Canon iR2016 my canon iR2016 copier machine have system error E001 .what is the cause of this problem and how I sove this ? please help me
  • 2 more comments
  • iali307 Apr 02, 2008
    I just replaced the fixing film two days before and it is shocking for me the error E007 is back and fixing film damaged ,prior to E007 system error E001 was coming three-four times.what can I do in this situation ? the fixing/fuser unit replacement is ideal solution for all these problems?(canon iR2016)
  • iali307 Apr 03, 2008
    thank for your reply .please elaborate your slution.
    how I can run the film HP or fixing film function? rest the codes mean reset the codes so if it is right how I can reset the codes?
    what type of voltage stabilizer should use to avoid power supply problem?
  • Anonymous May 28, 2008
    i have an error code e007 after using a blower
    Problem Solver:
  • 9 Answers
Most times eoo1 can be reset in service mode if there is no damage to fixing unit. 1) Enter service mode.
Press the operation panel user mode key, 2 key, 8 key and user mode key in this order.
2) scroll to "clear" and press ok then scroll to "err" and press ok.
if that does not work you can go back into service mode as above and instead of scrolling to "err" scroll to "all" and press ok. power off then on. doing this will clear settings service techs might have made but i've done quite a few and had no probs
Posted on Jun 14, 2008
    New Friend:
  • 18 Answers
For E001,808 Check thehalf cut bush of the fixing & readjust it
Posted on Mar 14, 2013
I have E007 in my machine IR2016 after using blower to clean my machine.
Posted on May 20, 2008
  • vivek_1313
    vivek_1313 Mar 14, 2013
    check the fixing film sensor & connection
  • 1,326 Answers
A E001 code is a fixing unit error code, it is not reading the right temp. of the fixing unit. It may be resetable or you may need a new fixing unit.
Posted on Apr 02, 2008
  • Chris Coughlin
    Chris Coughlin Apr 03, 2008
    The E007 is that the film HP is not bing seen. You may have to run the film HP search or run the fixing film funcation. The Eoo1 is the solid heating element is failing. Replacing the whole fixing unit should clear your problem, but you have to rest the codes once you turn it on. Most times it clears right up, but you may also have a power supply problem. Good Luck
SOURCE:
How to solve the error of canon iR2016 photocopy system error E003?
How to reset E000, E001, E003, and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" then Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Canon IC-MF6530/6550/6560/6580
No reset procedure is required, replacing the fuser is the only repair.
Canon D860 series
Press Additional Function key and the "#" key in that order. Go to Printer (number 7), select "Set", Select "Printer reset" and press "set".
Canon Printer Support Phone Number
Dec 06, 2017 | Canon Office Equipment & Supplies
How do I correct my photocopier machine Canon iR2016 with SYSTEM ERROR E007
Hi !
The error is caused when the fixing film is worn , it has a white patch that needs to be seen by the patch sensor , replacing the film will resolve the problem , as you can see on the picture below,
Oct 08, 2015 | Canon Office Equipment & Supplies
How can i reset a system error E007
Good answer here:
http://www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
<quote>
How to reset E000, E001, E003 and E007
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
</quote>
Jan 20, 2015 | Canon IR2020 Copier
My canon iR2016 has a system error E001
the e001 is error for temperature rise by main thermistor. If the termistor OK and doesn't need to be replaced you can clear the error in service mode. If clear doesnt helps, you need to change the fixing film assy.
Clearing error:
Press the User mode key, 2key, 8key,
User mode key sequentially
now you are in service mode, by arrow right, select #CLEAR, press OK, choose ERR and OK.
Also you can try with same procedure but instead ERR choose ALL. NOTE: under clear ALL, you delete all user data and restors the copier on factory settings.
Hope that helps!
Aug 25, 2011 | Canon Office Equipment & Supplies
I have error code showing E007 on Canon iR2016j copier. How can I go ahead to rectify the error. Pl advise necessary assistance
these means that you have trouble with fixing film in fixing assy.So... you need to change fixing foil.
Feb 22, 2011 | Office Equipment & Supplies
I want user manual of Canon ir2116J copier
conon IR2116J printer E001 and E808.Please help me.
Oct 27, 2009 | Canon imageRUNNER 2000 Copier
System error E808
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540 0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542 0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744 0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
Mar 22, 2009 | Canon CLC 1140 Copier
Canon copier iR2016
My Canon copier IR2016 Problem code E007 Solve the problem pls
help me
Mar 02, 2008 | Office Equipment & Supplies
CANON IR2016
hi... try to clean up your copier... usually dust accumulates inside the copier that's why paper inserted will always jam....always see to it that you copier is free from dust and other small particles that would cause your machine to get errors....
Feb 27, 2008 | Canon PC-940 Black and White Copier
Open Questions:
2,030 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
