We had a thunderstorm and had the electricty blink off then back on. Everything started working again but our Philips DVD home Theater System HTS 3555. Now there is no power to it at all.
    President:
  • 1,297 Answers
Sounds like you got a power spike that only took out your DVD
check your owners manual to see if yours has a replaceable fuse.... the older ones have replaceable fuses but the newer ones do not!
Posted on May 13, 2010
Philips HTS 6600/12 Home Theatre System HDMI does not open the DVD door.
DVD sledges work by a rubber belt that in your case might have broke or come off. It's very easy to replace. Find the original belt. Measure the diameter in MM (approx) and do a Google search for "Drive belt XX MM".
Get the nearest to your size.
Jan 21, 2016 | Philips HTS 6600/12 Home Theatre...
I have a Philips HTS 3371 DVD home theatre and can not play many DVD's as it give wrong region error. Can you please provide the unlock code and how/where to enter it to get it fixed?
Hi -
Please follow the instructions below for unlocking your Philips HTS 3371
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
1. Switch the DVD player ON
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Regards,
BElectric
Mar 26, 2011 | Philips HTS3371D Theater System
I GOT YOUR HELP PREVIOUSLY. RECENTLY I AM HAVING FOLLOWING PROBLEMS WITH MY PHILLIPS HOME THEATRE MODEL-HTS-3265. **** I HAVE BOUGHT ONE VIDEO CD OF VIOLIN BROTHERS LIVE CONCERT FROM ASHA AUDIO BUT...
It's possible that this DVD is not from the same region as the DVD player.
For instance, a DVD from India (region 5) will not play in a DVD player from the US (region 1).
You may want to check into that and post a reply here.
Mar 01, 2011 | Philips HTS-3565 Theater System
How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
May 25, 2010 | Philips HTS-3555 System
Want to make my philips DVD HTS 3265 a code free one. it is region 3 and I want to see DVD region 2
Open Tray
Place different zone DVD into player tray
Press 99990
Press Play
Enjoy
May 30, 2009 | Philips HTS-3565 Theater System
Phillips hts3410d no sound VERY dim led
Have you had any thunderstorms recently in your area? if so, this could be a pulse sent threw your system form an electrical storm. this happens often during dangerous thunderstorm activity. Also, your electrical wiring in your home can produce this as well due to a faulty circuit breaker box or lose ceiling fan hook ups. the best scenario could be a defective product. this way, you can get a full refund or a replacement set up.
Jan 28, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Phillips 6500 home theater system
Turn the power off, and then unplug the home theater from the wall outlet. Plug it back in after about 30 seconds, and turn it back on. If it still won't eject, then the HTS needs repair. Philips will replace it if it is still in warranty.
Feb 23, 2008 | Philips HTS-6500/37 System
Philips Home theater system
Just run the yellow cord that came supplied with the HTS from the CVBS plug in the back of the HTS to any available yellow video input on your TV, then you want to change your TV's video/source/input/channel (the wording varies by tv manufacturer) to Video 1/AV 1/Aux 1, or whatever your television is calling the yellow input that you plugged into.
Also, Philips number is 1-888-PHILIPS
-Tha Mp3 Doctor
Jan 12, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
97 people viewed this question
 Grubhead
Grubhead
