbammfran
Oct 07, 2008 | ViewSonic VX2235wm LCD Monitor
Got a view sonic vx2235wm monitor turns on and display is fine then it turns dark
chenge Monitor brightness &contrest settings after you see how it monitor
Apr 01, 2008 | Computers & Internet
Vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
May 25, 2007 | ViewSonic VX900 19" Flat Panel LCD Monitor
ViewSonic VX2235wm LCD Monitor Logo
247 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
