Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Hear a boom, oven door opens/closes, oven stays lit, burners blown out
Ok, I know not to use the stove as this surprised and scared me. I was cooking on the stove top and pre-heating the oven. I heard a slight boom and the door blew open about 2 or 3 inches and closed on its own. I opened the oven door and smelled gas, but noticed that the oven was still on and preheating. The burner on the top of the stove went out, and out of curiosity, I did relight it with no problem.
What could be causing this problem? While using the oven over Easter, I thought I heard the oven "popping" a little as it adjusted its heat while cooking dinner.
Thank you
  • Bee12 Apr 04, 2008
    My GE XL44 gas oven is close to five years old and the first problem I had with it was the warming tray not warming. We have a GE service plan and GE fixed it. A week ago my oven stopped working completely except for the broiler. A GE service man who was not use to working with gas ovens replaced the ignitor, turned on the oven and boom, except the oven door did not open but you could hear it explode. He ordered a gas pressure valve that he installed today. The problem is when the oven seems to ignite it makes a very big noise and there is definitely a very large gas smell throughout my whole kitchen. I've been concerned my house is going to blow up so I have not used the oven and will call the gas company tomorrow to have them check it out. Any idea what the problem could be? The oven is working and heating up but the smell of gas is extremely strong and that really worries me.
  • 262 Answers
SOURCE: no heat at burners or oven
check your fuse / breaker box make sure you have power (sounds like you dropped a leg of power) make sure breakers/fuse is on/good flip it to off the to on if oven don't work then take a look at the cord to the range check power at the wall then open where cord goes into range check power or you may even find the cord burnt in there if so replace all damaged wires good luck
Posted on Dec 22, 2007
SOURCE: stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Posted on Feb 08, 2008
  • 1543 Answers
SOURCE: GE Profile Stove, stove top works but the oven will not heat up.
You will most likely have to replace the oven igniter. If you have the model number you posted under, I believe the igniter for the broiler is the same as the oven broiler, and could be swapped out to get the oven working again. (of course, now the broiler won't work until that igniter is replaced) If you'd like the part number or any further advise, comment back with the full model number off the sticker just behind the lower drawer panel on the frame of the range. Tonight, you may have to finish the chicken on the stove top.
Posted on Mar 24, 2009
  • 867 Answers
SOURCE: xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Posted on Jul 30, 2009
  • 744 Answers
SOURCE: Gas smell when oven is on and heating.
This sounds like a gas leak at the gas control valve for the oven, probably somewhere just past the control valve. If the leak was before the valve, you would either hear or smell gas leaking all the time.
The line could simply be loose at the fitting or the gas valve could be faulty. You could also have a leak somewhere at or before the oven burner assembly.
At any rate, this condition can be dangerous. The oven gas leak (any gas leak) should be diagnosed by a competent technician and the cause(s) of the gas leak determined as soon as possible and corrected.
Posted on Jan 13, 2010
Need to know why burner flames on Viking stove with cook top over shoot the bottom of the pans once the pan is placed on burner top.Second the oven door was repaired By technician does not close 100%
pots to small for burner adjust flame size to fit pot placed on
oven door is frame adjustment you need servicer that is familiar with this repair
Jan 04, 2018 | Viking Kitchen Ranges
Old Beaumark electric kitchen range
For a detailed Range/Stove/Oven illustration, click below.
Gas Free Standing
redarrow.gif Electric Free Standing
redarrow.gif Gas Cooktop
redarrow.gif Electric Cooktop
redarrow.gif Gas Walloven
redarrow.gif Electric Walloven
Electric combination range/ovens are stoves that have both surface burners and an oven. Depending on their features, some electric range/oven units are quite complex. To understand how they work, let's look at the following areas:
The control panel
The cooktop
The area beneath the cooktop
The interior of the oven
The broiler
The back of the unit
click below for customer support;
Hope it may helps you;
Sep 22, 2008 | Whirlpool RF378 Electric Kitchen Range
I need to know how to light the oven? Does it have a pilot light like the stove top
most stoves do not have pilot lights but work from a pizo ignition system
when you turn on the gas knob ,the first action is to energize the pizo and that continually sparks to ignite the gas at the hob
the same is with the oven
ovens should be lit with the oven door open and once lit then the door can be closed
Jun 07, 2015 | Sears 61301 Gas Kitchen Range
My stove lights very slow with a low flame. Should the igniter stay on after it lights oven
Yes the ignitor stays on even after the burner is lit. The ignitor is wired in series with the oven valve. It sounds like the oven valve isn't opening all the way. A new ignitor should solve this problem. The old igniter builds up resistance and doesn't let the correct voltage through to the oven valve for it to open properly.
Aug 16, 2010 | Magic Chef CGR3725 Gas Kitchen Range
Oven won't ignite
Your range is a Direct spark model.ce00970.jpg8278a1e.pngIf you want a Direct spark manual, let me know. The module gets confirmation from relay on the oven control and sends dc power to the gas valve. I suspect that gas valve be cause the top burners work which is usually and indicator that the module is fine. The terminals ohms should be 216 ohms between each of the 3. If any are open the valve won't work.
Jun 01, 2010 | Whirlpool GS460 Gas Kitchen Range
Hotpoint Glasstop Stove - Burner turns on by itself
I have a GE stove which I purchased in 2004, and it is doing the same. I heard beeping coming from the kitchen in the middle of the night . I went to the kitchen and the oven was on by itself. I have been unplugging it when not using it. Maybe this could be a recall.
Oct 08, 2009 | GE Profile JKP18 Electric Single Oven
Igniter is on, gas is released, a small explosion occurs in oven
no the little boom before it lites is normal mine does it all the time
Dec 04, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven pilot light will not stay lit on Garland 6 burner, double stove, salamander commercial in home
Use a needle right where the pilot flame comes out. Should do the trick. GOODLUCK!!
Dec 16, 2007 | Garland H283 Gas Kitchen Range
Oven won't stay lit
I had the same problem - it was because we were closing the oven door too hard and it was blowing the pilot out
Dec 27, 2006 | Equipex PZ-330 Electric Single Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
358 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
