Question about Samsung RS2630WW Side by Side Refrigerator
De icing the freezer in a Samsung SW 2630WW
There's ice buildup in the freezer and I want to de-ice it. The fridge section is working normally and I don't want to turn it off and ruin the food in that section. There's only one power chord for the whole unit - both sections. I've turned the freezer to it's mildest setting and opened the door, but the freezing element is still keeping the freezer too cold for the ice to melt. Is there an override switch, or a separate power switch for the freezer only? How do I de-ice this thing without powering the whole thing down?
Take all of the shelves out of the freezer side. Take to Philips screws for backing and 4 philips screws from vent cover just above cover. unplug, Use a hair blow dryer and melt it. Put it back together and there you go. Whole operation from start to finish is about 15 minutes.
Posted on May 20, 2010
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
Samsung rs21dcns fridge freezer not gating cold composer is working
Do you see any ice buildup in the freezer section?
Oct 23, 2014 | Refrigerators
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
A 11 year old whirlpool fridge.. freezer working but not the fridge.. water dripping out from the shaft between freezer to fridge
HI, sounds like you have 2 problems. First of all, your drain pan in the freezer is clogged and will need to be cleaned out, second: this ice has caused an air flow restriction to the refer section. When you clear out all the ice, look for obstruction that you prevent clean air flow to the refer section. This should solve the problem.
You may have to remove all the food from the freezer, remove shelves and rear wall to clear all the ice. Failure to remove all the ice can prevent air from circulating from section to section. I would not suggest in using a hair dryer, too much heat in the wrong place can cause damage to the liner in the form of warping.
Turn off the unit while doing this de-icing, this will help greatly.
Good Luck
Aug 14, 2011 | Whirlpool Refrigerators
Freezer cools well, refirgator is warm, the vent that brings air from frezer to refrigator has no air movement, ice inside , i broke some ice with knife shoul di spray hot water to get rid rest , I did...
This answer will be somewhat long, but in order to understand the "fix" for your problem you need to understand how a refrigerator-freezer works.
Most units have ONE COMPRESSOR which usually cools the FREEZER. Then, to cool the fridge area, there is a DUCT or ducts between the freezer and the fridge area to move some small amount of very cold freezer air into the fridge section. In the old days this occurred by convection, but most newer units have a small fan in the duct to more dependably move the air.
The run time of the compressor, and thus the temperature of the freezer is usually controlled by a THERMOSTAT [usually with numbers on the dial]. A second control [usually with the letters A, B, C, and sometimes even D] operates either a DAMPER in the duct, or controls the duration of fan operation in order to control the temperature in the fridge section.
Under certain conditions of higher humidity, FROST [fine ice crystals] can build up in the duct, and on the fan if there is one, reducing or totally blocking the cold air flow from the freezer to the fridge section.
From your description of the freezer working well, but the fridge section being "warm" suggests that blockage of the duct is what has happened. However, there are a couple of other possibilities:
1. You inadvertantly moved the fridge control to a warmer setting,
2. You inadvertantly placed something in the freezer and/or fridge which BLOCKED the entrance or exit of the duct,
IF one of the above are the cause, a "manual" defrost of a few hours with the freezer and fridge doors open to allow warmer air in should melt out any frost/ice from the duct and allow the system to work properly. Depending on the severity of the frost/ice buildup, it could take a couple of days to fully melt all the frost/ice.
During the manual defrost ALL frozen and perishable foods should be temporary stored in an ice chest or cooler of some kind.
One more thing, in addition to heavy humidity, frost/ice buildup can also be caused by a defective automatic DEFROST TIMER. IF the system does not do its regular defrost cycle [usually an hour or two once in each 24 hours], then frost/ice buildup can occur even with "normal" humidities.
So, once you have the system back in operation, watch for the normal cycling of the defrost program, and if the problem continues, contact a qualified refrigeration repair technician to repair or replace the defrost TIMER.
Jul 13, 2011 | Refrigerators
Ice buildup in freezerator freezer section
If it is not a frost less freezer you'll have to remove perishables to another fridge/freezer; unplug and de-thaw the unit.
Nov 21, 2009 | Gladiator GAFZ21XXMK Bottom Freezer...
Evaporator fan stops working due to ice buildup around fan.
you need a drain tube heater.it is like a chain fence tie made from alluminum,you can actually use the fence ties,wrap one side around defrost heater and stick the other side in drain.that will prevent it from happening again
Mar 07, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Fridge wont stay cold in the bottom.
Your frost free is not defrosting properly. There should be no ice buildup in the freezer section. Frost in the freezer section stops air circulation to the refrigerator section.
Jun 28, 2008 | GE Refrigerators
Refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Nov 11, 2007 | Refrigerators
Samsung RS2630WW Side by Side Refrigerator Logo
573 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
