Question about Mitsubishi WS-65819 TV
Tv will not turn on. I hear it click and the light goes on for about 3 seconds then shuts off. I've tried this about 20 times
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Please listen and try this:
When the power light comes on and goes off, on the front of the set press BOTH the Menu and Input (Device) buttons at the SAME time and HOLD them both for at least five seconds and then release both.
The power light will blink a two digit error code and will repeat it about 5 times. To get it to repeat you would have to unplug the set and turn it one again etc.
The most common error is 2 blinks, pause, 2 blinks.
Let me know what error code you find and I will direct you as to what it means and what may have to be done.
SD TECH
Posted on May 13, 2010
If the pilot go out on a furnace would gas continue to flow to the pilot , or would it shut off with in a few seconds
The pilot flame heats a thermocouple, so if the pilot goes out, the thermocouple cools and shuts off the gas. It can take anywhere from 20 seconds to 2 minutes for it to shut off. You should hear an audible click when it happens.
Sep 14, 2014 | Heating & Cooling
Screan shuts off after 30 seconds and 3 lights flash on botton near power button.
Contact Samsung tech support, Tell them this info, they should be able to tell you the type of problem you have
Feb 12, 2014 | Samsung HLP5085W 50" Rear Projection...
When you turn on power you hear a click and the green light turns on. Three seconds later you hear another click and the green light turns off.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and"menu" buttons on front of tv for at least 5 seconds and then release bothtogether.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know what you find and I will assist you.
SD TECH
Aug 31, 2011 | Mitsubishi WS-55807 TV
Tv randomly shuts off
next time it shuts down and power light goes out--do the self check.
On front of set press and hold BOTH MENU AND INPUT BUTTONS FOR AT LEAST FIVE SECONDS AND RELEASE BOTH BUTTONS.
Power light (if an error is detected) will blink a two digit code.
Most common is 2 blinks, pause and 2 blinks---set if there is a error code will repeat it at least 5 times.
If you detect a error code, let me know and I will tell you what it means.
SD TECH
Jun 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
There is no picture when I turn the TV on, the red lamp light under the power button is blinking, when you turn the tv on, it goes off for 60 seconds, there is a ringing buzz every 20 seconds, then the tv...
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is xl-2100 you can find it here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click-48173.Have a blessed one!
Apr 12, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Samsung DLP TV HL-R4667W. When turned on, the TV comes on normally. Within about 10 - 20 seconds, the screen goes blank, can hear the sound for another couple of seconds, then can hear a relay trip, and...
Those lights flashing mean the lamp is the issue. You need to test it with a meter. If the lamp tests ok then it may be the ballast is bad and that is what powers the lamp.
Oct 12, 2017 | Televison & Video
I have a Mitsubishi 55 inch rear projection tv model ws55859. As soon as you turn on the power, the tv shuts down (either by remote or front of panel). The green light comes on for about 1 second and you...
Have you tried holding the input and menu buttons on the set both in together for 8 seconds to see if it will blink a 2 digit error code? Try that and let me know what code if any flashes from the Led.
Mar 30, 2008 | Televison & Video
RCA Television D52W14
The first thing in this unit is to check the ribbon cable that goes from the front control panel to the back ssb board, I would unplug and replug to make sure seated properly. Then try it again. There are alot of screws to take out but worth it if this solves the problem.
Jan 08, 2008 | RCA HD52W58 52" TV
Mitsubishi WS-65819 TV Logo
260 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
